Question about Garden
What year was an Ariens 902804 (005001) RT320 3hp 20" Front Tine Tiller manufactured
steve_lima
  • 181 Answers
SOURCE: what type of lube is used in 917-294261 tiller gearbox?
80-90 gear lube
Posted on Jan 09, 2009
SOURCE: Manual needed
Hello;
You might want to try the web site "ManageMyHome.com".
That's where I found my manual for my tiller.
Hope this helps you.
Jeff
Posted on Apr 04, 2009
SOURCE: Ariens rear tine tiller. What direction are the
The tines should turn counter clockwise or from the ground up toward the tiller not toward you .Owners manuals can be obtained from a local dealer on most often on line..
Posted on Apr 09, 2009
Typus
  • 69 Answers
SOURCE: Roper tiller 26 inch front tine Pulley/belt diagram
I am not sure either, but I think that it would be alot cheeper to buy a new tiller, than to use your strenght fixing a old tiller that you didn't bother to keep the instructions for (no, I am not trying to be harsh. I am trying to be nice. and I am not sure about it coming with instructions, they usually do.)
29259605.jpgSorry, that is the closest picture that I can get.
Here is a link that may help. (IDK, because it is blocked where I am at.) http://www.google.com/aclk?sa=l&ai=CqcKEPGEMSvvXJJyotgeEiOyLB_jqoUWYtdrOBMib0rsYEAMoB1DU-N7X_P____8BYMmOo4qkpMQRoAGUt9H9A8gBAaoEIU_Q6ppHU85NtRLlGbCSz8M4YQ7k6yZkGAMPo_XJ9i4rSQ&num=3&sig=AGiWqtyvlB5FasgaU109ezFuPnc-65WzHg&q=http://www.fixya.com/support/roper%3Fcmpid%3DG3372595023
Posted on May 14, 2009
  • 10865 Answers
SOURCE: rear tiller won't go into gear.belt needs replacing
find your model number from the list on this link and click to get your manual
http://www.managemyhome.com/mmh/owner_manuals/search?query=Craftsman+rear+tine+tiller
Posted on May 20, 2009
How do I adjust the carburetor on an Ariens 5020 tiller, model #901016, with a 5 HP Tecumseh engine?
close the needle valve completely, then back it off 1.5 turns. Adjust from there for most efficient fuel usage.
May 04, 2015 | Ariens Rear Tine Tiller 17 901028
2 year old gas in tank. tiller won't stay running
When you drained the gas from the gas tank did you also take the carb apart and clean it. There should be a bowl that the fuel line from the gas tank goes to. There is a float in that bowl that has to go up and down to regulate how much gas goes into the engine. You may have a build up of varnish from old gas on the piece that the float moves up and down. Also there should be an idle jet that you screw in and out to adjust the idle. That also could be junked up.
Apr 18, 2013 | Ariens 902032 - 12"/22"/24" 6HP/169cc...
I have a Ariens tiller model #901001. The rear
YOUR PROBABLY HAVE A GEAR CHEWED UP?CONTACT CHOOCHOOPARTS.COM FOR DIAGRAM? DID YOU CHECK OIL...IF OUT OF OIL IN REAR TINE TRANSM ...YOU CHEWED UP THE BRASS GEAR ....I REBUILT MY MAIN TRANSM...EASY TO WORK ON...AWESOME MACHINES.
May 04, 2010 | Garden
Apr 09, 2009 | Ariens Garden
Broken clutch cable connector, MTD Tiller
I found micro fiche on jackssmallengines.com . Click on the manufacturer's tab at the top of the page then you'll have the option to use an off-site tool to locate your machine. I used it and found my 1990 mtd rear tine tiller. I needed the cable that engages the tines - maybe the same as you. The part number for my 1990 model's cable was 746-0535. Dont know if it was still the same in 96 to 98. But look at the fiche and see.
Apr 04, 2009 | Mtd Products Yard Machines 158CC Tiller
Manual needed
Hello;
Jeff
Apr 03, 2009 | Garden
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
