Remote code boston acoustics
Remote control code for Boston Digital Theater 6000
HDTV GURU
  • 261 Answers
SOURCE: need help installing subwoofer
Just run "RCA" cable to sub and split off to both L&R with y adaptor and hookup to suboutput on receiver and plug into outlet and you should be a bangin then. GOOD LUCK. GURU JAY
Posted on Mar 22, 2008
SOURCE: how to hook up a boston acoustic ba7500g speaker
you can connect the BA7500G speakers to a regular digital coaxial output by using a cable that has an RCA plug on one end and a stereo minijack on the other. However, the pole of the RCA must connect to the tip of the stereo minijack and the shield of the RCA must connect to the middle ring on the stereo minijack. Also set your soundcard to output at 16bit and 48khz.
Posted on Dec 05, 2008
  • 6 Answers
SOURCE: Not enough IR range to use remote
Get yourself a very thin and small screwdriver. The type that comes in the eyeglass repair kits. Remove the cloth/plastic grill from the front of the sound bar. Locate the IR sensor in the center of the bar. Pry the dark red filter off the IR sensor and leave it off.
Problem solved, greatly increases range. I have read that there is a clear replacement cover you can buy but whats the point?
Posted on Jan 02, 2009
  • 7 Answers
SOURCE: Boston Acoustics BA7500... Problem
Try installing an old creative driver for digital audio but use system restore to take a backup of your settings first. Also, you may have to update the bios and unselect the AUTO mode for sound.
Posted on Feb 23, 2009
  • 7 Answers
SOURCE: Boston Acoustics Digital BA735 Speakers with no Analog input.
I use one set of BA735 with two computers. Computer A sends digital out and Computer B sends analog. BA735 plays both. I listen to music using digital while the analog from the other computer alerts me to the incoming messages in Pidgin.
I did have to change bios settings on one computer to use the on-board audio.
To enable digital output in XP, click on the speaker icon > Advanced > Select Enable SPDIF. You can leave the PC Spk Mute unchecked if you want the analog output as well. That's all.
I hope you are able to enjoy the rich sound of BA735. It's beautiful. My ears thank a lot for replacing those desktop speakers. BA735 hardly takes up any space . Two small speakers are perched on the hutch and the bass module is somewhere behind the desk, completely invisible.
Posted on Mar 06, 2009
My Boston Acoustics ASW 650 just turned off yesterday and wont turn back on. What could be wrong?
Check for the wires connections on all the terminals.
Else it is a minor problem due to power fluctuations.
Take it to a nearby technician.
Sep 22, 2014 | Boston Acoustics ASW650 10in 650 Watt A...
Boston Acoustics TVEE 26 factory reset
Reprogram the remote to function with a different brand of equipment that you do not have. The remote can't affect the receiver if it is not talking to it.
Feb 23, 2014 | Boston Acoustics TVee Model 26
Programming time warner remote to boston tvee volume
I had just about given up on programming my Time Warner universal remote with my Boston Soundbar until a mental lightbulb came on. This is a two step process. Step 1: Program your Time Warner remote (I have CLIKR-5, instructions available for other models at timewarner.com) Using Pre-Programmed 3-digit Code method -Turn on soundbar - Press device button (I chose AUX) and OK/Select simultaneously until device button stays lit. - Point remote control toward the soundbar and enter code (447 for Boston Acoustics) - Press the device button again to store the code. The TW instructions say you should now be able to turn the device off to verify that it works, but this is not true for the soundbar. Hang in there with me. Step 2: Program your remote from the Boston Soundbar. - Press the power button and the volume up button simultaneously until the indicator light flashes orange. Here's where the instructions provided with the soundbar fail to explain how to do this. Each button is individually programmed into the TW remote. What you have done so far is enable the remote to accept the programming. - Volume Up: press the volume up button on the soundbar while it is flashing, the light should become steadily orange. - While holding the remote steady about a foot away from the soundbar, slowly press the volume up button on the TW remote four times. The orange light should flicker each time you do, turning green when completed. - Volume Down, Mute, Power: repeat the steps for Volume Up, except press the button on the soundbar you wish program to the TW remote while the soundbar is flashing orange. It should become steady before you press the corresponding button on the TW remote. Good luck, I hope this helps. -Deidre.
Dec 05, 2012 | Boston Acoustics TVee Model 25 Sound Bar...
Boston media theater system 7000684 input plug broken
better idea .... set FM transmitter in your laptop & receive audio signal with FM receiver.
or" connect external EP socket.
May 28, 2012 | Audio Players & Recorders
Need instructions on how to connect Boston Digital Media Theater
Plug the sub into the PC, then plug the two front speakers into the sub.
May 07, 2011 | Boston Acoustics MediaTheater Computer...
I lost one of my speaker cords for my BOSTORN MICROMEDIA SYSTEM.The system has bass floor subwoffer, and two 3" X 3" soeajers,\r\nThe serial number iw EJ0102668 on the subwoofer,and the part# is...
You can order replacement speaker cables from Gateway Spares online.
These look like the appropriate cables:
8001844 - Gateway - Boston Acoustics Black Volume Control Speaker Cable
8001845 - Gateway - Boston Acoustics Micromedia Black Speaker Cable
8001846 - Gateway - Boston Acoustics Volume Control Speaker Cable
I hope that helps.
Mar 08, 2011 | Boston Acoustics BA735 Computer Speakers
Where can i find replacement wires?
I hope that helps.
Mar 08, 2011 | Boston Acoustics MicroMedia Computer...
My remote control stopped operating my Boston Acoustics Horizon Duo-1. I know it is not the remote because I have a 2nd Duo-i Horizon that can be operated by both remote control units. Thanks, Booker
You can contact the BA. As they will make arrangement to take it back and replace it. BA is a good company and they give consumer feedback as soon as possible. Well, only if you haven't got an answer to your question.
Jan 26, 2010 | Boston Acoustics Duo-i Horizon Clock Radio
Need new Power Supply Boston Acoustics Model No.
Boston Acoustics 12VAC 3000mA (3A) Adapter -BA Model DM12-3A0-1AN Only Source: BA Direct (in NJ: 978/538-5000) $54.00 (Incl. S&H) Ordered one on 7/8/09. Meow! Florida
Apr 01, 2009 | Boston Acoustics BA7500 Computer Speakers
I work at a public school in Boston, someone gave me the speaker set to hook up to my macbook. Can't get it to run.
well you probably have the digital version o the Boston acoustics speakers. you mac book may have a digital out . some mac books have a setting in the speaker setup. analog to digital.
Jan 13, 2009 | Boston Acoustics BA735 Computer Speakers
 Grubhead
Grubhead
