Question about MicroBypass Parking Brake Override Bypass Fully Automatic Video In Motion Pioneer
Parking brake override
Installed a pionner dvd player and have a two way switch. how do I hook it up?
Pionner avh-x2550bt wiering diagram
Red=ignition
Yellow=memory or constant power
Orange=illumination
Black=ground
Blue/blue w/white=Amp remote
Speakers are white/white w/stripe= front left
grey/grey w/stripe =front right
purple/purple w/stripe rear left
Green/green w/stripe rear right
If its a dvd player one wire will be for brake "ground" (have to be in park in order to watch movie unless bypassed)
Jul 11, 2016 | Car Audio & Video
XDVD700 how do i override the E Brake wire
usualy just hooking the e-brake wire to ground will do it. You may want to use a switch, hook one end to ground,one end to the wire leading to the dvd. that way you can flip it on and off when you want the dvd player to think the parking brake has benn engauged. Hope this helps.
Aug 17, 2009 | Car Audio & Video
How do i override a jvc KW-NT1 in dash dvd player
Install a toggle switch inline on the parking brake wire .
Jul 15, 2009 | JVC KW-NX7000 Car DVD Player
Park brake switch
If you have the old firmware then all you need to do is ground the parking brake wire..
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
Jun 29, 2009 | Clarion MAX385VD Car DVD Player
Putting kenwood kvt 617 dvd in rear of surburan how can i bypass parking brake so movies can play while driving
On bypasses you can either hook the parking brake wire straight to ground, if that does not work you can install a toggle switch between the parking brake wire and ground so you can mimic the parking brake on off.
Jun 04, 2009 | Kenwood KVT-617DVD Car DVD Player
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
Pyle override park brake code
You can run the brown wire to a ground and that should work for you. Would you happen to know the importance of the pink wire?
Dec 30, 2008 | Pyle PLTS76U Car DVD Player
Parking brake wire override
DVD head units have one extra wire in their wiring harnesses, compared to a standard CD head unit. On my Jensen, it's a peach-colored wire, and is the activation wire for the DVD feature. During the installation, the instructions call for this wire to be tapped into the emergency brake indicator light wire. The reason is this:
The e-brake indicator light is what is called a "ground complete" circuit. That means that the bulb always has power applied, but when you pull the brake, that puts a ground to the wire and completes the circuit, allowing it to illuminate. The head unit sees this ground, and activates the DVD player.
In my Jensen unit, I simply ran this wire to a ground (I used a screw near the fuse box), and I put a switch on the wire, so I could break the ground contact at will. Jensen calls for a procedure to activate DVD playback. In their instructions, they tell you to select DVD from the option menu, and when the "lawyer screen" comes up (the one warning you to park before you watch a movie), you release the e-brake for 3-5 seconds, and then reapply it. To simulate that with the switch I used, I leave the switch closed (activated), and select DVD. Then I flip the switch "off" for 3-5 seconds, and flip it back "on". This tricks the head unit into thinking I put the e-brake off for a few seconds and then put it back on, and the movie will start. Then I can drive away.
Basically, ground the wire that is used for DVD activation, and put a switch inline on it. Then you can break and reapply the ground in whatever manner is required by the manufacturer of your head unit. If there is no off/on sequence with yours, as there is with mine, simply ground the wire to a screw inside the dashboard and you're done.
Aug 10, 2008 | Car Audio & Video
Bypass the parking brake for vm9412 jensen
Hit Setup On Remote.
Select Language.
Get Remote And Hit 5,4,3,2,1,0.
Listen For Beeps. Touch “Hammer/Screwdriver” Logo.
Select Brake Override
Switch To Brake Override “ON”
Now Hit Setup On Remote.
this works thank you for posting this.
derek
Dec 25, 2007 | Jensen VM9510 Car DVD Player
Bypass
is there an override code I could put in instead of the toggle switch?
Sep 26, 2007 | Pioneer AVH-P4900 Car Video Player
MicroBypass Parking Brake Override Bypass Fully Automatic Video In Motion Pioneer Logo
88 people viewed this question
Top MicroBypass Science & Laboratory Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a MicroBypass Science and Laboratory Expert? Answer questions, earn points and help others
