Question about LG Televison & Video
LG MKJ40653802 HOW DO I TURN OFF THE STB BOTTON AS IT WONT LET ME DO ANYTHING IT LIGHTS UP EACH TIME, THE REMOTE IS A LG MKJ40653802
2 Suggested Answers
ginko
  • 19396 Answers
SOURCE: I have a LG Television, model 32LG30D-AA. It
Hi.
As you said, if the TV starts with buttons, then the problem is either the remote or the IR sensor inside the TV. You can superficially test the remote using a digital camera. The camera will tell you if remote IR light is turning on, but it won't be able to tell you if the IR signal is out of frequency.
Unfortunately the only efficient way to find out if the remote is working is testing the TV with a different remote or testing the remote on a different TV. There is not even a way to test the IR sensor without using a replacement remote or a programmable remote. If remote and sensor work, the sensor will return 2.3V, if either one does not work there will be no signal. At the shop will test the TV using a programmable remote to find out if the IR sensor is working.
If there is a 3.5 mm jack socket tagged "remote in" at the back of your TV (there should be one), that can be checked with a tester like this to find out if the problem is IR sensor. You can try inserting and unplugging a mini jack several times with TV off to get rid of electrostatic charges on TV IR circuit.
If you have a programmable remote you can test the TV using a programmable remote, otherwise you will necessarily need to get a different remote.
If you need to replace the remote, before replacing the remote disconnect TV power cord and remove again the remote's batteries for five or ten minutes. That will reset both TV and remote. Try also inserting and unplugging a non-powered jack (eg. from headphones, or use the plug alone) several times. That will get rid on electrostatic charges in IR circuit.
If that does not work, get a replacement remote. It will be less expensive and more practical than doing anything else (e.g. buying a tester for remote-input or disassembling TV and replacing IR board straight away).
A replacement remote can be purchased from Amazon for less than £10: Replacement Remote or mkj40653802 by LG Electronics.
Regards.
Ginko
Posted on Aug 23, 2011
Connecting rca tv model#F20352SF to a tv converter box
  • Connect ANTENNA OUT of STB to antenna terminal on rear of TV OR, for better picture, connect 3-wire cable to color coded L AUDIO, R AUDIO, and video outputs on rear of STB and connect other ends to L AUDIO, R AUDIO, and video inputs on rear of TV.
  • If STB connected to antenna terminal of TV, set CH 3/4 switch on rear to whichever channel is NOT used in your area.
  • Connect antenna to ANTENNA IN of STB
  • Connect STB to power and use STB remote to turn on
  • Turn on TV
  • If STB connected to antenna terminal of TV, use TV remote to select channel 3 (or 4).
  • Use STB remote to select SETUP and perform channel search.
  • Use STB remote to change channels.
Oct 23, 2016 | RCA Televison & Video
How do I turn the closed caption off? I have a remote
      Immediately-within one second-push the MENU button on your remote. You should see a User Settings menu screen displayed. Use the arrows keys on the remote to highlight the Closed Caption option and press OK or SELECT on your remote to toggle Enable/Disable. Power on the Set-Top Box to return to watching TV.
      How do I turn Closed Captioning on or off? ' Time Warner ...
      www.timewarnercable.com/.../closedcapt/how-do-i-turn... Time Warner Cable
    Feedback
    How do I turn on/off closed captioning? - Comcast Help and Support ...
    forums.xfinity.com/t5/.../How-do-I-turn...off-closed-captioning/.../1325...
    Jun 25, 2012 - Turn STB off and leave TV on; Press Menu on STB or remote control; Using the ... If this does not activate Closed Captioning, try the following:.
Jan 24, 2016 | Televison & Video
How do I use a gamechanger remote to control LG TV?
How do I program ESPN game changer remote control - Fixya
www.fixya.com/.../t6930391-program_espn_game_changer_remote_co...
Nov 21, 2010 - how do I program ESPN game changer remote control - RemoteControls question. ... You can also use the "Power Scan method": Turn TV off. ..... I need code for an lg bh100 dvd player .... I need the code for an emerson hd flat screentv using a universal Game Changer Remote control espn edition.
Game Changer Remote Programing Codes - LuLuSoSo.com
www.lulusoso.com/.../Game-Changer-Remote-Programing-Codes.html
We Provide 20 for you about game changer remote programing codes- page 1. ... OEM remote control,OEM quality standard remote control for TV or STB 3. ... ZTH3607Use: universal Place of original: Guangdong China (. ... Samsung Tv Remote ControlCodes List · Remote Control Codes For Lg Tv Lcd · Universal Remote ...
Dec 18, 2015 | LG Televison & Video
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
Need to use remote to change volume
this aiwa equipment failure is common, is that the contacts within the volume botton causing misreading get dirty when going up or down the volume. you have two options the first is to buy the button or pull it out and clean it is not difficult. bye
Jun 14, 2009 | Aiwa NSX-A999 Shelf System
Need remote code for LG HDTV model 47LG90...
Just bought an LG 32" HDTV and have the new Samsung STB, with a Scientific Remote; the code in the remote manual for LG says to use 1005, but after trying it and many others, I used the "Find Code" set-up (991) and (990) in the remote manual and happened upon 1004 for the LG.
While this worked, the remote is a bit awkward, as you have to enter yet another code (998) in order to control the Power for both the TV and Box with the remote; the good news is that the instructions to do this are pretty straightforward and well presented.
Now, I can turn both TV and Box on/off with power button on remote, can change channels with remote and also vary volume with remote!
Hope this helps
Mar 29, 2009 | Televison & Video
Televison & Video Logo
134 people viewed this question
Computer Repairing
Computer Repairing
