Question about Refrigerators
Husqvarna opal plus bruksanvisning
Ice on backwall
I'm trying to insert a zipper with my Husqvarna Viking Opal 650 and the instruction book shows to use the E foot but on my Graphic Display it doesn't show what # to use. Appreciate any assistance
Husqvarna Viking Presser Feet
You can probably use any zipper foot made for your machine.
This is what the E foot looks like, so one that is similarly shaped should work:
http://www.thecolorfulworldofsewing.com/Husqvarna-Viking-Zipper-Foot-E.html
Just make sure the foot is adjustable (right or left) so you can avoid hitting the foot with the needle.
Nov 13, 2017 | Husqvarna Sewing Machines
My husband bought me a Husqvarna Viking Opal 690Q sewing machine. In one of the videos it talks about an extension arm for quilting. Where can I purchase one and how much are they?
You can probably contact a H/V vendor. Otherwise, you can also purchase some table extensions to fit your model machine from vendors like Sew Steady Table. You select the make & model and the size you want and they cut it to fit.
Jun 06, 2017 | Husqvarna Sewing Machines
Where is the serial number on the opal 670 sewing machine
The serial number is on the bottom of the sewing machine. There is a sticker that states where the machine is made, what the model and serial number are as well as the electrical information. Just tip it over onto the back of the machine.
Jan 11, 2015 | Husqvarna Sewing Machines
I have a Kenwood side by side with water and ice despender. The freezer doesnt work fine but the other side(refrigerator) cool is good and the motor runs constantly without turning the switch off. It is...
If no ice build up on back wall of freezer then you may have a refrigerant leak causing the less than ideal situation with freezer. Need to locate and repair leak and fill to specs to get proper cooling.
Jul 24, 2017 | Refrigerators
Ice is forming on the backwall inside the refigerator portion of my side by side sub zero
It is probably low in refrigerant that means there's a leak in the seal system , you should contact subzero beacause they give a 10 years warranty on this.
Jul 27, 2009 | Refrigerators
The entire backwall of the unit is solid ice. 2
OK first defrost the refrigerator. Unplug and remove the back panel covering the evaporator and lets look at the defrost element and defrost thermostat. If they are OK we may need to have a look at mother board mounted on back of fridg. Let me know when you are ready, Sea Breeze
Apr 22, 2009 | GE Profile PDS22SCRL Stainless Steel...
I want to know if the RCA 8GB Opal MP3 Video Player works with itunes?
Hello csbnm,
The RCA Opal MP3 player appears to be compatible with iTunes and iTunes Plus servies.
Best Regards
Ken
"Go Ahead. Use Us."
Jul 01, 2008 | Audio Players & Recorders
Cooling problem
Look for a replacement "DEFROST" Timer which is located on the coil in the backwall of most freezers. If it is freezing up, that is a common, inexpensive fix.
Mar 14, 2008 | Refrigerators
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
