Ar answers for heat by mike lupica
AR or accelarated reader please help
sir fixalot
  • 146 Answers
SOURCE: Sharp ar-163 model Error code F1
You can hold down the start key when the F1 is displayed it will show a sub code. The service manual for that model shows only one F1 code which is an F1-06. That is a shifter motor trouble. That is the section after the exit that offsets the copies.
You can reset the code with the instructions below. If the error recurrs then chech the exit section shidter for proper movement. You may require an on site technician to remedy this issue.
To reset the error code:
Hit <clear> <interrupt> <0> <interrupt>
14 <start>
Posted on Jan 06, 2008
Marioland
  • 23 Answers
SOURCE: My ar is broken!
IF it freezes the instant the DS swiches on, then your Action Replay is Bricked.
Don't worry though, there is a way to Unbrick it. You'll need a flashcard and a pc with internet.
Posted on Jun 16, 2008
  • 4 Answers
SOURCE: How can I get a meter reading from an AR-M237?
press and hold the the button that says "copy" on it next to the screen, the meter should show on the screen
Posted on Dec 05, 2008
bobotfel
  • 236 Answers
SOURCE: replace remote control unit model ar-fb2
If your remote control have display but cannot transmit signal to the unit. Confirm first if the remote is really the problem, using your camera or cellphone camera as your eyes point the remote transmitter to your camera and "on" the remote. You should see light emits in your remote control, if no emitted light then the remote control is defective. But if there is a light the defect is in the unit receiver.
Check also if there is a reset or rst button in your remote control and reset it and try.
Check also if there are error codes in the unit, reset the unit by disconnecting the power supply in the unit for 10 sec. and "on" again and try.
The unit can be operate without remote control, use the manual button located in the unit.
If the remote control have no display replacement of remote is recommended.
Posted on Jan 16, 2009
micromatikal
  • 2777 Answers
SOURCE: white screen on my ar
Sounds like the AR may not be compatible with the DS or has died... Is this a regular DS or DSi?
Posted on Jun 24, 2009
Sharp ar 5516 maintenance reset
sharp ar 5516 showing ( - - - ) what's the solution
Sep 02, 2012 | Sharp AR-5316 Advanced Digital Imager...
The printer Ar-5516 is showing H4 error
this error means:
heat roller abnormally low temperature.
for check:
1- check the heater lamp
2- check the thermistor
for reset:
clear key --> interrupt key --> "0" key --> interrupt key --> 14 --> start key
Jul 04, 2012 | Sharp AR-5316 Advanced Digital Imager...
I have a problem about my ar-5320 copier i just replace the toner but suddenly its indicate f2 what is that means....i need your help.
Mr Mike: this problem occur wen you use different type of cartridge , replace the cartridge.
or you can replace the new toner chip by your old one.
Jan 02, 2011 | Sharp AR-5320 Black and White Copier
My ar won,t read my games anymore
Maybe you've just used it's last use. AR Readers never liked to cooperate with me when I wanted them to though. I always tried to get them to work but either it wouldn't read or the games would freeze before I got a chance to save. AR Readers are not supported by nintendo so they arn't always the best. The best I can tell you is that if oyu have a can of air, spray it out. There might be something in the slot. you didn't specify if this was a game you'd used it on before or not though. If it was a realitively newer game for you, then you should update your AR and try again. I believe that is possible by hooking your computer up to your AR. I'm not sure if any drivers are required for that or if it does it automatically. If worse comes to worst, AR readers arn't that expensive if your useing a gameboy one. Maybe 5-10 bucks. Ebay maybe. If it's DS then it'll run you 20 bucks but that investment is up to you. I hope your AR Reader starts to work again. :)
Jul 07, 2009 | Nintendo Action Replay DS for DS and NDS...
Action Replay freezing and not reading.
This is one of those sucky problems that I don't really know how to fix but I do know kinda what to do. For me it's probably just lucky but I turn off my DS. Leave it be for a while. Make sure everything is cleaned out well. No grim or crud in there. Slowly put in back in, don't scape anything with it. Insert the game before putting the AR Reader into the DS. I always have my DS set to not read automatically though. If it doesn't load now then try again a few more times. You may need to inves tin a new AR Reader though.
(Btw, it's okay to cheat on games every now and then. I wouldn't make it a habit though. It gets adictive and sometimes the game gets boring way too fast. I never use the AR Reader until after I've beaten the game.)
Jul 07, 2009 | Datel Action Replay for Nintendo DS
Action replay problem
Your AR Cartridge probably needs a cleaning. Use some rubbing alcohol and a q-tip and rub it on the pins of the AR Cartridge. Then use a dry q-tip to dry the rubbing alchohol. If that doesn't work then you should probably buy a new AR.
Mar 01, 2009 | Nintendo DS Lite Console
Sharp AR-M201
no. i cant print. its showing red light and user guide attention
Jan 14, 2009 | Sharp AR-5316 Advanced Digital Imager...
Computers & Internet Logo
David Payne
David Payne
