Question about Health & Beauty
How to fix split ends
Without cutting!
    New Friend:
Hey, try hydrogen p
it clears splits and breaks
mix it w/ water and conditoner
Posted on May 08, 2013
Can you fix broken hose connection without buying whole hose?
are you talking garden hose or what?
if a garden hose ,just cut the end off and get fittings from your local hardware shop
Nov 22, 2015 | Cars & Trucks
Where can I purchase a garden line fuel line for a 2stroke blower vac
take old line off and go to hardware store they will replace it with the same size line
Jan 20, 2015 | Garden
How fix a gas line break at gas tank?
Using needle nose pliers slip the split line off the connection and pull out of the gas tank. If there is a filter on the end you need to extract through the gas cap opening. Purchase another gas line either in a repair kit or individual line and cut to fit. If the filter is bad, use a new kit. Insert through the gas cap opening and pull up through the supply line opening. Be sure the connection is clean then slip the new line onto the clean connection.
Sep 12, 2014 | Craftsman WeedWacker Gas Trimmer 29cc...
Broken wire harness
you can split the wire case. cut out the split wire/s and put a new wire in. make sure you cut out upto 3 inches either side of the split. best to solder new wire to old wire's . sand down the new solderd parts so there are no sharp edges and tape over them with installation tape. re tape up the harness and job done. if on doors you will need to un clip the harnes at both ends.
Sep 14, 2013 | Cars & Trucks
How to take off the top ball joint nut with an open end wrench without stripping the nut?
Usual method,Pull the cotter pin and use 2 open end wrenches,on top of each other to increase the contact area and pull slowly.The nut should come off.
2nd method,use a sharp air chisel and split the nut apart.
3rd method,shield the CV boot and heat the nut or cut it off flush with a torch.
4th method,freeze the nut with 134a and then remove it with the 2 wrenches.
5th method,Cut across it at an angle with an air cut off tool
down to the ball joint threads to release the nut pressure then remove it with one wrench.
Do you need more methods?
Apr 26, 2017 | 1996 Nissan Maxima
How do I take an axle boot off
you mean the cv joint boot? It has to be removed from the car first. then its easy: held on by metal clamps, one on the small end of boot around the half axle, and one on the big end of boot around cv housing. Are you replacing the boot? then just cut the metal clamp with snips or a hacksaw. If you are trying to replace boot with it on the car (like those replacement boots that are split and use a glue to seal the split after wrapping it around the axle-really only a temporary fix, and not recommended cause they often don't hold up), anyway just cut the clamps. Be advised that cv clamps require a special tool to tighten them properly. Of course once you get the boot on, you could take it to a shop to have the clamps set properly.
Oct 07, 2011 | 1998 Ford Escort
I have an Electrolux split air-con, have no manual, want to just have fan on without the air on ,do I fix it no DRY Mode regards
Fan mode only, you can control low/med/high speed. In dry mode with low fan, it cut in and off air-con for five minutes frequently.
Jan 04, 2011 | Heating & Cooling
Same thing wrong with ours leaking out the black plug
Make sure the hose is clamped on tightly and not split, cracked or chiped. Meaning remove it and inspect every milimeter of it in good light if it is bad anywere cut off the bad end or replace entirely.
If split on end of hose just cut off the part that is bad, not more then you need too. Then reattach the hose tightly..
IF leaking from the plug use a little bit of silicon rubber sealent from autoparts or hardware store. use spareingly around plug after plug is removed reinsert the plug.
Sep 19, 2009 | Everstar Portable Heater/Fan
Landrover discovery Td300 1998
the rev counter on the 300tdi disco takes its speed signal from a wire connected to the back of the alternator (single spade type connector) this wire usually breaks rewire and should be ok
cruise faults are usually caused by a vacuum pipe splitting check all the vac pipes to the cruise control actuator in the engine bay and at the brake pedal switch of end are split cut off and refit pipe
May 01, 2009 | 1998 Land Rover Discovery
Health & Beauty Logo
50 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
