Question about Crest Audio Audio Players & Recorders
Crest Audio amplifier V900 oversensitive ACL/IGM
Oversensitive ACL/IGM progressively became more sensitive over time. Now does not run more than a minute before e tripping protect relays.
3 Suggested Answers
  • 5370 Answers
SOURCE: when i turn on my crest audio 8001 it stay in
The power transformer is getting short and overheated causing it to go in thermal protection mode.Also if the amplifier gets overladed by its connection, it goes to thermal mode.
The problems i have seen most often in Crest amplifiers is bad capacitors. They look fine from the outside but pull one out of circuit and measure it and there bad. These are the small electrolytic types. there are 2 sets of solid white wires from each output module to the output relays. Inject a a signal into the amp and take a look at the signal on those white wires. If the signal looks clean with minimal DC offset then you have bad caps causing it to stay in thermal protect. A very common crest amplifier problem.
Check in between the heatsink's. These amps have a tendency for those heatsinks to arc across the sinks. There are only 2 thin rails that hold the modules and rough tour duty service can cause those rails to bend and the sinks to touch and arc. Even a bug getting between the sinks can cause them to arc if the amp is running hard!
Also look for open resistors. This are possibilities, that can cause the amplifier to remain in thermal protect mode.
------------- This should help.Thanks.Helpmech.
Posted on May 31, 2011
  • 867 Answers
SOURCE: I have a Crest Audio V900, a set of Bose 901, a Gemini EQ-3000. Do I need a PREAMP? Or can I hook up the Crest AMP to the Equalizer?
You could use the EQ but it won;t sound as good as it will with a pre amp and also could make it a bit trickier when adjusting the volume and getting it to sound right.
Posted on Mar 10, 2012
Testimonial: "Thank you very much. I wouldn't like to mess up my Bose. So I guess It's better to buy a PREAMP and then connect accordingly. Once again, thank you for your time and concern , oh, and your most valuable information."
Crest audio ca12
Dust in the unit - clean with Canned air like a computer.
or Delamination on the printed circuit board.
Don't forget to clean all contacts on the backside of the unit!
If cleaning doesn't work - head to the local Crest "AUTHORIZED" Service Center.
Mar 24, 2014 | Crest Audio Audio Players & Recorders
He never active and ACL Led stays on and the cooling fan go for hi speed
Hello folks,
The same thing happening with my crest cc4000. The plastic connector, connecting the wires from the transformer to the circuit board was burnt damaged and was removed. but acl light still stays on and amp not active.
Dec 19, 2012 | Crest Audio CC4000 Amplifier
Mar 10, 2012 | Crest Audio Audio Players & Recorders
Smoke comes out from the switch and wont turn on ... there 2 amps make of ca9 and ca6 wondering if you guys can help
This is a very easy cheap fix, but since this thread is pretty old first make contact to help you out with this issue, common on CA series power amplifiers of Crest Audio.
Aug 12, 2011 | Crest Audio CA 9 2Channel Amplifier
How to activate 70v line of crest audio cki 800v
First of all the 70 volt line is used when we are dragging long lengths of speaker wires. hence to counter the drop we use a high voltage line brring it further down without any remarkable drop and use a step down matching transformer to power the speaker according to the impedance of the speaker to the secondary of the transformer. Connect the 70 volt to the 70 volt output in the amplifier. Now connect the other end of the wires tto the primary of the 70 volt transformer. Use the secondary output to connect to the speaker using the tap most suitable..2, 4,6,8 ohms . Check the phasing when you connect or reverse if the bass quality is less.
Hope this helps. Good day
Jun 29, 2010 | Crest Audio CKi 800v Amplifier
Why my crest audio ca6 has the lights clip signal
disconnect you load (speakers) power amp up. If this fault persists there might be a problemm with the amp
Apr 21, 2010 | Crest Audio CA9 Car Audio Amplifier
Every time I turn the amp on it shuts its self off.
disconnect all speakers and test if the problem corrected you will have a problem in your speakers(either wire or speaker itself)-try to connect the speakers one by one until you find the bad one and change it--if all above does not work send your amp to service center near you
Mar 30, 2009 | Crest Audio CPX-900 Amplifier
My CA9 has protect recurrent problems.
if you are bridged in parallel instead of in series the amp wont support the load so it turns the power protect on till the amp cant handle nomore then the amp will go if you have two subs bridged run them left speaker possative to to the amp possative for bridged mode then laft speaker negative to the right speaker possative then right speaker negative to your amp negative for bridged mode if you have them left and right speaker possative to amp possative and left and right speaker neggative to your negative to your amp thats parallel the ampwont support the 2 ohm load
Feb 08, 2009 | Crest Audio CA9 Car Audio Amplifier
No power
These amps are very compact and are not the easiest to work on. If you are not experienced at repair, I would not recommend you start here. Where are you located?
Dan
Jan 13, 2009 | Crest Audio CPX-900 Amplifier
61 people viewed this question
Top Crest Audio Audio Players & Recorders Experts
Owen Barnes
Jordan Lee
Level 1 Expert
Geoff White
Geoff White
Are you a Crest Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
