Question about Tools & Hardware - Others
How do I confirm the reason for no spark
The points are under the flywheel. gaped at .018. There was spark now there is none.
    Top Expert:
  • Tools & Hard... Master
  • 49,974 Answers
Recheck the point gap as it has been known to alter after a while. Check that the wire to the points is not shorting out or that the shut down wire is not touching earth.
Posted on May 18, 2013
No spark 40hp evinrude model 40253e serial no.j02143
Your model number says it is a 1972 40 hp motor. It has points and condenser under the flywheel. It stops the motor by shorting the points together/ground. Two small wires coming out from under the flywheel. Disconnect and check for spark. You do not say if it has run recently or if it has been sitting. Probably just needs an old fashion tune up.
Oct 11, 2014 | Boating
Need point gap specks
use a 0.25 feeler guage between the ignition module and flywheel.
Apr 15, 2013 | Stihl 017 018 Ms170 Ms180 Chainsaw Starter...
Have an older tiller w/a 5hp briggs motor, no spark,had to repair inside wire going to coil, still no fire, are there points inside flywheel i should check & does flywheel pull off
First check continuity of coil to ensure there are no breaks .If there is a wire heading in under the flywheel, it is probably going to the points. Check coil is grounded properly.
The points are normally behind the flywheel which you will have to remove using a pullers. The nut holding the flywheel on to the shaft normally loosens in the same direction as the flywheel rotates but if there is any shaft thread exposed above the nut, check the threads to confirm this.
The capacitor near the points may be shorted, disconnect it to check this with a continuity tester.
Mar 10, 2011 | Briggs & Stratton Hammering
Clearance for stihl ms 250 ignition coil
Rotate the flywheel until the magnets are under the module, insert a thin business card into the pole gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Turn the flywheel one full turn to make sure the pole gaps don't close further. Hope this helps!
Dec 28, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
CS346 no spark, replaced ignition coil and it did not help, have checked switch and disconnected it. Ideas?
Did you try a fresh spark plug gapped at 0.020"? The ignition module needs to be very close to the flywheel magnets to get good spark. Turn the flywheel magnets just under the module, insert a thin business card into the gaps, loosen the module screws and allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to release the card. Rotate the flywheel one full turn to make sure the gaps don't close up at any point. Unless this is an older saw with points and condenser, it should now have good spark. Hope this helps!
Nov 17, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
The saw wont start up
Check the fuel filter, air cleaner, and muffler for plugging. Check the condition of the fuel lines for decay or other damage. Make sure there is fresh fuel mix in the tank and be sure to shake the container thoroughly each time just before filling the tank to prevent oil starvation. Remove the spark plug and check for blue, snappy spark (plug gapped 0.020"). If weak or none, try a fresh plug. If no help, remove the left side cover to expose the flywheel and ignition module. Remove the ignition switch wire from the module coil and try for spark again. If still nothing, try setting the module pole gap by turning the flywheel magnets under the module poles, insert a thin business card into the gaps, loosen the module screws to allow the module to contact the magnets. Tighten the screws and rotate the flywheel somewhat to remove the card. Turn the flywheel one full turn to make sure the gaps don't close up at any point. Recheck for spark--if still nothing, replace the module using the above procedure. Assuming that the engine has good compression and the carburetor in not in trouble, it should start. Hope this helps!
Nov 08, 2010 | Husqvarna Chain Saw Handle Models 362 365...
Have a 5600 Gen. with 10 HP B/S engine OHV. Did great during Rita, replaced carb- changed gas-replaced plug- doesn't want to fire it seems. Where Can I find the magneto ? Are there points on the flywheel...
The magneto is by the flywheel. Depending on the age, there maybe points under the flywheel. If so you remove the flywheel and there the points are. Sometimes bugs build cacoons between points, make them inoperable. Newer engines have electronic ignition though. Follow the small wire from the magneto coil ( where the spark plug wire goes) it will either go under the flywheel through a plastic bushing, or to an electronic module. The magneto coils do fail you can test with an ohm meter. Before that test for spark. You can remove the spark plug, and let it rest on the engine to get ground, and turn the engine over. You always need 1-spark, 2 fuel . If you have spark, see if it will hit on starting fluid, if it does, then you have a carb or fuel filter issue. Those shut off valves on the bottom of those tanks, can be a problem
Jun 29, 2010 | Briggs Stratton H7159 & Stratton® 5500,...
8 hp tecumseh with old type ignition (points, etc) I intalled a new coil, condenser, points, plug, but get no spark at all. Cannot find the problem.
Make sure the flywheel key is a new one. use .020 brass or non metalic shim stock to space the coil away from the flywheel, set the points to be about .016 - .018 when fully open and make sure the ground wire on the coil is not grounded to anything.
Jun 04, 2010 | Garden
I crank and get no spark from coil wire brush contact points does the coil haved to be back so far gaped its 7 horse brigs
The coil should be as close as possible to the flywheel without actually touching it. I usually insert a piece of greeting card stock between the coil and flywheel, then tighten the coil and remove the card stock. If you're still using contact points, you may want to clean or replace them. Those are the single most common reason for lost spark in a briggs.
Mar 23, 2010 | Garden
Can you start the bike with the stator cover off?
On most bikes you can, with no problem.
Jan 01, 2010 | 2001 Yamaha YZ 426 F
Tools & Hardware - Others Logo
70 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
