Phillip 42PFL7332D/37 The TV cycles on/off repeatedly (video/audio/back light
    Top Expert:
  • Televison & ... Master
  • 74,384 Answers
Symptom of damaged main digital board. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 08, 2013
5 Suggested Answers
  • 5 Answers
SOURCE: Unexpected lamp shutdown
Remove the lower front panel by removing the 2 large round screw heads at the lower back corners, one on each side. Remove the retaining screw on the right side of the metal horizontal retaining strip in front of the bulb holder, remove bulb retaining screw in the upper left corner of the bulb holder. Pull the bulb holder out towards you and check for dust build up on the top screen on the bulb casing, if there is an abundance of dust it will restrict the airflow across the face of the bulb which causes it to heat up and turn off. Once the dust has been cleaned your bulb should now work as it should without a problem.
Posted on Mar 13, 2008
SOURCE: Shutting off then on continuously, w/ green light on
I pulled the lamp, and blew the dust off of the top. TV is back to working great!
Posted on Jun 14, 2009
  • 8457 Answers
SOURCE: I have a philips lcd tv model 42PFL7332D/37.
Tv turn on now,u just get a flashes of a picture only a few sec. than dies and have sound left only?Yes,than those 2 long boards that call the LCD inverter boards are dead.These 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produced the picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 2 refurbishes long LCD inverter boards for the replacement.
Posted on Nov 29, 2010
  • 4 Answers
SOURCE: How do you find the
Carefully remove the back of the TV. If you have a grounding strap, wear it. If not, always keep one hand on the TV and use the other hand when ''rooting around'' back there to prevent shock damage. The power supply will be large, and very heavy. Here is a link to what it could look like - this link is a list of all possible power supplies in your model along with photos. http://www.shopjimmy.com/catalogsearch/result/?q=42PFP5332D+power
Once you find the power supply, locate a part number on a sticker or the board itself and match that up to one of the power supplies from the link. Leave the power supply inside the TV until you have the replacement in your hot little hands, so you can remember how it went in etc.
Posted on Jul 08, 2011
Philip's tv 47PFL7432D/37 cycling
Power supply, check for back caps, remove backing and check for bad bugling caps, if you know how to solder then its might be a fun project to do, if not time for a repairman call or take it to a shop!
May 11, 2014 | Philips Televison & Video
Home stereo Phillip 708/37 is not getting power.i was told that I need to replace the transformer.cam you advise me how?
maybe not, are the fuses ok ? check fuses, make sure they are ok, also some transformers has a thermistor in between the winding of the transformer in series with the primary winding. Phillip do make their transformers with that kind of protection, just in case the transformer over heat it shuts down. examine the transformer look for the thermistor it is open.
Apr 07, 2014 | Audio Players & Recorders
The sound on my television is not working
Did you select the audio through HDMI cable or through analog audio input port in the TV menu setup for that HDMI input?
Mar 24, 2010 | Philips 42PFL7332D 42 in. Flat Panel LCD...
TV repeatedly goes into standby mode and then comes back on
Resolder Horizontal section & SMPS Power Supply with Soldering Iron
Jan 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Television turns on and off
Almost certainly the lamp.
Apr 09, 2009 | Televison & Video
Philips 37PF7320A/37 won't turn on
That blinking led is an error code for the audio standby board in the set. It should not go out this soon and yes it should last longer.
Aug 21, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Tv cycling on and off
Phillip you have a problem in the main power supply or in the High voltage shutdown circuit. Now the longer you wait to have this fixed the more its gonna cost ya Unless your a tech then get a schematic and measure the voltage on the hv shutdown pin on the video junglke ic when the set shuts down If the voltage at the time of the shutdown sodent spike up then you know your problem is in the power supply. Good luck
May 27, 2006 | Sony Grand WEGA KDF-50WE655 50" Rear...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
