Question about Husqvarna Variable Speed Self Propelled Lawn Mower
Blades keep bending
We bought a husqvarna push mower last summer and never had problems with it. Then this summer after prepping the mower and mowing for about 20 minutes, the blade bent. We weren't sure what caused it so we just bought a replacement blade. Then the same thing happened to the new blade when hitting a SMALL patch of dirt, we bought a better blade and mowed for about 30 mins and it bent AGAIN on a SMALL patch of dirt! What could be causing this? The patches of dirt are the size of an ant hill and should not be bending a blade.
My Husqvarna LGT 2554 deck hung up on high spot mowing. Turned off deck & mower pushed by hand. Engaged deck,started to mow, wound to stop. Belts fine. Pull up on knob to engage, you get nothing.
The engine runs but the blades do not engage? Make sure the wire connecting the electric clutch is still plugged in. If all is connected and the belt is really fine, there is a problem with either the electric clutch or PTO switch.
May 21, 2015 | Husqvarna Garden
Husqvarna lgt24k54 keeps turning off
Interesting! Try seeing if it will run without the fuel tank cap on. There is normally a small hole to let air in as fuel is used, if this gets blocked the fuel will stop running from the tank. You probably won't be able to clean it well enough so a replacement cap shouldn't be too expensive.
Jul 17, 2013 | Husqvarna LGT24K54 54" 24HP Kawasaki Lawn...
Husqvarna 6021p won't start
Make sure spark plug wire is connected and that plug is not blackened and fouled out. Also check your fuel filter (plugged?), the handbar safety lever & it pull cable and make sure it is opening the breather assembly down at the motor or closing the proper switch (unsure of the setup) Those are typically the most common problems. Good Luck
Jun 07, 2012 | Husqvarna 6021P 21-Inch 149cc Kohler XT-6...
Husqvarna clogging problems
make sure your deck is scrapped out after every 8-10 mows, make sure your blades are sharp. I'm assuming you have a bagging system. Make sure you have the correct blades on your mower. Blades need to have a high wing in order to push the debris out correctly and make sure there are no other obstructions in shoot and always run engine at high rpm.
May 13, 2010 | Garden
Deck will not shed the grass . the grass has to be cleaned after each mowing, lawn is not mowed when wet,
The only way to shred the grass while mowing is to have a pair of mulching blades on your mower, they work, but they wear out fast. They do in Florida anyway with all the sand. And don't for the grass to look a hayfield to mow it. You have to keep at it. Hope this helps.
Apr 04, 2010 | Husqvarna Garden
The carb on my mdf lawnmower is flooding is there adj on this type of carb it is 15 years old and has not been run untill this summer , now it does not stay running
I am unsure if this will fix your problem, but I have a MDF riding mower. Last Summer I installed a 1/4 turn shut off valve in the gas line. I keep it off until I want to use the mower, then only open it 1/8th turn. When I'm done mowing, I turn it all the way off and let the mower die so I know the line is empty from it on down. Hope that helps.
Oct 27, 2009 | Mtd 22" Yard Machine Push Mower
Husqvarna 48' 24 hp 2008 riding mower.Engine stops when mower deck is engauged
check under the deck and see if you have something wrapped around the blades and locking them up. Make sure you can turn the blades by hand. I had this happen with some barbed wire on my mower last summer. hope this helps you
Oct 08, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Leaving streaks of grass in middle of mower
Your forward speed may be too fast for the mower blades to cut every blade of grass. It may be new, but check the deck to see if there are any dents pushing the quill assemblies up making the deck cut uneven. Or it may have the wrong blades on it.
I have seen this problem in the past with a Gravely mower. The person was trying to cut grass to fast. He sold the unit and the new onwer did not noticed any the problems the old owner described.
Sep 25, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
48 inch deck problems
a lot of problems here.try this.[grass buildup]. usually cause by damp grass or blades not going fast enough to throw into box.engine cutout is then caused by grass jamming blade[s]. backfire is usually too much choke or wrong petrol/air mixture.re bent grass.try cutting driving in reverse[if strip is wide cos of back tyre then blade is uneven.]
Jul 21, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Husqvarna Variable Speed Self Propelled Lawn Mower Logo
24 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
