Question about Vitapur Energy Star Bottom Load Water Dispenser
Vitapur water cooler
Cooling tank has problem refilling
Vitapur manually cool lite is not on
You have a model number ? is it VWD9506W-POU
VWD9506BLS-POU
if it is the cool light is off because the water is cooling to coldest temperature . See the manual here.
http://www.homedepot.com/catalog/pdfimages/2d/2d629539-f891-45c8-8493-fdc50aff5a84.pdf
Aug 16, 2014 | Refrigerators
Water cooler runs for 20 sec and then stops says that bottler is empty. not pumping water?
either you faild to unpack it properly and left some thing in the dispenser area where the bottle drops in. It doesn`t pump water, it gavitys out of the bottle.
Apr 23, 2014 | Vitapur Energy Star Bottom Load Water...
Not sucking up water
the cap on the top of the water bottle at the elbow sucks air. Take off the plastic elbow and put a hose in place of the elbow clamp so no air and the water cool will pump water.
Mar 30, 2014 | Vitapur Energy Star Bottom Load Water...
Hot water not dispensing
I ve glacier bay hot/ cold water dispenser - new product. Cold water is coming but no hot water. Water is not coming. What have I to do it is a week old machine.
Nov 20, 2013 | Vitapur Water Dispenser. Hot, Room and...
Vitapur water cooler troubleshooting
Mine was beeping after it overflowed. I could not figure out why, but my husband did. The beeping noise is a warning that your holding tank is too full. Just dispense some of the water and it will shut off.
Jun 15, 2012 | Refrigerators
Someone put oil in the cooling system,what should i do?
drain the radiator refill with water & use some radiator cleaner, you may need to repeat this several times to get all the oil out......hope this helps.....cheers
Aug 14, 2010 | 1999 Mercedes-Benz E-Class
Cold water never quits trying to cool water. runs
Hello, this is going to be a bad thermostat. This is located behind the grill in the back. It has 2 electrical wires and a metal wire that goes to the tank, you should replace it. Hope this helps! Mike
Oct 30, 2009 | Hamilton Beach Water Cooler with Storage...
Vitapur Energy Star Bottom Load Water Dispenser Logo
26 people viewed this question
Top Vitapur Water Filters & Coolers Experts
Tom Chichester
Are you a Vitapur Water Filter and Cooler Expert? Answer questions, earn points and help others
