Question about Restoration Hardware Allaire Desk Fan Black
Simply Stopped Working
All of a sudden, one day, it just stopped turning on. Has been sitting in the same spot for three years. No damage to cord. Tried other plugs, other speeds, plugging in off, plugging it in on. Nothing. Does Restoration Hardware offer repairs?
2003 F150 - LED display in stereo faceplate does not light up. It suddenly stopped working a couple of years ago, coincidentally(?) the next day after I had washed the engine with garden hose sprayer. A...
2 years ago? Have you checked any of the wiring for it under the hood? Any wires they may have been spliced could be corroded or simply have come apart. Take some time to look closely.
Oct 31, 2013 | Ford Cars & Trucks
My zoom g1xn suddenly stopped working. When i connect the power source, it doesn't turn on. . . When i tried batteries, i turned on but the display was flickering then it turned off. . . What is wrong?
Try another cord/charger. Check the AC jack in the machine. Is the battery charging with the cord/charger plug in? Has the laptop AC jack been pulled by the cord? Damaged?
Dec 11, 2012 | Computers & Internet
Makita JR3000V stopped working
I would have checked the cord first. Cords are a high failure part because they always get bent and pulled and such. Some versions of the jr3000v had problems with field wires breaking right at the field terminal.
Mar 05, 2012 | Makita Saws
Ice maker stopped working
check to make sure that the fill tube has not become blocked with frozen water.
Feb 23, 2010 | Frigidaire FRS3R5EMB Side by Side...
Maxtor One Touch 4 won't open
Hi, Generally one of three things will have happened, They damaged the cord, broke the connector inside the drive or they shorted the board by bending the connector. In the first case you can replace the AC adapter. In the other two cases it's not generally worth repairing due to cost. You can try locating a connector with the same voltage amperage and polarity to test the drive but you simplest solution in all three cases is simply to purchase a new enclosure at the local PC store and have the techs put the harddrive from the maxtor enclosure in the new case for testing(about $40). If this works you're done. If not the short may have damaged the cicuit board on the HDD. If the drive itself is damaged and you need the files that are on it you will need the help of a pro. Try the above suggestion and comment back here as to your results, if you need a pro, include your country and city in the comment and I will make an appropriate recommendation. Chris
Jun 05, 2009 | Maxtor OneTouch 4 500GB External USB 2.0...
Infinity 336rms amp worked for over a year then one day stopped?
check your fuses. Also check the power wire connection to the amp and then the ground source maybe move that if there is paint under it. check fuses on the amp. Check ohm load to the amp from the speakers.
May 27, 2009 | Infinity Reference 611a Car Audio...
We have a trusted Philips Azur Precise 4310 iron. Worked fine for the 2-3 years we have had it - then, suddenly, nothing! Power light on handle has gone out and the iron has completely stopped working...
It looks like a problem with the power cord. Try splicing the cord with a new one near the base of the iron and see if this helps. If not, it could indicate some connection problem inside the iron. In this case, it would be cheaper (and wiser) to simply go in for a new iron box..
Sep 28, 2008 | Philips Computers & Internet
Older washer/ dryer with no power
Check to see if power cord is loose at connection inside dryer. ONLY after UNPLUGING! Held on by three screws inside.
Aug 22, 2006 | Maytag PYE2300AY Electric Dryer
Restoration Hardware Allaire Desk Fan Black Logo
94 people viewed this question
Top Restoration Hardware Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Restoration Hardware Furniture Expert? Answer questions, earn points and help others
