Question about Texas Instruments TI-30XA Calculator
How do you use the factorial button?
I can see it on the 3 I just don't know how to use it.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Enter the number and then press 2nd [x!]. For example, to calculate 3!, press 3 2nd [x!] and get 6.
Posted on May 08, 2013
Don't the user name or password for my motorola SB900 can you help ?
That's depends...First, do you have the password to log into the modem? it seems that the default is admin/motorola. If that hasn't been changed, you could log in and remove the WEP key.
In addition, most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't be worry...Or if these all can not work, you can call or ask directly to the customer service of Most modems and routers will reset to factory defaults if you press and hold in the reset button for around 30 seconds with the device turned on. Forgetting the password is a common problem. Don't worry... or if the above ones all didn't work, you can call or ask the Motorola customer service directly, maybe they know the solutions because they produce it!
May 30, 2012 | Computers & Internet
How do I restore factory settings for a wnr3500L?
You can reset your Netgear router/wireless router to the factory settings from within the router manager. The reset procedure removes all user-configured settings and returns the router to the original factory settings.
For this reason, only reset the router if you encounter problems that can't be solved with other methods.
Step 1: Check that your Netgear router/wireless router is properly connected with your system or not. If it is OK, then press reset button on Netgear router for at least 10 seconds. The 'test' light should flash during this process.
Step 2: Now open browser and enter Netgear's IP address into the address bar. Generally, '192.168.0.1' is the Netgear router IP address but you can find specific IP address in Netgear router manual.
Step 3: Now enter your default username and password to log in to router.
Step 4: Click 'Erase' button under the 'Revert to Factory Default Settings'. This process will erase all your previous changes that have been made to the router and restore the configuration settings to factory setting. Don't interrupt the process until the process is finished.
Once the router's 'test' light has stopped blinking and the configuration page you are on has refreshed, the router has been reset.
Feel free to get instant online Netgear router support at http://www.vtechsquad.com/netgear-router-support/ to fix Netgear router/wireless router issues.
Mar 19, 2012 | NetGear WNR3500L Router
I locked my galaxy ace GT-S5830T
To fix it, just then again remove the battery out, then put it back again. Don't power it ON yet, just press and hold the Volume Up, Center button and Power button at the same time. A menu will then appear that let choose with an option. Just use the volume button to toggle and select the wipe data/factory reset, that will then reset your Galaxy Ace to it's factory default settings.
Feb 05, 2012 | Samsung Galaxy Cell Phones
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
What do I do to make my LG RH397D regeion free?
Try the following method.
Using the factory supplied remote:
1. Press 'home' button
2. Scroll to 'setup options'
3. Scroll to 'lock' (don't scroll sideways)
4. Press the following button sequence: 0, 0, 0, 0, 0, 0, 0 (message appears)
5. Press 'enter'
When attempting to play other region discs, it may take a few seconds for the firmware to recognize the disc.
Hope this helps...
Aug 28, 2011 | LG Televison & Video
MY FRIEND JUST GAVE ME HER OLD PHONE WHICH IS A MOTOROLA MB300. BUT THE PHONE HAS A PATTERN LOCK BUT SHE FORGOT WHAT IT IS. CAN SOMEONE HELP ME?
Welcome to Fixya. If the you don't know the lock code you can try the steps below so that you can reset the phone to it's factory state.
1. Power off phone. 2. Hold camera button and power on phone at the same time. 3. Release the camera button when prompted to. 4. You will see a message screen telling you to press the up or down volume button 5. Press and HOLD the down volume key (ignore message 'Volume Up Key Pressed') 6. When triangle and phone screen appears 7. Press on the screen just above the back key 8. You will now see the "Motorola system recovery" menu
At this point you will have three choices:
1. reboot system now [Menu+Back] 2. apply ssdcrad:update.zip [Alt+S] 3. wipedata/factory reset [Alt+W]
Select the third option to do a factory reset.
Thanks You can simply tap an item to select it.
Aug 02, 2011 | Cell Phones
Cant login to my motorola sbg900 wireless router. i know my username and password and it will not work. I've tried resetting it by holding the button down in the back, but that won't work either. i...
By holding down the button in the back, you may have reset it to factory defaults for the password and username. Try using Admin for the user name and motorola for the password.
Jul 28, 2011 | Arris SURFboard SBG900 Wireless Router...
I purchased this router from someone and they told me it wasn't used. Turns out it was and now I don't know the log in information to set it up to my computer. Can this be reset without having to...
There is a reset button on the back. Press and hold that button (will require the end of a paper clip to get to it) for 20 seconds until the unit resets. The settings will be restored to the original factory defaults. The IP address will be 192.168.1.1 and the password will be admin (no user name).
Jun 20, 2011 | Linksys Wireless-G WRT54G Router
Hi i have play station 2 and i don't know what to put the tv on to play my games
Well first if you don't have a factory remote you will have to purchase a universal remote that supports i'll products program using factory codes or do a manual search( which takes a little time but I have had better luck with for more functions ) after programming you press tv/vcr button in which it should display ant. vIDEO1 video 2 and component repress button until desired chann el is highlighted coincideing with whatever location you have your device connected rear is video 1 and multicolor is component and front is video2
May 18, 2011 | iLO IWT3206 TV
Texas Instruments TI-30XA Calculator Logo
62 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
