Question about Husqvarna Chainsaw Model 353 18" inch bar
Chainsaw problems leaks fuel from a hose
  • Husqvarna Master
  • 1,807 Answers
chainsaw problems - 2b95f6d0-00c9-437c-9a90-cef2cbbc13f4.jpgIve highlighted the fuel line part number on the parts manual
Posted on May 09, 2013
Saw will fire then die in 10 sec.
The fuel is not going through as it is supposed to. Clean all fuel lines . Make sure you check the fuel filter at the tank that it is not clogged.
blow into the hose to make sure it is open . Do the same with the filter.
If you find any leaks , replace the hose. To check for leaks . Pinch the hose on one side and blow through it.
Nov 23, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
My chainsaw won't run without full choke on and
Fuel starvation, start by replacing the fuel filter in the tank, check the fuel hoses for leaks up to the carb.
May 22, 2013 | Garden
My chainsaw will start ok but it will not run properly
If this is a older saw I would suspect the fuel line. A common problem, especially with ethanol fuel. The hoses get hard and brittleand a small crack, even if it does not leak fuel, could suck in air. If this is not the case you should have a low and high adjustment on the carb.
HTH
Feb 28, 2013 | Garden
No gas in carb husqvarna 141 chainsaw
Fuel gets to the carb via the fuel filter in the tank, the fuel hose up to the carb, and the impulse from the engine making the pump diaphram in the carb pulse and pump fuel, so start by replacing the fuel filter in the fuel tank, then check the fuel hose for signs of leaks, the impulse from the engine is fed through a pipe in the carb support block, you will need to remove the carb and block to inspect this, there is also a filter within the carb itself, this is sited under the pump housing of the carb ( alloy cover held with a single screw )
Oct 05, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Chainsaw will fire up but stall immediatly as if starved of fuel
Fuel starvation always starts at the fuel filter in the tank, replace the filter and try again, also check the fuel hoses for cracks, splits and leaks.
Sep 02, 2011 | Ryobi Garden
My rancher, reliable for many years, has developed the problem of starting but not continuing under acceleration via the hand trigger; it just cuts out.
This sounds like fuel starvation, start by replacing the fuel filter in the tank, check the fuel hose up to the carb for signs of leaking or cracks.
Aug 31, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Petrol not pumping through to engine.The chainsaw works when I pour petrol into the spark plug hole,what do you suggest the problem may be? Reg John
Fuel starvation, replace the fuel filter in the tank on the end of the fuel hose, check the fuel hoses for leaks and cracks, replace if needed.
Aug 12, 2011 | Garden
My poulan saw will only run for 30 seconds and then quits. It ran for about 30 minutes before developing this problem. Plug is dry with tan color. Air filter is clean.
Try a few simple things first, clean the air filter, remove and replace the filter inside the fuel tank on the end of the fuel hose,check the fuel hose up to the carb for cracks and leaks, fit a new spark plug.
Jun 27, 2011 | Poulan 14" Chainsaw
My Poulan 18in 40 cc WildThing ChainSaw Won't Start.
Start with basic tests, drain the fuel tank and fill with fresh fuel oil mix, remove and reolace the fuel filter on the edn of the fuel hose, check the fuel hose up to the carb for leaks, remove the spark plug, rest it on the side of the cylinder ( away from the plug hole ) cramk the engine and check if you have a spark.
Apr 16, 2011 | Poulan Wild Thing 2375 18" Gas Chain Saw...
My Stihl MS-180be chainsaw is leaking a small amount of gas when full. What could be the problem? Is is the fuel line where it goes into the tank? The saw is working ok?
This saw has a fuel tank vent that could be leaking a small amount of fuel, or the fuel line coming out of the tank could be leaking. Fuel line replacement isn't complicated, you could try installing a new one. If it's the vent, odds are it's not enough to cause alarm........unless the vent line is cracked. In that event, you should replace the vent hose. Again, not a complicated repair.
Jun 13, 2009 | Garden
Husqvarna Chainsaw Model 353 18" inch bar Logo
44 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
