Question about Plantronics Explorer 232 Bluetooth Headset
Help me with connecting it to my ps3
I have been trying this for about 15 mins and i cannot do it please help
When i turn on my ps3 and change the tv output to the right one it says "no signal only audio" at first i thought it was my hdmi wire but i got a new one and tried that and it still doesn't...
Try the alternative connection, with other TV set. This means change your TV for moment and check it with the PS3. Use AV connection if you have provisions to make sure if your PS3 has video signal. This will ensure you that your PS3 is working fine. If you can't get any signal out, then check your PS3. Other options is, setting your TV's NTSC/PAL system to auto mode for video signal. This function can be done using remote control or user manual can also be a good help.
Apr 14, 2011 | Video Game Consoles & Games
My ps3 freezes up after 10 to 15 min.
You should try disasemblying your ps3 using Gilskys guide and than cleaning all your parts with a vacum cleaner, next step would be than to re apply some new thermal paste
Apr 23, 2010 | Sony Playstation 3 (PS3) Console
HELP
If your PS3 is freezing up then this happens in much the same way as the 3 red lights on the Xbox 360.
The GPU and the CPU heat up and you need to stop the heat to fix it.
You can send it in and pay $130 to get it fixed or you can use the recommended PS3 Repair guide that will have it fixed for you in under an hour!
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
PS3 freezes.
PS3 is one of the most amazing gaming device but like other competitor gaming devices (Xbox and Wii) It also has some problems like Freezing up. You may check out the informative Article at ezinearticles Remedy for PS3 Freezing up.
Mar 31, 2009 | Sony Playstation 3 (PS3) Console
Ps3 shuts off during gameplay
My PS3 shuts off 15 minutes after I play can I fix the problem in system settings
Mar 25, 2009 | Sony PlayStation® 3 (60 GB) Console
Beeps 3 times and blinking red light
do you have it conneting to the wall??? or threw something else???? be specific!!! it sounds like your power is not connected right!!! but explain to me in detail!!! check your connection from your ps3 or try cleaning the port from the connection!!
Dec 16, 2008 | Sony Playstation 3 (PS3) Console
Help?
Sounds like a blown fan.. new one is 15$ on ebay and about 15 min fix.. or ask sony.. or get an external cooler for 30$ at walmart...!!
Jun 29, 2008 | Sony Playstation 3 (PS3) Console
System Update wont work
unplug your internet modem for 15 min, keep the connection to the PS3, of course. do automatic settings, not manual, select easy but DO NOT GO FURTHER until you plug in your internet. Let it cycle, the modem may shut down. if/when it does, turn it on and continue. The PS3 should automatically find everything by itself. Confirm then test the settings. I think that should work.
May 28, 2007 | Sony Playstation 3 (PS3) Console
Plantronics Explorer 232 Bluetooth Headset Logo
20 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
skiffy99
skiffy99
Level 1 Expert
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
