Black border on my screen - Computers & Internet
  • 7,627 Answers
Have you changed resolution? Graphics Adapter updates? You didn't post the Make, Model of Laptop or the OS you are using? Have you tried a System Restore to a date before this issue?
Posted on May 08, 2013
Black border around screen
Have you checked to see that you've set the correct resolution for your desktop?
The specifications say that the laptop's display can show 1024x768 pixels.
http://www.toshiba-europe.com/computers/products/notebooks/tecra9000/index.htm
Set it to that first. Anywhere below that resolution (for example 800x600) may be causing black borders on your screen.
Hope this helps!
-BuzzPuppy
Apr 30, 2011 | Toshiba Tecra T9000 Notebook
Well i have a 23 inch LG monitor and im using the recommended resolution of 1920 x 1080 and its not fitting the screen. therers 1 inch black border on tob and bottom and 3/4 inch black border right and...
Dear User,
Good Day!
Please use the auto button in you monitor then it will automatically adjust the resolution of your screen. Please feedback us what happen.
Thank you...
Apr 16, 2011 | Computers & Internet
Remove cover from HP w2408h monitor
pop the roundish 'HP' cover of the back of the stand. Remove the 4 black screws and the stand comes away. The case is just a clamshell affair, the main piece is the rear cover, the LCD front plastic border locks into it. The screen with components mounted is sitting loose in the back cover once the front border is removed. The trick is to pry off the front border without damage. Hook the fingers under the border where it lays against the LCD screen, wiggle, pull, curse and do it again. The top and bottom borders come loose easier than the end borders. Once these are popped free, stand the unit on end between your knees and pry away the end borders. A wide putty knife slipped between the border and metal frame will save your fingers but don't damage the screen. When the front border is off, lay the unit face-up on a table, undo the screws for the control panel and power switch modules, flip it over and lift off the back panel. Everything is under a metal casing.. I had no voltage from the power supply, trying to find a Fairchild chip SG6902SZ on the small control module, P/N ILTR-003, else the Pwr Bd, P/N ILP-004..
Jan 05, 2010 | HP w19 19" LCD Monitor
Screen resolution change = black border around small screen
Once you change the resolution to a smaller size and you see the black border, go into the monitor's menu and there should be settings for the Horizontal and Vertical size/position. Adjust those until it looks correct.
I hope this helps :)
Best Regards,
James
Aug 21, 2009 | Dell Inspiron 8200 Notebook
Website is right screen centered for one given website. want to display it at center screen
The following is an illustration of an entire body element (with a black border for clarification purposes) centered on a page. A width must be set for the element, then the left and right margins are set to auto. Here's how:
body {
width: 80%;
margin-right: auto;
margin-left: auto;
border: 1px solid black;
Try this
Aug 08, 2009 | Computers & Internet
Black borders on either side of creen
Is it a laptop or desktop?
If laptop, check it's not in 4:3 mode Usually pressing the FN and one of the "F-keys" does it. The key will have an image that shows the borders like on your screen.
If it's a desktop, check in your display settings. have you got the resolution set correctly?
May 10, 2009 | Computers & Internet
Sometimes when I change the settings profile from "User" to "Graphics," a black border appears on the screen and some of the viewing window is off the screen. Usually when I click the "Graphics" profile...
All LCD displays have an "Auto" button press it and see if that fixs it. should be aparent what it does if it does it. but basicly it alines the picture with the screen. when you change back to user profile you may need to press it again.
Dec 21, 2008 | Acer AL1916W 19" LCD Monitor
Dell monitor
Monitor Help CH000315, Black borders on side of screen. CH000316, Dead or black pixels. CH000403, Macintosh and/or PC monitor compatibility.
Black borders on side of screen. Additional information about what causes black borders on computer displays.
Good Luck, Please dont for get to Vote/Thank You.
Dec 19, 2007 | Samsung SyncMaster 712N 17" Flat Panel LCD...
C840 resolution difficulties...
The type of screen you have is a UXGA screen. the optimal resolution for that is 1600 x 1200. changing the resolution for that will distort the screen causing black borders. If a computer has a 15.0+" SXGA+ screen with an optimized resolution of 1400x1050 and the screen's current resolution is set to 1280x1024 pixels, the display will shrink resulting in a black border surrounding the edges of the screen. Also, all other lower resolutions may be stretched to fit the screen. No border will be visible, but fonts may appear slightly fuzzy.
Oct 03, 2007 | Dell Inspiron 8200 Latitude C840 Laptop...
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Computers & Internet Logo
14 people viewed this question
David Payne
David Payne
