Question about LG 42LG30 42 in. LCD HDTV
My tv screen has turned white
What do you think is wrong with my TV....when I switch it on the screen comes on for about 4 seconds then it breaks up and muffles with a broken image horizontally then the screen turns white (could this be a thermal fuse problem) the sound works the remote still works and I have changed the lead to the power supply and tried plugging in a DVD player and a computer console and still the screen becomes white, seems abit strange to me. Make + model= LG 42LG3000-ZA Actions I have taken: I have tried a different power lead, i have also taken the back of the unit off to check for any leakages near the capacitors and checked the capacitors themselves but nothing seemed wrong.
    Top Expert:
  • LG Master
  • 74,251 Answers
Check and replace its T'Con board.
Posted on May 08, 2013
SOURCE: lg lcd 37 inch tv loosing sound
i have the same problem and find that if i freeze then unfreeze the screen it works
Posted on Mar 20, 2008
  • 5 Answers
SOURCE: LG 47LC7DF Green Light Blinks 16 Times - No Picture or Sound
The lights indicate what the issue is. Kind of like your check engine light in your car tells you something is wrong with the engine.
Posted on Aug 31, 2009
SOURCE: LG 26lx1d tv will not turn on. Power supply is
Have an LG26Lx1D for about 3 years, dropped off by my son.(Figures).Power light just blinking, but went back to red.Removed back panel, and metal cover. Just above antenna/cable input, its a small fan,mine was full of dirt. Blow off dirt, and make sure its turning freely.
Install back the covers, an voila....its a miracle...its working again.
Good luck
Posted on Mar 21, 2010
SOURCE: Lg 42lc7d turns on to blank screen doesnt respond to any request
I need sreen for LG 4LC7D-UB because the screen is damaged
Posted on Mar 21, 2011
dbTVfixer
  • 79 Answers
SOURCE: LG 32LH2000 My TV was turned of last night in the
most LG have a "vacation switch" on the bottom right hand side of the set very near that standby light.
it is placed poorly, where you can accidently click when grabbing the TV to move it or swivel it.
it is a toggle switch, a "master power" switch.
you may have bumped it to the off position. flip the switch, your standby light will come back on.
Posted on Apr 16, 2011
When I turn on my Sony TV, ti stays on about 30 seconds then shuts off, What do you think is wrong?
Do a Power Reset.
1. Turn off TV.
2. Unplug the power cord of the TV from the electrical outlet.
3. Let the TV remain without power for 60 seconds.
4. Plug the power cord back into the electrical outlet. (If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.)
5. Turn on the TV.
If issue persists after doing the steps, reset the TV to factory default settings.
1. Turn on the TV.
2. Using the supplied remote, press and hold the UP arrow button.
3. While holding the UP arrow button press the POWER button on the TV itself.
4. When the TV goes off, release the POWER and UP arrow button.
5. The TV will turn on by itself and the initial setup screen will be displayed. Just follow the on-screen prompts to finish the setup.
Sony KDL 46V5100 random shut off 15 20 sec
Feb 25, 2016 | Sony Televison & Video
My screen turns white but sound works
Symptom of a damaged T'Con board. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
May 07, 2013 | LG 42LG30 42 in. LCD HDTV
1 dg board, (stv 5v sense time out). ........ive
To pettinabatem
I am having a shutdown problem with a Panasonic TC-32LX50. Initially when pressing the on switch, you see for 1 second a right half white screen (the left side of the screen remains black) and the TV turns off and the LED flashes 1 time. I did a T-Con cable check (based on the half white screen) and indeed this went away. Got backlight (full screen and no half white screen anymore). But still the TV shuts down after 1 second and the Red front LED flashes one time. Since this code is also illustrating a "dg board, (stv 5v sense time out)" problem in this unit, I was wondering if indeed you have encountered a defective DG board with yours. I am enclining towards a defective Power supply board.
Jun 27, 2011 | Panasonic Televison & Video
Iv had an n64 before so i think i have a good idea of how to set it up. i've managed to tune my tv in to find where abouts it is but there's only a black screen.i can turn the n64 off an the tv screen goes...
Adjust the vertical or horizontal hold controls. This is helpful even if regular TV stations come in fine. If your TV has an automatic fine tuning control (called AFC or AFT), turn it OFF. Use the manual fine tuning dial to adjust the picture. If turning OFF the AFC/AFT causes your TV to display in black and white, then leave the AFC/AFT ON. Slide the Power Switch on the Control Deck to the ON position. While the control deck remains ON, turn the TV off for 10 second then back on again. This resets your AFC/AFT so that it will tune in the signal from the control deck.
Move your control deck farther away from your TV. If the control deck is too close to the TV, the control deck may cause some interference.
Jan 19, 2011 | Nintendo 64 Console
HS500, white/light at top of screen
I believe input 5 is hd input wich is different from the others
you may want to try hooking the sat to any component input to find out if there is any difference
Jul 19, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kf-60we610 screen in black and white
Hi there
Is this a DLP tv ?
If it is then your colourwheel might need replacement
Mar 18, 2008 | Sony XL-2100U Projector Lamp for...
TV Shuts off, Screen Problems
The problem could be the power supply, the flyback trasformer or simply a bad connection. A repair cost for this TV set could run any where from 75 bucks all the way up to 225 or so, depending on the problem. Good Luck
Apr 29, 2007 | Sony KV-32S40 32" TV
Snowy picture and Yellowy Whites
Make sure the TV setting is set to or . A power surge may have reset your ?cable-ready? TV. Check the cable setting on your TV and make sure it is set to or . If a VCR is connected: * The VCR needs to be on channel 4. * VCR may not be ?fine-tuned? to channel 4. Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * The <3/4> switch may be in the wrong position. Locate the switch on the back of the VCR and set it to <4>. If a converter is connected: * Make sure the TV is on channel 4. * TV may not be ?fine-tuned? to channel Locate and adjust the fine-tuning mechanism until the picture comes in clearly. * Determine if the converter is bad. Locate the cable wire coming in to the room and connect it directly to the back of the TV. If the picture is clear, your converter needs to be exchanged. Give us a call or stop by your local office and we?ll switch out your equipment. Check the fine-tuning of your TV
Jan 11, 2006 | Fujitsu Plasmavision P42VCA30EH 42 in....
LG 42LG30 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
