Question about Fedders A6Q10F2B Q Chassis Room Air Conditioner
Fan switch stuck on low fan speed and will not change to med & high
Was able to select all fan speeds. Turned unit off. Turned unit on and only get low speed fan.
2 Suggested Answers
  • 659 Answers
SOURCE: heat doesn't work on ac
You need to check if the heat strip is still good on it or that it is receiving power. If its getting power, then the strip is bad.
Posted on Apr 01, 2009
Fan only runs on high speed
Wild guess the fan was replaced with a one speed motor. Or the selector switch is bad or not connected. Or the relay/s for other speeds are not getting thermostat signal for some reason.
Mar 12, 2015 | Heating & Cooling
Can you control the fan speed of the cool air coming out I have a 5 ton
If your a.c. doesn't have an ecm motor then you can change speeds. With the cooling on you want high speed selected. You can select med speed or med high for fan motors that have four speeds. You would not want to do that with cooling though. It could cause your coil to ice up.
Feb 28, 2015 | Heating & Cooling
How do i fix the blower stuck on high
if it only goes on high, the resistor needs to be changed . It is on firewall ,passenger side of car under wiper assembly behind alternator. not a hard job to do, part is not expensive. you will get low,med , and high back. if not switch on dash panel, or change blower motor, last ,since it is going on- working. good luck
Feb 22, 2015 | 2003 Chrysler Town & Country
Hampton Bay Chateau Deville with remote stuck in high. Remote works fine for light with dimmer, but will not turn off fan or change speed. Stuck on high.
When you had the batteries out of the remote, did you press all the buttons to be sure one is not stuck? Also, this could be a button failure.
Nov 21, 2013 | Hampton Bay Ceiling Fan. Chateau Deville...
Do you know of a way to slow down the LOW speed fan setting on a Kelvinator KSE70HRA air conditioner? Low is very noisy and blows air like a HIGH setting.
Hi, no, im sorry if it is on low already, it can't be changed to go any lower. The only thing I can come up with is the fan motored is wired wrong, and they have the high or med lead connected to the low speed, as it should run slow. On a central air system, there is a board that is in the indoor unit that shows the fan speeds, and they can be changed.I didnt look up your unit, and if it is a central air and not a window unit, you can change the speeds at the board. The wires are colored, blue is normally low, red is Hi, and blk or yellow is med. If this is a window unit, there is nothing much you can do. If you know anything about electrical, and you have a 3 speed fan, pull the cover to get to the switch back, and see what leads the have terminated to the switch. They may have it miswired. I wish you the best of luck,
Shastalaker7
A/C, Contractor
Jun 12, 2011 | Heating & Cooling
Water spill
1) Press the POWER SWITCH key (Fig. G) to
switch the unit on.
2) Press the MODE key (Fig. H) until the DRY
indicator light illuminates on the control panel
(Fig. I). Each depression of the MODE key will
advance to a different mode setting (Cool -
Dehumidify - Fan - Auto )
3) If the room temperature is > 25°C (77°F), fan
speed can be adjusted. Press the FAN key (Fig.
J) to select the desired FAN SPEED setting. Your
selection will appear on the control panel. Each
depression of the fan key will advance to a
different fan speed (High - Med. - Low )
as shown in Fig. K. Otherwise fan speed is fixed
to low.
Note: The warm air exchange hoses must vent
inside the room when using Dehumidify mode.
Jun 01, 2010 | Danby DPAC7099 Air Conditioner
I have an intertherm central air unit in my mobile home that does not change fan speed when I click the fan speed switch. I've checked the fan relay which is good and energized in the ac mode which should...
You may ahve a bad switch but sometimes when they are worked on the servicrman bypasses the switch. Fan speeds are color coded black high blue med yellow med high and red low. Just for your info. Russ
Aug 16, 2009 | Heating & Cooling
Change motor speed
if it is afixed speed system, the taps on the motor are: black = hi speed
yellow = med hi
blue = med low
red = low
you may not have a yellow
white is always neutral or comon
Jun 22, 2009 | Lakewood 007 Floor / Box Fan
Changing the 3 speed switch on my westinghouse ceiling fan
If you are careful and take the hot coming into the fan from the power source and connect it to the colored wires one at a time, you will be able to find which one is high, med. and low. Then connect them. Hot in is L, 1 is low, 2 is med, 3 is high
Jun 18, 2009 | Speed Ceiling Fan 3-speed Switch By...
Fedders A6Q10F2B Q Chassis Room Air Conditioner Logo
35 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
