Question about Tama HP910LWS Speed Cobra Double Bass Drum Pedal
Manual I purchased a slightly used Tama Speed Cobra double bass pedal on ebay. Opened it up, put it together, and gave it a trial run. No problem. THEN - I took it to a gig, and the little rubber thing on the right side of the connecting rod came off and I couldn't put it together! Good thing I took a spare single pedal, which got me through the night. I was under extreme time pressure, and this was a horrible experience and a frustrating way to play thru the night. Can anyone direct me to somewhere that I can find SPECIFIC information on assembling the connecting pedal? i.e. do springs go on first, or second? which way does the little rubber thing face? etc. Thanks! Frank in NM
2 Suggested Answers
criss_michae
  • 63 Answers
SOURCE: i need a diagram for putting my tama iron cobra
It may not be a diagram, but sometimes, videos work wonders!!!
Here's how to put it together.
Hope that helps!
Posted on Feb 12, 2011
I have a gallien kreuger backline 600 bass amp head . and I'm wondering how to use the effects loop send and return jacks with a pedal or processor ?
Run a cable from the Send to the effects and a cable from the effects to the Return. This would be in place of running a cable from the bass guitar to the effects to the amp input.
Nov 30, 2015 | Bass Music
Im having problems attaching my Gibraltar Intruder Direct-Drive Double Bass Drum Pedal  to the bass drum
Does it hit the drumhead?
I guess you need to read the instruction manual, because double pedals usually have special way of attaching and tightening mechanism because it's larger.
Mar 03, 2014 | Gibraltar Intruder Direct Drive Double...
Hooking up two amps together
Yes. There could be big issues depending on how you want to "hook" them together. If you are wanting to simply run them at the same time (play through both at once) you can get a cheap signal splitter from GC or Radioshack and run your bass to the input, then output 1 and 2 to the respective amps. That is your best bet.
Setting up two amps parrallel does not nessesarily add power. That is to say that your 150 and your 350 "hooked" together does not give you 500 watts. In addition, there may be some issues with running a powered signal from the first amp into an input that is not designed for powered signals. Try the splitter or an old fashioned AB box. Safe and a cool trick. You can also use a stereo chorus pedal and let the signal chorus between amps. Makes the bass sound huge! Try it and good luck.
Jun 17, 2013 | Fender Music
Alesis dm6 bass pedal
There's a tiny switch on the back of the module "kick type" try switching that
Sep 22, 2012 | Alesis DM6 Electronic Drum Set
Hi. I have bought a Behringer Bass Synth BSY600 and a Boss FV-300L Volume / Expression pedal. Both work on their own but i can't get the Expression pedal to work with the Bass synth. The expression...
The FV300l WILL NOT work tying it into the EXP of the BSY600. What you need to do is to run your guitar into the IN of the BSY600 and use TWO audio cables from the BSY600 output, the OUT and the DIR out and run those into the two IN's of the FV-300L. Then use whichever function by connecting the two OUT''s of the FV-300L to two channels of the mixer or a two channel amp so you could proportion the BSY600's effects as desired. You could also just use whichever out from the FV-300L you want which originates in the BSY600. The BSY600 is made to use an expression pedal that is a single TRS plug which is simpler, but you can use your FV-300L as I have described just as well, it just can't use the EXP input of the BSY600.
Jun 22, 2011 | Behringer BSY600 Bass Synthesizer Ultimate...
My speed cobra double pedal has alwyas been fine but i think i must of set it up wrong or maybe damaged it because now the slave pedal beater won't touch the bass drum head, it's like a couple of cm's...
There are MANY adjustments and some may have slipped. The clamp of the beater to the shaft would be the most suspect. At each of the universals there is the possibility for loose setscrews. Also see if the chain on the slave could have SLIPPED one cog !!!
Feb 27, 2011 | Tama HP910LWS Speed Cobra Double Bass Drum...
Hello Tech, I beg your wisdom. My keyboardist and I love the Yamaha S80 but are stumped with an operational problem. The club blues internal 039 C07 patch sends an anoying ride cymbal strike with every...
I'm not familiar with this kind of keyboard, but it is almost certainly that you have 2 parts (2 instruments) layered together. In this case a bass and a cymbal. This is a feature, not a malfunction of every multitimbral keyboard. Multitimbral means you can play more than one instrument at the same time. This is good as you can create some nice fat sounds, but put the wrong instruments together and you'll have the problem you're experiencing. My suggestion is that you read what the manual says about layering or mixing parts. There you should find instructions on how to turn one of the instruments off. You can also try to google the words "how to parts layer (or sound layer, or combine sounds) on the Yamaha S80". Good luck.
Dec 16, 2009 | Yamaha Full-Size Keyboard
The proper way of setting up a foot board to my amp and guitar
Run a jack from your guitar to Input R Mono on the pedal.
Run a jack from Output R Mono on the pedal to the input of your amplifier.
There is a switch for guitar or Bass. Put the swich on guitar
You do not need a preamp to use this pedal.
Hope this helps,
Maxx.
Aug 27, 2008 | Boss Music
Tama HP910LWS Speed Cobra Double Bass Drum Pedal Logo
Top Tama Music Experts
Michial Gueffroy
Are you a Tama Music Expert? Answer questions, earn points and help others
