Canon ir 2318 photocopier error message **E000261-000
Give message **000261-0000
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
  • 199 Answers
SOURCE: canon ir 2200 Error code E000064-0000
E064 The presence of a high-voltage error is communicated by the composite power supply PCB. (The output for primary charging, developing, or transfer
has deviated from a specific level of voltage.)
Main cause The contact has poor connection. The wiring is faulty. The composite power supply PCB is faulty. The DC controller PCB is faulty.
Action
1. Contact
Is any of the contacts of the primary charging roller, developing assembly, or transfer charging roller soiled? Or, is there poor contact?
YES: Clean the contact, and set it once again.
2. Wiring
Is the wiring between the contacts for the following normal: DC controller
PCB (J301), composite power supply PCB (J136), primary charging roller, developing assembly, transfer charging roller?
a. DC controller PCB (J301) <-> composite power supply PCB (J136)
b. composite power supply PCB (J130-7) <-> primary charging roller contact
c. composite power supply PCB (J130-1) <-> developing assembly contact
d. composite power supply PCB (FT133) <-> transfer roller contact
NO: Correct the connection.
3. Composite power supply PCB, DC controller PCB
Try replacing the composite power supply PCB. Is the problem corrected?
YES: Yes.
NO: Replace the DC controller PCB.
Posted on Feb 26, 2009
pineworks
  • 4041 Answers
SOURCE: IR 3100 error. E020-01A9, E020-02A9,
E020-01A9 Error Code : iR C3100 Series
Hi there
I have looked it up and what it says about it I have put down for you so you can gave it a try hope it works for you.
Approved
Symptom
E020-01A9 Error Code.
Cause
For ATR control, the detected Toner/Density ratio exceeds the lower limit (3%) 3 times continuously for Yellow
Action
The ATR Sensor and Patch Image Read Sensor both determine toner density. Depending on the density readings the copier will or will not add toner. Check the status of the Drum Unit under COPIER>DISPLAY>MISC>DRUM-LIFE. The Patch Image Read Sensor looks at a patch of toner that is generated on the drum for each colour and determines the amount of toner that is in the patch by the amount of reflected light. If the drum is not creating the patch correctly, the patch reading will be affected. Replace the Drum Unit if it is 80% of its rated life or higher. ..
Posted on Feb 16, 2010
pineworks
  • 4041 Answers
SOURCE: My canon 4370dn gives an error message: E225
I know this is for a diferent printer but it could work it worth a try.
Canon imageCLASS MF4150 And ERROR E225 maybe others
Canon imageCLASS MF4150 Firmware Update V062 Windows 2000/XP/Vista/Windows 7(all x32/x64) from Canon Multifunction .
Hi there
This is because you need to update your Firmware,
So what I have don for you I have found the Update you need and I have put it on my website for you to download, this is a update for Vista / Win 7 / All 32Bit and 64 Bit.
Click Link = http://www.4all2sell.com/driver/Canon-MF4150_FirmwareUpdateTool_V062.exe
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
All files on my website is only there foe a limited time.
Posted on Apr 28, 2010
IR 2318. What is e261 error?
http://www.copytechnet.com/forums/canon/76193-canon-ir-2318-error-e261-dont-found-manual.html
Apr 05, 2016 | Canon Office Equipment & Supplies
What is the error 00261'on photocopy machine can't on ir 2318?
It basically means that the fuser isn't getting the correct voltage.
Do check to see if the fuser is warm.
Feb 19, 2015 | Office Equipment & Supplies
Error code 0001
canon ir 2318 photocopier
what is the solution of error code E00001-0001
E000808-000
Nov 02, 2013 | Canon imageRUNNER C3170U Color Copier
Service manual Canon ir 2318
Hello friend, I have downloaded a Good canon iR2318 service manual from below link:
Canon iR 2318 2320 2420 2422 service manual:
http://goo.gl/dBXTt0
Good luck on repairs.
Aug 03, 2012 | Canon imageRUNNER 6000 Copier
Canon IR 2318 Copying Problem
My Canon copier IR 2318 has a problem. When it prints, comes out a dirty paper with texts just easy to be rubbed by a finger and disappear! No any error code shown, so what can I do to fix this.
Jun 26, 2012 | Office Equipment & Supplies
Canon photocopier 2318 service manual
Hello friend, you can find the Canon iR 2318 2422 2420 232 service manual in below link:
Canon iR 2318 series service manual:
http://goo.gl/Ee4H4l
Thanks
Mar 12, 2012 | Office Equipment & Supplies
Error e000007-0000 for canon ir 2318
Feb 04, 2012 | Office Equipment & Supplies
CAnon xerox Machine IR 2318 L Error code : E 000007-0000
My canon ir 2318L shows error**E000007-0000 how can i solve this problem
Feb 28, 2011 | Office Equipment & Supplies
503 people viewed this question
k24674
jasbo
jasbo
