Question about Westinghouse 24" Class 1080p 60hz LED LCD HDTV - Black LD-2480
Set sleep timer tv
Cant figure out where to set sleep timer
    Top Expert:
  • Westinghouse Master
  • 74,118 Answers
Refer its user manual for details. If you do not have the user manual, check this link to download it. http://www.retrevo.com
Posted on May 08, 2013
TURNS OFF AFTER 12 MINS. SLEEP IS SET AT OFF
In addition to a Sleep Timer, many TVs have an Off Timer, too. Check for other automatic settings and timer settings. If you use the TV as a monitor for a computer, the sleep setting on the computer might affect the operation of the TV.
Apr 28, 2015 | Televison & Video
Tv keeps turning off by itself using auto shutdown function how do i turn it off
Check if the sleep timer is on. Go to settings and check under timer and check the sleep timer if it's on/off.
Sep 24, 2012 | Emerson Televison & Video
Why does my tv turn off automaticly
Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. M Some tvs have a sleep timer on it and if it is accidently programmed the tv will turn off at a certain time. You may want to look at the users manual for more info. Or call a local place that fixs tv's for some more input before paying someone or getting a new tv. I had a tv once and it did the same think. I had to get into the menu with the remote and figure it out it had something to do with a set sleep timer so the tv would shut off at a certain time if the timer was set. It sucks if you dont have a remote though hopefully you do. Good luck. Malena!!
May 10, 2012 | Vizio Televison & Video
How do I set the sleep timer? We got the tv from a friend and it had no manuel.
Programming the Sleep Timer:
  1. Press and release the TV key.
  2. Press and hold the SLEEP key for three seconds. The illuminated component name turns on.
  3. Release the SLEEP key.
  4. Using the number keys, enter the desired time in minutes (from 1-99 minutes). To set the timer to an umber under 10 minutes, first press 0 and then the desired number (e.g.,05 for five minutes). The illuminated component name blinks with each key press.
  5. Once the second number is entered,the illuminated component name turns off.
    Tip Any key press other than the number keys is ignored. If you don't enter the sleep time within 10 seconds after pressing the SLEEP key, you must start over at step 1. The illuminated component name blinks four times and then turns off, indicating your attempt to program the Sleep Timer has been unsuccessful.
  6. The Sleep Timer is now set.
  7. Leave remote aimed at the TV. Once the Sleep Timer is set, you can continue to use the remote without affecting the Sleep Timer. However, because the timing mechanism for the Sleep Timer is built into the remote itself, the remote must be in TV Mode and pointed at the TV to activate the Sleep Timer.
    Note: If the ON·OFF key is pressed, the Sleep Timer is canceled.
Aug 19, 2011 | RCA Rcr461 Remote Control
I can't figure out how to set the sleep timer and i have no manual
On the remote there is a button called sleep. Every time you press it the time will increase in half an hour increments. Eg: Press it four times and the display will show 120, which means the TV will switch off after 120 minutes.
Mar 08, 2011 | Sansui 27" TV
How do I use the sleep timer? when I push the sleep timer button it gives me on time and off time to set. I dont know how to use this. Cant I just set sleep timer for 30 minutes to turn off? Thank you.
Hello
Before going to set the timer, you have to set the current time. Set it according to the manual with you. If the timer function work properly, there must be an uninerrupted power supply also. If the power goes off, the set time will also get resetted, and improper function will occur.
After setting the present time, set the "on" time and "Off" time. The TV will switch on at that time you set, and will switch off automatically after the end time. OK.
Dec 23, 2010 | RCA 20F420T 20" TV
Can't set sleep timer on my mitsubishi cs-40505 tv. I do not have the original remote. How can I set the sleep timer?
U can't do it without the original remote.Go in the tv menu by the manual button control might could set the sleep timer.This is a extra option on most tvs.
Jun 07, 2010 | Mitsubishi CS-40505 TV
Olevia TV Remote doesnt work Sleep Timer
The TV is in 'showroom mode'. To fix: Click: Menu --> Picture --> Mode --> Power up then select: Home. Then click menu until you exit the settings. You will now be able to use the sleep timer.
Mar 10, 2009 | Bose Cinemate Digital Home Theater System...
Magnavox lcd tv
Setting the Sleep Timer sleeptimer.gif The sleep timer allows your LCD TV to automatically turn OFF after a given amount of time. You can set the sleep timer using your remote control or through the onscreen display (OSD).
TO SET THE SLEEP TIMER USING THE REMOTE CONTROL
1. Press the SLEEP button on the remote control. The sleep timer appears at
the top of your screen.
2. Press the SLEEP button one or more times to select the time you want.
3. Press the EXIT button to hide the sleep timer display. Your sleep timer is now running in the background. The sleep timer will be hidden after 10 seconds.
Turning On the LCD TV.
1. Press the MAIN POWER switch in the back of the unit (see Back Connectors for location). The Status LED on the front turns orange
and your LCD TV is ready to turn on.
2. Press the POWER button on the front of your LCD TV or on your
remote control. The Status LED on the front turns green.moz-screenshot-6.jpgmoz-screenshot-5.jpg
Dec 18, 2007 | Televison & Video
Westinghouse 24" Class 1080p 60hz LED LCD HDTV - Black LD-2480 Logo
172 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
