Question about Water Heaters
Rheem elec water heater model number 666H30D
Need wiring schematic
  • 14 Answers
SOURCE: Rheem water heater, will start but flame lasts 10 seconds
Is the vent fan working well and can you feel unobstructed air out the termination fitting outside?
Posted on Apr 05, 2009
  • 252 Answers
SOURCE: I have a Rheem glas fury model 22-40 gas water - leaking
once they leak it's time for a new water heater. ther is no way to repair a tank leak
Posted on Oct 23, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
  • 494 Answers
SOURCE: Rheem Power Vent 2 water heater is flashing 4
The flashing light is a trouble sequence light. Find your manual to see what 4 flashes means. It's usually attached to the side of the water heater tank. Try a quick fix by unplugging the power vent and see what happens.
Posted on May 15, 2010
mkh5094
  • 145 Answers
SOURCE: TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
Posted on May 25, 2010
Where can I get a Rheem water heater repair manual
I would first look at the owners manual and or the schematics. You can probably find it on line if you have the model and serial number. I would then call a Rheem dealer or contact the company to see what that error code is. Personally I wouldn't try to fix it myself because it's gas and if you screw up you could blow youself up or burn the house down. That's why I buy electric water heaters and a water softener. I may pay a little more in electric but with the softner to remove the lime, I never have to change an element, only add salt about every 3 months.
Oct 16, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Date of manufacture 81v400, serial r1194849014
1) Rheem 81V40 electric water heater ... manufactured pre 2009 ... posted serial number does not match manufacturer
http://waterheatertimer.org/pdf/Find-Age-of-water-heater.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-2009-water-heater-parts-by-model-number.pdf page 5
2) Possible date of manufacture 11-1994
Mar 05, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Do you have a wiring schematic for a Rheemglas model 81V66DB ser # RH0500408476?
I can't identify that model number, and Rheem does not show that model:
Open following link to help identify water heater:
http://www.rheem.com/Products/tank_water_heaters/gas_water_heaters
Contact Rheem:
http://www.rheem.com/Contact.aspx
Oct 07, 2011 | Water Heaters
Need a diagram on how to wire a disconnect box to the water heater
the heater should be wired with number 10 wire depending on the distance with its own breaker from the panel,if you want another one if you don't know how to put it in you shouldn't be messing with it.
Jan 12, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Our electric water heater doesn't work.
make sure it is wired correctly, check circuit breaker, check breaker built on to element. If all fails, and it is determined your not getting power to it, you may need a electrician. Be careful. good luck.
Steve
Oct 11, 2009 | Rheem 65 GAL ELEC Water Heater 6YR Self...
Water Heaters Logo
78 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
