Question about Amana Refrigerators
My side by side refrigerator's fridge side is not cold but the freezer is fine.
My Amana refrigerator used to partially freeze items in the fridge on A COLD SETTING OF 3. lAST WEEK i NOTICED THAT OUR MILK IS BARELY COLD ENOUGH TO NOT SPOIL. sO i TURNED THE COLD UP TO 7 and its not getting any colder. The freezer side is working just fine.
  • Amana Master
  • 4,655 Answers
My side by side refrigerator's fridge side is  - b583e4b9-797f-4253-9fec-f4da3eedb27e.jpg
What is your model number? Thanks Sea Breeze
Posted on May 10, 2013
heatman101
  • 43501 Answers
SOURCE: Freezer & refrigerator are not getting cold.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r4588788-refrigerator_or_freezer_not_cooling_or
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Apr 25, 2010
  • 1462 Answers
SOURCE: Amana neither fridge nor freezer getting cold enough
the defrost system has failed. to get it working temporarily, take the back panel off inside the freezer. melt ice off with a hairdryer.
after that, fault can be in several areas - defrost heater, thermal fuse or the main pcb
Posted on Jun 30, 2008
  • 19 Answers
SOURCE: my freezers works but my refrigerator
make sure all your fans are turning. maybe try to remove the knobs and see if you can turn them without the knobs, possibly they could be stripped.
Posted on Apr 22, 2009
blueextc3221
  • 15935 Answers
SOURCE: Freezer does not freeze fast enough, icecream gets soft
Faulty Cold control (Temperature Control)
The cold control is a temperature actuated switch and should open when the set temperature has been achieved. If the control does not open and turn the compressor off, it will continue to run and all items in the fresh food section will begin to freeze.
If the control is not closing, the compressor and all fans will cease to operate. Check the control for continuity.
This is usually not a do it your selfer.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Apr 25, 2009
  • 14 Answers
SOURCE: Refrigerator not getting cold in Fridge side
No. check this post from right here.
http://www.fixya.com/support/t245665-samsung_rs2556_refrigerator_side_not
Question: was the fridge running when you went to pick it up ?
Was it already on ?
My thinking is that you have the ice build up problem too and that it never thawed. If you unplug it, thawing could take days. Seriously. If you take the inside panel off and get some heat on it
only an hour or so.
You have the exact same model I do, and it works good, just designed poorly. It needs a drain hole on that condensor.
And your fan probably is fine. Do not spend $500.
Posted on May 08, 2009
Amana sx22sw
There could be a problem with the cold control. It is a common failure item
Jun 28, 2013 | Amana Refrigerators
Amana fridge is not cold but freezer is working
If freezer is ok and cooling ( 5 degrees or less) one thing you might want to check is that the flow of cold air to refrigerator is not obstructed by the items in your freezer. The ductwork has to be available. Also check the opening of the damper if fridge is not cold enough. And is the fan operating at full speed - are the bearings dirty and slowing it down?
Also check your freezer temp - there are degrees of freezing. Water freezes at 32 degrees but a good freezer should go down to about zero. And the colder your freezer air is the colder your fridge will be.
Sep 21, 2017 | Refrigerators
Its defrost problem, the freezer should cool, then freeze, then defrost cycle should start. In your case freezer is cooling, then freezing, but its not defrosting. That's why fridge section is not cooling.-------
Click this link below and follow the troubleshooting:----
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
This will help.Thanks.Helpmech/.
Oct 26, 2011 | Amana ABB1927DE Bottom Freezer...
Freezer and fridge cooling but freezer not freezing and fridge not cold enough
Their are a couple things that could be causing that.
The conderser coils under the kickplate below the doors is clogged with dust. Remove the kickplate and check/clean using a refrigerator coil brush that could be purchased from your local hardware store (Lowe's HomeDepot Ace hardware)
The condenser fan motor behind the refrig., behind the lower service plate directly next to the compressor isn't running and needs to be replaced.
Good luck,i hope this helps you to get your refrig back to cold,
Gene
Aug 13, 2011 | Amana ARS266ZB Side by Side Refrigerator
I have an amana bottom freeze abb2227dew the freezer is working fine but the frige isn't cold?
check the regulator or thermostat for the fridge and set it well.
if it is well set then your compressor is losing compression.
May 11, 2011 | Amana ABB2227DE Bottom Freezer...
Put in garage now unit will not keep cold or freeze.
Since refrigerators were designed to run in your 72° kitchen, when you put a fridge outside, where its colder than normal operating REFRIGERATOR temperatures, i.e. 35-40°F, because that ambient temp is colder than fridge temp, the thermostat in the fridge section reads it as normal temperature, and does not turn unit on. it does not read what the freezer temp is. You have a couple of choices: bring the unit inside, heat your garage, or only use it for pop and beer in the summer. You can reply here or send me a question from my website: www.FixMyFridge.net
Mar 15, 2010 | Refrigerators
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Freezer not freezing
It sound like you may be having defrost issues,Check to see if you have a build up of ice on the inside rear wall of the freezer.If so,You will need to have the defrost timer,defrost element,and the defrost thermostat checked.
Please rate this.
Dec 27, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana fridge freezer
Replace your thermostat, aka cold control.
Jun 13, 2008 | Amana SXD524VW Side by Side Refrigerator
Refrigerators Logo
376 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
