Question about Maytag MER5770 Electric Kitchen Range
Oven light How do I remove the oven light cover to change the light bulb? The owner's manual picture does not match my oven.
    President:
  • 331 Answers
There's a sprung steel retainer clip holding the cover in place. Use a small screwdriver to pry it downward, the clip will release and the cover can be pulled straight off.
Posted on Aug 11, 2007
SOURCE:
How do i replace the light bulb in my maytag microwave oven. the bulb broke in the socket.
The cooktop light bulb(s) is(are) located on the underside of the microwave oven, and is(are) replaceable. Remove bulb cover screw, and open the bulb cover. Replace bulb, close bulb cover, and secure with screw. Cavity light: The cavity light bulb is located behind the vent grille at the top front of the microwave oven, under the bulb cover, and is replaceable. Remove 2 screws on the vent grille, tilt the grille forward, and lift it out. Open bulb cover and replace bulb. Close bulb cover, replace vent grille, and secure with screws.
For more information, your owners manual can be viewed here (scroll to the bottom of page 4):
Maytag MMV1164WB Owners Manual Page 4
Feb 11, 2015 | Maytag MMV1164WB Microwave Oven
Replace bulb
oven bulbs are special bulbs only available from an oven service agent
although the ratings are the same , the glass used is actually pyrex glass as ordinary glass will not handle the oven temperatures
Dec 24, 2017 | Viking Professional VESO130 Dual Single...
I have a Kitchenaid combo unit of Oven & Microwave. Model YKEMC308KM01, Serial # XP4603281.Can someone help me as to how to change the light bulb of the microwave. I simply dont see any openings on the...
That's covered on page 21 of your owner's manual.
If for some reason you don't have yours, you can download it free here.
To Replace:
Before replacing, make sure the oven is off and cool.
1. Disconnect power.
2. Remove glass light cover by grasping the front edge and
pulling away from oven.
3. Remove bulb from socket.
4. Replace bulb, replace bulb cover by snapping back into wall.
5. Reconnect power.
You can find handy exploded views and order parts by model number here.
Dec 18, 2010 | KitchenAid KBMC140HSS Convection/Microwave...
Burned out light bulb
You can download the owner's manual here.
If the owner's manual doesn't cover it and there's no obvious cover on the side or rear, you'll have to remove the outer wrapper.
See these files:
http://207.234.249.73/mwd/safety.txt
http://207.234.249.73/mwd/disassembly.txt
The light will be located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Most bulbs can be matched up at hardware stores, home improvement centers, and places like Wal-Mart or even large grocery stores.
Aug 22, 2010 | Whirlpool MT4155SP Microwave Oven
Replace light bulb
See these files:
How to replace light bulb in Quasar microwave oven model MQS1236H
Could that be MQS1263H?
Either way, this owner's manual may be close enough.
If it's not addressed in the manual, and there's no obvious cover on the side or back, then you'll have to remove the cover of the oven to change it.
If it's an owner the range type, you can likely get to and replace the light by just removing the grille or possibly the control panel assembly.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If it's a counter top unit, you will need to remove the outer cover and look for it near the magnetron cooling duct on the right side.
Before doing any disassembly, please see these files: safety disassembly.
You can also order Panasonic parts here.
Dec 25, 2009 | Microwave Ovens
Change light bulb in microwave
See these files:
http://wwww.microwavedisplay.com/safety.txt
http://wwww.microwavedisplay.com/disassembly.txt
The light is often located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Some halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
You can find links to helpful exploded view diagrams and part ordering help here.
Nov 28, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do you change light bulb on a Magic Chef microwave MCD11E3B
The owner's manual is here.
See these files:
Some use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Oct 09, 2009 | Magic Microwave Ovens
Light bulb issues
You can download most recent GE owner's manuals and installation instructions here.
See these files:
The light is usually located on the right side in the air duct attached to the magnetron or on the top of the oven cavity.
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
LG LRE30451SW range
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
Jul 19, 2008 | LG LRE30451ST Electric Kitchen Range
Maytag MER5770 Electric Kitchen Range Logo
565 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
