Question about NEC ND-6500A DVD±RW Dual Layer Burner
CD/DVD won't eject, won't play, Device Manager doesn't recognize.
I have a Dell Inspiron E1505. The DVD+RW that came with the computer is a NEC DVD+TW ND-6650A. The computer is about 8 months old. All of a sudden the cd player won't open. The LED light has remained on, but when you push the button, it won't open. The emergency release works. The Device Manager does not show the player at all, and when I tried to manually add it, it wasn't on the list of models for NEC. Does anyone have any idea what's going on?
  • Anonymous Apr 30, 2008
    I have the same problem, but my E1505 is just over a year old - no longer under warranty - and I've recently moved to a foreign country, so I can't bring it back anyway. I can't get the DVD out at all.
  • 2,961 Answers
If it's only 8 months old, then you have atleast 4 months left on your warranty. The problem will either be the ide controller channel or the dvd drive and firmware has faulted, the same fault probably happens when you have put a dvd in and it wont read or eject. Return to the place of purchase, where the drive should be replaced or the notebook exchanged.
Posted on Aug 11, 2007
My DVD/CD-RW drive isn't recognized/ doesn't play disks.
It may be bad. Has the laptop been damaged? Dropped? Open Device Manager, DVD/CD Rom drives, is it listed? In Start Menu, Computer, Is it listed? Try re installing the DVD rom driver, the MS Vista 32bit drivers can be found here:
Feb 02, 2013 | Dell Vostro A860 Notebook
Music CD won't eject from Dell Studio 15 notebook
Open "COMPUTER" hold cursor over the Device CD/DVD right click scroll down to "EJECT" and click.
Nov 01, 2012 | Dell Computers & Internet
My burner will not burn cd's anymore. It still plays cd's fine as well as play and burn dvd's fine. I see no errors in hardware setup. It is a nec dvd +- RW ND 6650A that came with my Dell Inspiron E1705.
The CD Burner / Player / DVD Burner are all different heads. If the Dell Inspiron E1705 is an older model it is most likely you have reached the end of it's usable life for the CD burner part. If it is new the CD burner is most likely defective and hopefully warrantied. Otherwise these CD/DVD units can be replaced relatively inexpensively (as compared to buying a new laptop).
Feb 01, 2011 | NEC ND-6650A DVD RW Dual Layer Burner
My optiarc dvd rw ad-7200s a. t. device for my desktop Inspiron 530S will not play dvd's ..What can i do to fix this?
Hi tripping,
First I would check all the preferences in the software I was using and make sure everything is set right. If I could find nothing wrong there I would go to the Device Manager, uninstall the drivers and shut down the system. On reboot if it is a plug and play device, Windows should reinstall it. If it is not PnP, go back to the Device Manager an manually reload the driver.
To get to the Device Manager - click Start, right click on My Computer, click on Properties, click on Device Manager tab or link. XP has a tab, Windows 7 has a link.
Hope this helps.
Dec 26, 2010 | Sony NEC Optiarc AD-7200S DVD-RW Burner
Won' read discs, won't eject manually or through Eject under DVD drives.
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Nov 14, 2010 | Dell Vostro 1500 1700 / Inspiron 1520 1521...
What DVD burner should I put in my Dell E1505 Laptop
I'd get a double layer (dl) drive by Memorex from either Tigerdirect or NewEgg. They always have them on sale and all three of my systems have one installed.
Good luck,
Nov 12, 2009 | Dell Inspiron E1505 Notebook
Installed XP SP3 to my Dell 6000 and now NEC 6500a can't be found. Device manager says that the drivers are loaded by cannot find the hardward Code 41
see if its recognised in the Device Manager. Start/My computer/Control Panel/System/Device manager.
if so remove or uninstall the Drive.
Physically remove/eject the drive from the Computer. reboot then shutdown. re-insert the Drive. boot computer and see if it,s detected by the system or ( found new hardware Wizard )
re-install any drivers as requested. Installing SP3 shouldn,t do this. unless the drive was actually Virused Or failing already.
Mike @ compurepair.
Oct 16, 2009 | NEC ND-6500A DVD±RW Dual Layer Burner
CD/DVD drive not recognized by system and not working at all!
in windows xp: go to start then control panel then system then hardware then device manager then remove anythig that even remotely looks lika a DVD drive then: shut down you computer when it restarts xp will look for and, install anything hooked up to it automaticly
Apr 28, 2009 | Dell Inspiron E1505 Notebook
Dell Inspiron 6400 Vista CD Drive Does Not Recognize CDs
Try to use dvd cleaner disk to clean the lens, if it doesnot work, i think you have to replace your drive , this happens with Dell alot. but try to clean it, uninstall then install the driver back and check if its work.
Best Regards
Mar 14, 2009 | Dell Inspiron 6400 Notebook
Driver for NEC CD-RW NR 9100A
I cannot watch DVDs with my nr-9100a cd rw and dvd rom drive.
Nov 29, 2008 | NEC MultiSpin NR-9100 (NR-9100A) CD-RW...
NEC ND-6500A DVD±RW Dual Layer Burner Logo
600 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
