Question about Olevia LT42HVi 42 in. LCD Television
Volume on tv not work
When I turned on tv there was no volume not even when I push the volume button
    Top Expert:
  • Olevia Master
  • 75,462 Answers
If there is no sound to TV, check its speker first. If is is found OK, check and replace the audio output card.
Posted on May 08, 2013
  • Ronald Gugel
    Ronald Gugel May 18, 2014
    when the tv is first turned on it has volume. it starts of with 20 on the volume scale, and goes down to 0 by itself, and the scale wont go away, and none of the buttons on the front of the tv work,. I have to unplug the tv to turn it off.
  • Ronald Gugel
    Ronald Gugel May 19, 2014
    I replaced the button control board and that did not fix it.
Bush lcd42f1080p100hz remote will not turn tv on
I had come home about a week ago and pushed the power button from my remote but my tv did not respond. So I just went to the front panel and pushed power but once the tv turned on, the volume was on full blast! I used the front panel volume decrease to get the volume down, but when I stopped pushing the button, the tv increased its volume to full blast again by itself! Naturally I just turned the tv off for a few moments. I tried the remote again, no response again, so I used the panel power button. The tv volume was still full blast when it turned on but after I decreased the volume it stayed this time. The picture is and has been perfectly fine and the tv was working fine. The next day the problem started all over and now once we turned it off from frustration of having to manually use the panel to change channels, it now will not turn on at all. I have changed batteries from my remote, reprogrammed my remote, pushed system reset several times, unplugged it for a while, bought a new surge charge, and even held the menu and device panel buttons for 10 sec and tried to turn the t.v. on again! What other options do I have or what may be the issue at hand and possible parts that may need to be replaced?? Thanks!!
Nov 02, 2012 | Televison & Video
My tv turns on an off, and the picture and sound works fine. The problem I am having, is that no matter what button you push on the remote, or the tv itself, it just brings up the input. You could hit...
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish manual functions controls board that have like buttons POWER,Channels + -,Volume + -,MENU.This manual functions controls board it is shorted.
May 21, 2011 | Element Electronics ELCHW261 26 in. TV
Samsung 40 hd tv the vol will not come down from 100 percent . I try to turn the vol down and it will not turn down. what can I do. tks mike
I presume that the volume will not turn down from either the remote control or the volume buttons on the side of the tv. If the volume down button works on the side of the tv then the remote control is suspect to be faulty. If neither remote or tv volume buttons work then check whether the channel buttons work on the tv (not remote). If none of these work then check the input connection from the buttons /infra red reciver to the main pcb. This is a push on cable connector. As a point, also check that the volume up button on the tv is not stuck in, and feels the same as the other buttons when pressed.
Apr 24, 2010 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
OLDER 32" TV WON'T TURN ON/KEEPS TURNING OFF
re solder your tv,if its not works, check the horizontal output transistor
Oct 01, 2008 | Samsung DLP HL-P5663W 56" TV
Philips tv demo
Try holding the volume up and channel down buttons on the set at the same time. Give me the model # if that doesn't work.
Jan 17, 2008 | Philips 32PT6441/37 32" TV
Tv not responding to remote and now will not turn back on!
if the remote eye on the tv it will do all kinds of strange stuff once the eye on tv gets dirty the the tv will shut off after 2 seconds try cleaning it and see what happens the eye on tv is hard toget to so get a can of air to blow it out i took my pocket knife to clean mine i know that was ruff on eye but thats all i had if this dont work try unpluging your control board on front of set board may be bad or buttons are stuck email me at rjp5765@msn.com if this helps
Nov 01, 2007 | Mitsubishi WS-55613 55" Rear Projection...
RCA F31317 Model - Very strange problems
Sounds to me like there is an issue in the control circuit, and quite possibly the micro itself. If you have issue with both the remote and buttons I am thinking a microprocessor issue since they normally enter the micro at different locations and therefore would not have a single component cause a failure across both of them (Except the micro of course) Best option may be a service center.
Jun 18, 2007 | RCA F31317 31" TV
Volume keeps going up by itself
help the volume on my tv keeps going up and no one is touching it! please help. my parents cannot afford a new tv
Mar 29, 2006 | Apex Digital PF2025 20" TV
Olevia LT42HVi 42 in. LCD Television Logo
120 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
