Question about LG 42LG30 42 in. LCD HDTV
My screen turns white but sound works
What do you think is wrong with my TV....when I switch it on the screen comes on for about 4 seconds then it breaks up and muffles with a broken image horizontally then the screen turns white (could this be a thermal fuse problem) the sound works the remote still works and I have changed the lead to the power supply and tried plugging in a DVD player and a computer console and still the screen becomes white, seems abit strange to me. Make + model= LG 42LG3000-ZA Actions I have taken: I have tried a different power lead, i have also taken the back of the unit off to check for any leakages near the capacitors and checked the capacitors themselves but nothing seemed wrong.
    Top Expert:
  • LG Master
  • 75,581 Answers
Symptom of a damaged T'Con board. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 08, 2013
dbTVfixer
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
SOURCE: lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Posted on Mar 20, 2008
  • 5 Answers
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Posted on Aug 31, 2009
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
Posted on Mar 21, 2011
Tv comes on but after couple of seconds lights goes off but sound stays ok
check the power board on the 24v side this is for the inverters.if fine then shine a light in one of the side hole in the screen at the back to see if you have a picture if you have a picture then check the relay on the power board is working its a black square there are 2 of them. when you turn on the tv you should hear click then click thats the power and then the inverter power. if you have 3 click that is the inverter power switch turning back off. if you not having this problem. then the 24volt side has a fault. would think off hand the 3 pin power chip its a half moon top. they are prone to over heat if they are next to the transformer. failing that there is a logic power chip 4 pin you will see a white line and the chip is crossing it. hope this helps.
Sep 23, 2013 | Samsung LE46M51B 46 in. LCD Television
My tv screen has turned white
Check and replace its T'Con board.
May 07, 2013 | LG 42LG30 42 in. LCD HDTV
I have sony bravia kvl40u100 it has sound no picture what could be wrong
If there is white light coming out of the back of the set, it sounds like the inverters are firing and your backlights are working. Is the screen pitch black? Gray? White? Blue? It could be a defective T-Con, main board, faulty power supply rail, or in rare cases, a faulty LCD panel.
Jan 05, 2013 | Televison & Video
Maganavox flat screen tv no pic, red light blink codes...
Those blinks are fault codes. To know more visit the site linked here. http://electronicshelponline.blogspot.com/
Mar 25, 2017 | Televison & Video
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
Sony kf-60we610 screen in black and white
Hi there
Is this a DLP tv ?
If it is then your colourwheel might need replacement
Mar 18, 2008 | Sony XL-2100U Projector Lamp for...
No sound on just one channel
Do you have another TV in house that works with this channel correctly? Do you have a VCR (or VCR/DVD combo) that you can use to tune to this channel? I'm wondering if your tuner is going bad on this one channel. Do you have SAP (Second Audio Program) turned on? You may want to turn it on and then check channel for sound. I'm assuming that you're getting your cable feed thru coax and not composite (red & white audio). If you are using composite, try switching the red & white inputs to see if sound comes in. It's possible that cable company is only outputting audio on left or right channel and something is wrong either with one of your TV's speakers or with the cable company's output.
Mar 06, 2008 | Orion STV2763 27" TV
Blue screen with white snowy circle in the middle of screen
Sounds like bad capacitors
Replacing the C9A37 & C9A38 caps or
problems with some capacitors on the pwd power board, and that it would be good to change them if they were swollen
Oct 20, 2007 | Mitsubishi WD-62525 62" Rear Projection...
TV Shuts off, Screen Problems
The problem could be the power supply, the flyback trasformer or simply a bad connection. A repair cost for this TV set could run any where from 75 bucks all the way up to 225 or so, depending on the problem. Good Luck
Apr 29, 2007 | Sony KV-32S40 32" TV
LG 42LG30 42 in. LCD HDTV Logo
