Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Loss of sync
At fist it was working fine, i was switching between my ps3 and a blueray player by just disconnecting the hdmi from the systems. but after trying to use a belin hdmi switcher, so i wouldnt need to plug and unplug all the hdmis, it worked for a bit but i guess it crapped out. now i cant even plug in one system at a time
    Top Expert:
  • Sharp Master
  • 74,473 Answers
Main digital board has the fault. In most cases, it will need replacement. Contact any service technician. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/. If you are sound in electronics, you can do it by yourself.
Posted on May 08, 2013
  • 4 Answers
SOURCE: HDMI Connection to Ooptical Output
Talked with Sharp, it's a issue with hdmi and optical out, best fix for it that I'm currently using is a 3-way toslink splitter, cost a little of nothing and work perfectly, you just turn the dial to the signal you want to play off of. Clicky
Posted on Jan 24, 2008
DRebel
  • 19 Answers
SOURCE: Sharp Aquos LC-32B20E wont display a PS3 output via HDMI
kitconnolly,
I too went through this problem.
Step 1 - Plug in your "composite" cables and the HDMI cable to the PS3. Obviously, the "composite" cable are the ones that came with the system. You need to start with them as the default connector.
Step 2 - After connecting the "composite" cable and the HDMI cable to the PS3, connect the other ends to your TV.
Step 3 - Power on your PS3
Step 4 - Select display settings-->video output settings
Step 5 - Change from the current video cables to HDMI. (Your tv has different inputs. When you switch to HDMI in the PS3, you will have to switch your TV to the HDMI input that it is connected to, to get a picture)
Step 6 - Be quick, the PS3 will display a "test" for 30 seconds. You need to switch your tv to the correct HDMI input and press "X" on your controller to accept the change.
Let me know how this works for you.
Posted on Apr 03, 2009
  • 413 Answers
SOURCE: IVE TRIED CONNECTING THE PS3
perhaps the tv needs to scan for the channel tha the PS3 is on.
Posted on May 07, 2009
milkburp
  • 416 Answers
SOURCE: My volumn doesn't work when using the HDMI cable
Your TV and the cable box may not be compatible via HDMI or the digital audio format of the cable box is not set to PCM (contact your cable provider for information on how to change this on your cable box... too many models to speculate). The easiest solution is to use the component connections on the box and the TV (5 wire - Green, Blue, Red, White, Red). This will give you HD and eliminate to question of compatibility. I hope this was helpful, best wishes.
Posted on Apr 22, 2010
  • 81 Answers
SOURCE: My Sharp Aquos LC-40E67UN is plugged into a Sony
Wow it seems as though you've pretty much done all of the applicable troubleshooting for this issue. The only other thing I can advise in this case is to consider purchasing a SD card. Some Blu Ray players require a little extra memory to function properly so they come with an SD card slot. Of course no one tells you this when you buy the player but it may be the solution to your problem.
Posted on Jul 18, 2011
Bose lifestyle v20
Make sure the HDMI device (TV, Blueray player) is set up for audio output. Usually HDMI 1 is the only connection that has audio out. Also some TVa have to be configured for HDMI audio out.
Dec 07, 2013 | Audio Players & Recorders
Hook up new blueray thru old home theater system
Yes you can. If you have more than 1 HDMI sources and your old system only has 1 HDMI in, you may want to invest in an HDMI switch. They are inexpensive (under $20 on Amazon) and let you choose 4 HDMI sources to feed your system. The audio is embedded in HDMI and you may have to select the choices (surround versus stereo) when you play the disc.
Dec 25, 2012 | Sony DAV-DZ175 DVD Home Theater System
I have an LG42LH40 and ive had 2 situations when i turn on a tv in another room one of the hdmi ports go out. ive had to use the other hdmi port and the cable or ps3 works fine but not in the 2 other...
Are you aware that all the new HDMI devices have interactive technologies . For eg: if you are watching cable TV and switch on your Blue ray player connected via HDMI, you will notice the TV will automatically switch to that HDMI input with you having to pick up the Tv remote and switch manually. Some find it irritating, but you can disable that function in your system Menu. Panasonic calls it Vierra link / Sony calls it Bravia sync etc.....
Mar 08, 2011 | LG 42LH4000 42" HDTV-Ready LCD TV
My son tried to download demo of a game called spare parts from the sony ps3 website and since then we only have sound and no picture on his ps3. the hdmi lead is fine and works other things ie blueray...
No prob. The PS3's HDMI is crazy at times. All you have to do is what is called a "Video reset". I'll include a link to a video that will help you. This works for all PS3 models.
How To Reset PS3 Video Settings PS3
Feb 16, 2011 | Sony Playstation 3 (PS3) Console
PS3 hdmi only working on some displays
I have noticed using an HDMI cable that with some of the newer tvs you have to set up the tv also to enable HDMI for a game system. Like you said before internet tv and blueray dvd player work fine. Try adjusting the settings on the tvs themselves. I have a 50in DLP mitsubishi, and had a very troubling time getting my ps3 to work on that particular tv set while it worked flawlessly on other sets. And what I had to do was enter my tv setup menu and then power on my ps3 with both my AV and HDMI cables connected, it would pick up the AV first. Then I would alter the video settings on the PS3 for HDMI, and unplug the AV cable. Exit the tv menu and then reenter it. Then I had to setup my HDMI port from the tv to game in order for it to work, where you can set options ar usually like cable/dvd/sat, and so on. Without my TV being set to game that way it would not work. Try this and see if it helps. Good Luck.
Dec 21, 2009 | Sony Playstation 3 (PS3) Console
When tv is wired to media center and then to blueray dvd , disc will not play. Non blueray disc will play. When tv wired directly to blueray player, blueray disc runs fine. Cables are hdmi
Hi.
When you say disk will not play I assume the BRD player does not start playing.
If the Blue ray unit does not start at all and stays in stand by , then the HDMI cable you are using to connect to TV, or HDMI port on TV may be defective.
Try replacing cable and swapping HDMI ports.
Oct 24, 2009 | Bose Audio Players & Recorders
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
Getting the TV to play through the HDMI cord
First, you need to set the playstation to display on HDMI out.
Plug the HDMI cable into the TV and into the PS3.
Use the PS3 to setup the video settings to 720p which every HDTV can display. Then switch the TV-out to HDMI and it should display.
Also consult your televisions manual to set it up for HDMI input as well. Make sure that the TV allows sound through the HDMI port as some older HDTV's didn't have that ability.
If you still have a problem; please let me know! I hope it helps you out
Aug 08, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Hook up surround sound system to entire system
Is the 42 inch a lcd tv. is the blueray player & ps3 hooked up in the hdmi inputs?
Jun 01, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
Ws-65807 65" mitsubishi rear projection tv
For this unit and the addition of the secuity features of Blu-Ray, the 1080i you set can handle is through the component input from a DVD player or an XBOX. In the configuration menu of the PS3, change the resolution to 1080i and see if your set will reset to it. The 1080i on the Blu-Ray is only possible on the HDMI cable as far as I could find, again due to the security restriction. The Mitsu is not going to run it in 720p due to the PS3 is running component and cannot control sync to this set.
Aug 01, 2007 | Mitsubishi WS-65807 65" Rear Projection...
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
55 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
