Question about HP Pavilion Dv9543cl 17" Laptop Lcd Screen
4 duplicate screens
Screen has 4 horizontal screens
    Problem Solver:
  • 7 Answers
You have the wrong driver installed, go to Hp's website here,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&lc=en&product=3439703
Download the driver that matches your operating system and install it, this should fix ya.
Posted on Nov 29, 2013
Picture size
I found the user manual online, and the pictures in it are really helpful and make this make a lot more sense, but:
1. Press [SCREEN MODE], to switch the TV aspect ratio.
2. Press [SCREEN MODE] repeatedly until the normal screen displays.
NOTE: • Some programs may not offer all display mode options.
4:3 Programming
[Sidebar] Sidebar displays a 4:3 picture at its standard 4:3 size. Sidebars will be displayed on the right and left edges of the screen.
[Full] Full displays a 4:3 picture at a 16:9 size, with horizontal elongation necessary to fill the screen.
[Cinema] Cinema displays a 4:3 picture at a 16:9 size, with less horizontal elongation necessary to fill the screen because a little bit of the top and bottom edge of the screen will be cut off.
[Wide] Wide displays the center of the picture as original size and the outer sides of the picture will be elongated. The size of the picture will depend on the original signal.
16:9 Programming
[Full] A picture is displayed at 16:9 size as it is.
[Zoom] Zoom displays a 16:9 picture without changing its horizontal and vertical ratio, at its maximum size.
[Cinema] Cinema displays a 16:9 picture with vertical elongation.
[Expand] Expand displays a 16:9 picture with horizontal elongation
Source: LC320EM8 User Manual
http://www.manualslib.com/manual/47021/Emerson-Lc320em8.html?page=21#manual
May 15, 2013 | Emerson LC320EM8 32 in. LCD TV
Has 4 duplicate screens could this be a memory issue
It would be helpful if we knew the Make and Model of laptop. When you say' "Has 4 duplicate screens", do you mean your Desktop is quartered into 4 versions of your desktop? If so, right click on a open spot on the Desktop, select Personalize, select Desktop Background, select FILL.
May 08, 2013 | Computers & Internet
Why does the screen have 4 horizontal duplicates
It would be helpful if we knew the Make, Model of Laptop and the OS you are using. If you connect it to a external monitor is it the same? If you boot to safe mode is it the same? Have you done ANY updates to the Graphics Adapter? Have you tried a System Restore to a date before this issue? Has there been ANY damage? Drop? Have you cleaned the Fan, Vents, and heatsink? Has the Laptop been overheating?
Screen split in half horizontally and duplicated
You didn't supply the make , model of laptop or the OS you are using? Has there been any damage? Dropped? Open Control Panel, Display adapter, Uninstall the Graphics adapter, reboot. Allow the Windows OS to apply the generic driver. post results with info.
Jan 27, 2013 | Computers & Internet
Desktop screen is 3/4 size and shifted to the left
Check out the monitor settings. You need to see the settings and see what size it's set at.
Sep 06, 2012 | Acer Aspire One PC Notebook
The display of my phone is working but for last 2 days , there are 3 -4 horizontal lines . i dnt knw the reason . i evn tried factory settings but of no use . please provide me with necessary remedy for...
Hi, possible causes for horizontal line on screen are,
Phone Screen problem and,
The flex of a phone.
When a screen displays horizontal lines on the screen, is when screen of the phone is getting damaged due to phone falling on the ground,or hitting phone on an object can cause horizontal line on a screen.
Solution to this problem is to replace the screen of the phone.
The flex of the phone can also cause horizontal lines on a screen. The flex is a thread like object inside the phone that makes the phone to function properly in terms of the display..
When the flex is getting damaged, it can cause such horizontal line on the screen display.
Solution for this problem,is to replace the flex.
Note : flex can be found only on slide phones.
Thanks for using fixya........
Sep 15, 2010 | Nokia BH500 Bluetooth Headset For N95 8GB...
Ps 27123 have sound, tuning etc only small horizontal color band
Hello bdedrick708,
If what you are trying to say is that you have a 1/4 inch horizontal line across your screen, this means that something in your vertical deflection circuit has failed. This could be the vertical oscillator, the vertical output processor, the vertical coupling capacitor, or the vertical section of the yoke transformer.
If what you are talking about is a vertical line from top to bottom then you are possibly talking about a failed horizontal section of the yoke transformer.
Why so little about the horizontal section of the yoke? That is because if the horizontal section fails completely then you would lose high voltage and no line would be present because you would not have raster (screen light).
In any even check the yoke transformer first. Then work back from there.
I hope this helps,
Thank you,
Shuttle83
llc.com/">http://www.electron-age-technologies-llc.com
Feb 07, 2009 | Proscan PS27123 TV
Picture on 42HDX82 vertically stretchs after about 10 mins
Sounds like a bad cap, spray some freeze around till you can duplicate the problem.
Oct 22, 2007 | Toshiba 42HDX82 42" Rear Projection...
32 in RCA MODEL NUMBER f32650
TV FINE UNTIL 2 NIGHTS AGO HAVE HAD 4 YEARS, STARTED HAVING A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. HAS SOUND A FOGGY SCREEN WITH WHITE HORIZONTAL LINES. called retrace lines please check 1 screen control on eht transformer is mituned 2 supply to screen of crt 3 supply to rgb video output is absent 4 connector loose 5 crt base loose thanks
Sep 11, 2007 | RCA F32650 32" TV
HP Pavilion Dv9543cl 17" Laptop Lcd Screen Logo
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
