Question about Music
How to connect a roland pc-200 mk II midi keyboard controller to yamaha mw12cx mixer
  • 4 Answers
SOURCE: Yamaha 61 key keyboard midi usb connected but what next
Depending on what you want to do...
If it's only music Mixing, you will have to plug your keyboard via audio jack to the line in of your computer. Then Audacity (free soft) can do the job.
If you want to edit midi file with your keybord you will need midi editor software like Linux-Rosegarden or if under windows try LMMS (all free soft of course).
Good luck
Posted on Apr 27, 2009
  • 1138 Answers
SOURCE: Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Posted on Jul 17, 2009
  • 5603 Answers
SOURCE: How to connect YamahaPSR-550 keyboard with PC in Cubase
You would connect the in's to the outs on the MIDI connections.
You would need a driver fro the EMU cable so that the USB will be recognized.
You LIKELY will need a soundbank EDITOR compatible with the keyboard to allow talking to the synth. Often theswe are called "plu-ins" to use with Cubase. They may already have one or it may be an option, some of which have to be purchased seperately.
Posted on Sep 25, 2009
  • 5603 Answers
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Posted on Sep 08, 2010
  • 1138 Answers
SOURCE: Roland e09 read "midi error" when connected with
If you have the version 1 cable you need to download a driver. The details are at this link:http://www.cme-pro.com/en/news-detail.php?news_id=105
Posted on Nov 09, 2010
How do i connect my keyboard and my laptop?
Download USB MIDI driver for yamaha from yamaha website,and install to laptop.
Next:
Make sure the POWER switch on the instrument is set to OFF,then use an AB type USB cable to connect the instrument to the laptop.
After making the connections, turn on the power of the instrument.
Laptop will immediately notify that new hardwares is connecting and automatically install the drivers. Wait until the process is finish.
Thats all. In Ableton,the setting MIDI input must be set to USB MIDI.
Aug 19, 2015 | Yamaha PSRE413 Keyboard
Need user manual for MK-4902 midi keyboard
Use LMMS software on PC. You will need a MIDI to USB cable which you can get on eBay.
The manual can be found at:
webpages.charter.net/rochamalhada/MK-4902.pdf
Sep 20, 2012 | Music
I get random unwanted midi notes triggering while I plug my dd-55 into my emu x-midi 2x2 with my Reaper DAW. I don't know if this is a problem with the emu or the dd-55 itself, but it doesn't...
Check that you don't have MIDI echo on in the DAW. If the MIDI data is echoed, it MAY be merging with the outgoing and when MIDI signals are merged in pieces instead of whole messages the data is corrupted. If you can look at the data stream with software, you should be able to spot the problem. Another problem might be excessive latency of the recording software. Make sure you do not have antivirus or antispyware programs running or network running. The Roland will spill data at much less rate and while the dd55 may overrun the DAW the Roland might not be able to. The key to the problem is to analyze the MIDI data stream that is being recorded.
Sep 05, 2011 | Yamaha DD55 7 Pad General MIDI Digital...
I cant connect my yamaha ypt 320 to my pc using the midi
Assuming you have a MIDI interface on your computer, you need to connect the MIDI cables between the keyboard and the PC. You cross connect, that is, in to out and vice versa. You will ALSO need the driver software for the interface in the PC AND most importantly, some software in the PC to handle the MIDI for instance to record.
Mar 27, 2011 | Yamaha YPT320 61 Key Personal Keyboard
I have just bought a second hand Evolution MK-161 MIDI controller music keyboard on ebay. It works fine when I play it through my computer using the virtual organ software 'Hauptwerk' (which is the prime...
You must use some form of MIDI sound generator module connected to get sound... It is a standalone capable MIDI generator, but NOT generating audio.
Mar 01, 2011 | Music
What should I do for connect the fc7 to Roland RD-700sx for controll the loudness? Thanks a lot Heinz
Yamaha pedals MAY not work on the Roland... However, read page 85 of your manual regarding the FC1 and FC2 jacks. plug the pedal into one of them and then assign/select that jack as controller #7 (CC7) which is the volume controller number used in MIDI.
Jan 23, 2011 | Yamaha FC7 Pedal EXpression
None of my programs are receiving midi commands from the FC-300, it's linked into an M-Box II.
I have a FC-200. I don't know by your post what you are trying to do but think of the pedal as a device that can alter a communication between two other devices or one device which transmits info which the pedal receives, alters and then transmits to whatever is on the receiving end. In this case your program. The pedal has to have sysex info transmitted to it or midi info such as a sequence etc. I use mine to control the parameters on my wind syth module. I go from midi out on the module to midi in on the pedal and from midi out on the pedal to midi in on the module. There is also a battery onboard that you might want to check that stores your pedals programmed parameters. Hope this helps.
Aug 30, 2009 | Roland Fc300 Guitar Foot Controller
Jul 16, 2009 | Music
Music Logo
64 people viewed this question
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
