Question about Hitachi 50VS69 50" Projection HDTV
Lamp light blinking red
Tv come on ,but dont show pic and no sound red light ,and blue lights soon they go out but red stay ,and soon it go out.what could it be
    New Friend:
  • 7 Answers
From your description it sounds like the lamp bulbs needs to be replaced.
You need one of these:
http://www.amazon.com/Hitachi-50VS69-Watt-RPTV-Replacement/dp/B006C58MOI
NOTE: DO NOT TOUCH THE GLASS PART OF THIS BULB. The smudges from your fingers can show up on the image projected onto your screen and make things look blurry.
Once you have the new bulb then turn off the TV and unplug it. On the back panel there is a rectangle on the left with a screw holding it on. Use a philips head screwdriver to loosen the screw then slide the rectangular panel to the left and pull it off. Inside will be the old lamp bulb. Use the screw driver again to remove the screw holding the lamp bulb in and pull the lamp bulb out (it may be hot). Insert the new bulb and then screw it back in. Place the panel back on and screw it back in as well. Make sure the screws are tight or the TV may not turn on. You can now plug the TV back in and turn it on. If done correctly this should resolve the issue.
Posted on May 07, 2013
ctf1800
  • 4402 Answers
SOURCE: Hitatchi Ultravision LCD Widescreen acts like it doesn't want to power up
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 05, 2007
  • 18 Answers
SOURCE: Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
Posted on Jan 05, 2008
  • 1779 Answers
SOURCE: no picture/ no sound
Guest= Yours seems to be your lamp needs replacing, the buzzing is the lamp inverter trying to start the lamp and the lamp says NO.
Posted on Mar 21, 2009
  • 5 Answers
SOURCE: tv no picture 50vf820 red blue lights on?
Yes you should order a new lamp and replace it. if you are not real handy with tideous electronic tasks, consider buying the lamp in am enclosure for an additional $30
Posted on Jul 16, 2009
SOURCE: Hitachi 55VS69A , just turned off while watching.
video is not coming but audio is coming
Posted on Jul 17, 2009
OK so my jvc av56wp74 will turn on with a green pic then turns off and the blue light in front blinks
it sounds like u need a new lamp with housing if that dont work than its your main board on the inside of tv. but i would try the lamp first
Aug 26, 2013 | JVC AV-56WP74 56" Rear Projection...
Blank Screen; Blinking Blue Light.
try to re seat the bulb again dont touch it lens or anything unplug ist as u do then reset timer on it ok in menu maby it just not in tight or came loose after 1st heat
Jan 21, 2008 | JVC HD-52Z585 52" Rear Projection...
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
Blue light remains lit but lose picture. no other indicator lights flash. if i unplug the tv it will restart but lose picture again after half hour
I have a toshiba 50hm67 tv and with mine the blue light would come on and I would hear sound first and then the picture would finally come on... this happend for about a month.... next the yellow and blue light would come on but the pic still wouldn't come on until it clicked off and on by itself for about 10 min this went on for about a week. All of a sudden last night the red lights by the power light started blinking. No tv now and when the tv shut off it said lamp not working.
Sep 17, 2010 | Toshiba 56HM66 56" Projection HDTV
The tv turns on but then shuts down. will not stay on, any ideas why?
If its Sony KDF-42WE655 TV then it has self diagnostic feature and if it gets any problem inside, its red light will start blinking in specific numbers to show an error code.
Let me know how many times its red standby light blinking between 3 seconds interval.
Nov 29, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Screen went dark
Ur video ic inverter board is dead.
U need a new one.
Aug 25, 2009 | Televison & Video
Dec 06, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
65 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
