Question about Kenmore 44109 / 44102 Side by Side Refrigerator
Refrigerator wont cool, fans run but not compressor
PSD2450GRW
Posted on Feb 07, 2009
    President:
  • 331 Answers
You didn't mention it, but I'll bet there's a "humm" followed by a "click" noise coming from the back of the fridge. Even if you don't hear the noise, the starter on the compressor has failed. One of two things cause this... 1.) A mechanically failed starter. 2.) A seized compressor. If it's the starter only, you are in good shape. If it's #2 and the unit is less than 5 years old, it'll be a warranty claim. If the unit is less than 5 years old... do not attempt the repair yourself. Because, if you do and find the compressor locked up, you have voided your warranty and they will not repair for free. If it's over 5? Install a starter. We need the FULL model number off of your fridge to provide steps on this. It's located on a data tag affixed to the inner fresh food section lining. Most likely near the top on the right. Please post back with these numbers if you require further assistance.
Posted on Aug 11, 2007
SOURCE:
Turned ac off while running well turned back on to soon
shut unit off and wait at least 5-10 minutes before re-starting. do not want compressor to struggle to start. good luck!
Jul 08, 2015 | Dometic Rooftop RV Air Conditioner
GE refrigerator model #GSS22WGMD wont cool at all but fans run but don't hear compressor
If possible, try by passing the thermostat. If it starts up the t/stat is bad.
Feb 25, 2015 | GE Refrigerators
Wont cool compressor runs
If there is a small amount of cooling, you have a failure in the defrost system. If there is no cooling whatsoever and the compressor is running, check for a failed condenser fan motor or blocked or dirty condenser coil. If those items are all okay, you have a failed compressor.
Jul 26, 2014 | GE Refrigerators
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
The refrigerator is running but will not cool eitherr side, a repairman changed a fan motor and bladebut is still wont cool. Is it worth spending any more money into it
Sounds like you may have a leak... can you tell if the compressor (black can in the back, bottom) is running also or not...if compressor is running and not cooling you may as well junk it....if the compressor is not running it maybe something more simple to fix...
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 15, 2010 | Samsung RS2630SH Side by Side Refrigerator
Wont stay cool
does it cool and then stop when it does this is there frost in the fzr compartment or ice build up. Does the fans run at all do you hear the compressor and compressor fan running. Just need more info
Aug 17, 2010 | Kenmore 57029 Side by Side Refrigerator
The compressor wont start back up. The fan runs
check the start relay and klixon, these may be burnt out.
May 15, 2010 | Refrigerators
Poor cooling on frezer and almost no cooling on refrigirator
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Apr 10, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is not cooling
Dirty condenser, condenser fan or evaporator fan motor are not running, Ice build up on evaporator and restricted the air flow. If compressor, condenser fan and evaporator fan motor are running but not cooling, then either compressor or sealed system problem.
Mar 07, 2010 | Refrigerators
My u-line 75rfb-00 refrigerator wont get cold the light comes on the motor sounds as if its working but it only gets cool not cold ?
Then you need to see if the compressor is running or is it the fan? You migh be hearing the compressor come on for a short while. The fan might not be running. Replace the fan if its not running
Sep 26, 2009 | U-Line 75R Refrigerator
Kenmore 44109 / 44102 Side by Side Refrigerator Logo
151 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Paul Carew
Lawrence Oravetz
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
