Question about HP Computers & Internet
Spacebar problems When I login to w g t golf, my space bar will not work. It works ok in all other app.
  • HP Master
  • 3,799 Answers
RE-install the game.
Posted on May 08, 2013
The spacebar on my laptop doesn't always leave spaces between words, what is wrong with it?
Inside the key, there is a metal bar the makes the spacebar key depress from anywhere you press it. Either this bar as unclipped from its hinges or they have broken.
Jul 06, 2014 | Toshiba Satellite A100-S8111TD Notebook
Wired and onscreen keyboard space bar doesnt work
Keyboards are cheap. If you need to use this one then you will need to carefully pop the spacebar key out, turn the keyboard upside down and give it a good shake. You will see a ton of junk fall out ;)
Mar 08, 2014 | Computers & Internet
Samsung netbook N130 spacebar not working
manually pull up and remove the space bar, see if you can reconnect this. Check that something isn't caught beneath. like crumbs or
simply disconnected or not properly connected. Then re attach the space bar. Don't break it in half. inform me.
Sep 16, 2012 | Samsung NP-N130-JA01US Netbook
The far right and left ends of the spacebar do not work. In order to use the spacebar function, the direct middle of the button has to be pushed down.
You need to reposition (clip) the torssion bar under the spacebar key (a steel wire formed in a wide U shape), it is unhooked, call for a professionnal if you'r not sure how to do this as you may brake the plastic hinge if you don't know what you'r dooing...
Aug 09, 2011 | Toshiba 310CDT Keyboard
When keyboard comes up on IPad, the space bar is missing. I know that it was there at first. How do I get it back?
What app are you in? The iPad's software keyboard is not always the same - it changes depending on what context you're in. For example, it will remove the space bar and display web symbols when typing a URL (web address).
Feb 14, 2011 | Apple iPad (16 GB) WiFi Tablet PC
I have a IBM WW 1500 all the keyboard works but the spacebar, is this the function or keyboard or possible homming sensor failure?
If everything wirks but the space bar you probably have a keyboard problem. If someone had the space bar off it may not be properly installed. You can pop the space bar off and look for debris under it.
DickyO
Dec 02, 2010 | IBM Office Equipment & Supplies
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Sidekick lx spacebar
Go to:
http://www.fixmysidekick.com/sidekick-lx-or-sidekick-2008-space-bar-not-working/164/
Or just read this...:
sidekick2008spacebarpicture.jpgIs the space bar on your Sidekick LX not working when you are trying to text or in AIM? Do you have thesame space bar button problem on your T-mobile Sidekick 2008? Does the Sidekick spacebar work in other apps though?
If so then this fix is for you.
1. Open the AutoText & Spelling screen. From the Jump screen, press the MENU button, then select Settings > AutoText & Spelling.
2. Uncheck the following settings:
    • Highlight misspelled words
    • Auto correct spelling
3. Exit out of the settings screen and try it out.
Hopefully, this will have solved your issue.
How to check for misspelled words with these two options unchecked?
Run a manual spell check on T-mobile Sidekick: To run a spell check while in a text field from any Edit Text submenu, or by using the keyboard shortcut by pressing MENU +S.
Dec 19, 2008 | Sharp Sidekick LX Smartphone
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Computers & Internet Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
