Question about Dishwashers
Tuscany DW101S-TU dishwasher runs a long time and dial slow to move or not at all,I think it may be the timer/settind dial.?
3 Suggested Answers
huuum
  • 750 Answers
SOURCE: sticking programer dial
Hello zxnigel,
Welcome to fixya.
I'm Huuum at your service.
You said, The program timer on my dishwasher is sticking.
And you have to move the dial by hand as it is taking 3 hours to do the wash cycle
I think the timer needs to be replaced!
What brand an model is your machine?
And how old is your dishwasher?
Let me know this information, please.
Here is an interesting report I just read.
Repair or replace?
When to pull the plug on your old Appliance
It nearly always makes sense to undertake simple do-it-yourself repairs,
such as replacing a gasket on a refrigerator or a freezer.
Typically, you'll also find a troubleshooting section for more-serious problems
in the owner's manual.
Should you pay for a repair or buy a new model?
The answer depends mostly on the age of your appliance,
how much you bought it for,and the cost of the repair.
Follow these guidelines:
When a repair makes sense.
If your appliance is under warranty or less than four years old
paying for a repair makes sense.
Note that appliances under warranty might require service from a factory-authorized technician;
readers have found them on a par with independent repairers.
When a repair might be a wise choice.
If your appliance is out of warranty and is four to seven years old,
it might make sense to pay for a repair. Customers generally pay $100 to $200 for a repair.
But you might want to buy a new model even at this stage,
given that today's models are quieter and have added features.
Higher energy efficiency is another plus: Energy Star-qualified models made after April 28, 2008,
are 43 percent more efficient than conventional models built before 2001 and 56 percent
more efficient than those built before 1993.
When it pays to replace.
The repair costs more than half the price of a comparable new appliance.
Data also shows that it doesn't pay to fix a less-expensive applaince
six or more years old .
Thanks to better recycling programs, less than 10 percent
of a appliances you replace is likely to end up in a landfill.
Thanks for giving me the opportunity to help!
Please remember to leave a rating before you sign off!
Thank You, HUUUM
Posted on Sep 30, 2008
localwonder
  • 6784 Answers
SOURCE: Dishwasher runs several hours
OK, that several hour wash cycle seems to be very abnormal and, the only way this can happen is if the timer control mechanism is damaged. this is referred to as a Overrun error. simply replacing the timer will fix this issue.
Posted on Jun 03, 2009
How to setup instructions for a tu40 tork timer for a pool
TU40 is analog dial timer, wired same as GM40, DTU40, GE15000 series etc
http://waterheatertimer.org/How-to-wire-GM40-timer.html#TU
http://waterheatertimer.org/images/Wire-GM40-timer-600.jpg
http://waterheatertimer.org/images/Wire-GM40-timer-120V-600.jpg
TU series can handle motor load 3Hp @ 240V, 1.5Hp @ 120V
TU series automatically detects voltage... no dip switch selection
How to set analog timer dial:
http://waterheatertimer.org/How-to-set-timers.html
Gene
Aug 17, 2014 | Hardware & Accessories
Dishwasher keeps running
That is a indication of a bad timer the timer is the nob that u turn to make it run drop door down take off the top six screws on the door from the inside then pull off the knob then there will be two screws behind nob and the time should come right out then once u get the new time pull off wires one by one to make sure u putt when in the same place
Jan 16, 2014 | GE Dishwashers
Tuscany dishwasher
Sounds like the timer unit went bad call manufacturer for part the job is quite easy and should only take about 15mins
Nov 19, 2013 | Health & Beauty
How to set a tork timer
1) Copy following link to identify timer, and download possible manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html
2) Tork TU universal
3) Usually the dial will rotate manually until current time lines up with Time arrow located next to override lever, or time arrow located on inner dial, depending on model number.
4) Tork DTU digital timer:
http://waterheatertimer.org/How-to-wire-Tork-DTU40-timer.html
5) After opening links to identify timer, add comment and describe where you are, and what you discover.
Feb 20, 2013 | Intermatic T101 - 24 Hr. Dial Time Switch...
Timer wheel seems to slip. Won't hold time
You posted under Intermatic T104 timer.
If you have different timer, information below may not fit your timer.
Add a comment with correct timer brand and model number.
1) Click manual override on-off to see if Load turns ON, and that override snaps crisp and clean and is not sluggish or hard to move.
If override is not functioning well, then timer is bad. Buy new timer.
2) If dial is rotating, note current time, and watch if dial is keeping correct time over full day.
If dial is running slow, then buy T100 series 240Volt clock motor for T104 timer.
3) If dial is keeping good time, then tripper might be worn and need replacement
Link below shows Intermatic T100 series parts:
http://www.grainger.com/Grainger/timer-accessories/timers/electrical/ecatalog/N-8hi
4) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer, or any do-it-yourself project.
Jan 06, 2011 | Intermatic T104 24h 208-277v Mechanical...
I didn't get any instructions with my timer. It is a tork 601A I don't know how to set it. I think it looks great and just what I'm looking for. The case was sealed but no instructions. Thanks J Seel
Tork 601A outdoor timer manual:
http://waterheatertimer.org/pdf/Tork-601A-Manual.pdf
Timer has 1 125Volt receptacle located on bottom of timer
96 captive tabs located around timer dial allow times to be set each 15 minutes.
Move pins in-or-out with fingernail or pen to set timer on-off functions.
Minimum time setting is 15 minutes.
Maximum time setting 23 ¾ hours.
Set multiple ON/OFFs each day.
Timer repeats every 24-hours.
Dial is divided into daylight and nighttime hours.
Nighttime PM hours are on dark background.
Daylight hours are on light background.
To set timer, rotate dial clockwise until current time lines up with arrowhead located on inner dial. Reset time after power outage.
Manual ON/TIMER switch located on inner dial.
To override time and turn on Load, move override to ON position. To use timer functions, move override to TIMER position
Dec 02, 2010 | TORK 601A 24 Hr Mechanical Outdoor Timer ...
Dial sticks in two places until dial is moved slightly
HI. this Timer mechanism will need ot be replaced soon. the timer motor is defective. this will continue to affect the performance of this unit. replace asap.
Jun 20, 2009 | Frigidaire 24 in. FDB750RCC Stainless...
Jun 03, 2009 | Frigidaire Dishwashers
Cycle Sticks unless I manually move it along
Ya, the mechanical timer/dial is the problem. The heating element just got stuck on as the timer stalled in that dry cycle.
May 03, 2009 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
Top Dishwashers Experts
Owen Barnes
