Question about Refrigerators
Samsung RS22DCSW Service Manual
Need diagram of pipes to have new compressor fitted
2 Suggested Answers
  • 6 Answers
SOURCE: water line broken for Kenmore refrigerator near compressor
Cut off a piece of line and go to a good hardware store, they can show you how to fix it. Need a coupling, and a nut and ferrel. House water line goes on one end of coupling, nut and ferrel on the broken water line on fridge. A good hardware store will be able to show you how to fix.
Posted on Aug 07, 2008
1988 Honda CBR 250 RR fuel pump not working
Hi, James_hume22 for this scenario you will need your service manual that has all fastener torque specs and a wiring diagram on the back pages, parts fiche, and owners manual if you can not find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Thread Running honda cbr250 without fuel pump
Honda Motorcycle Wiring Diagrams
1986 1999 Honda CBR250R CBR250RR Service Manual Moto Data Project
https://www.partsfish.com/page/oem-parts-for-honda
http://www.hondampe.com.au/docs/owning_a_honda/owners_manuals/motorcycles/CBR250R-RA%2032KYJE000.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
May 02, 2018 | 1990 Honda CBR 250 RR
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
Sep 25, 2017 | John Deere Garden
After you change the compressor do you need oil.
if you fitted a new ac compressor , they normally come pre oiled so adding oil is not necessary
if you fitted a previously used ac compressor , the amount of oil added has to be measure carefully as there will still be oil in the ac system and pipes
as the gas has to be added by pressure gauges , best if you get an accredited ac specialist add the oil if necessary and fill with gas
Jun 28, 2017 | Air Tools & Compressors
I have a Carrier 38QCA036 and was wondering if there is any model I ca replace it with, without changing all the pipes ect
if the unit you want to replace it with uses the same gas then there is no need to change out the pipes
if the replacement unit uses r312 gas the pipe fittings are a different size so new pipes will be used as there is a higher operating pressure ( pipe wall thickness will be larger)and to stop people mixing gasses and compressor oils different fittings are used
so look at the models and see what gas they use
Nov 13, 2016 | Cars & Trucks
The outside center and out side corners are very hot. Everything else is working fine
Hot refrigerator I have a Samsung refrigerator RS2630SH ...
www.fixya.com/support/t322304-hot_refrigerator
Also the freezer side outside wall is very hot to touch. Ice maker does not work as well. Any suggestions appreciated, excluding the one "not to buy Samsung ...
Samsung RS2630WW Side by Side Refrigerator Divider hot ...
www.fixya.com > ... > Samsung RS2630WW Side by Side Refrigerator
Samsung RS2630WW Side by Side Refrigerator, divider hot related issues. ...Compressor/motor on mu Whirlpool frige is really hot. face of fridge/freezer ... centerdivider is hot to the touch, it means that the compressor is running hot. either your ...means there is inadequate air flow over the condenser coils outside the unit.
[PDF]SAM0059 Samsung Side-by-Side Refrigerator.pdf
applianceassistant.com/.../sam0059_samsung_side-by-side_refrigerator.p...
A newly developed SAMSUNG side by side refrigerator in 2004 has the .... Warranty service can only be performed by a SAMSUNG authorized service center. .... SUB-CONDENSER. Hot Pipe. Hot Pipe. Compressor. SIDE CLUSTER PIPE .... corner of the refrigerator. ... The CoolSelect ZoneTM thermistor is located outside.
Jan 25, 2016 | Samsung RS2556 Side by Side Refrigerator
Need a manual for a Samsung fridge freezer model rs21dcn
no water coming out of dispenser. water is coming through the valve out the other side but not going through the water pipe when fitted. any suggestions bought and fitted a new valve but still not working?
Jun 14, 2012 | Samsung Refrigerators
Motor will run but frige will not get cold. I see there is a cripped off pipe from the bottom of the compressor. if I fit a service port at that point can I check for charge? and if none than put a...
When the gas is sealed off there is a pipe which ends out. So this is not necessarily a leak. But it is important that you check the compressor motor speed, check the gas pressure within- pumping pressure to be checked - before the problem of a leak can be ascertained. Also if there is a leak then you need to pressure test the sealed system including the compressor before gas is filled.
Take help and estimate before you decide or a new fridge would be cheaper.
May 03, 2011 | Refrigerators
The manifold which holds the Air Hoses and control valve and gauge is broken and I need a new one ,dont know the part number
We repair lots of compressors with broken manifolds. Most compressors now use a manifold with a built in pressure regulator. We are not able to find exact matches so we use a manifold from porter cable or make one out of pipe fittings. If your compressor was made in china, most likely the thread and tubing sizes are almost impossible to match. To use porter cable parts, go to dewalt service center or to porter cable dealer and find close match then use that model number for ordering your part. Check closely that parts/thread/fittings will work.
Jan 29, 2011 | Hdc Homer Hdc 2 Hp, 4 Gallon Pancake Air...
Would like to know how to intall an air condition compressor
Firstly de gas the a/c system then remove a/c belt then remove the 2 a/ c pipes to the compressor then disconnect the ac clutch wiring remove the bolts holding the compressor to the cyl block fit new compressor replace the ac pipe orings Then refit the ac pipes reconnect ac clutch wiring refit belt. Then regas the system addind uv dye and comressor oil
Oct 04, 2010 | 2001 Pontiac Grand Am SE
Aircon pipes dont fit
the refrig doods use out side diamiter. 1/2" pluming pipe is called 5/8" in refrig. we use a reducer to go 1/2 od to 3/4" od, or we swedge one to get the smaller to fit inside the larger and soder. add flairs to the finished size pipe
Feb 17, 2008 | Heating & Cooling
Refrigerators Logo
137 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
