Question about Acer eMachines 520-2890 Notebook
My laptop gets dim from startup - Acer eMachines 520-2890 Notebook
  • Acer Master
  • 7,627 Answers
Open the Control Panel, select Power Options, select High Performance, select Change Plan settings, adjust Display Brightness, Open the Advanced Power settings, adjust to your preference. On battery your laptop will decrease brightness, and other nonessential processes to conserve/extend battery time.
Posted on May 08, 2013
SONY VAIO PCG-61611l has a very dim screen
Normally, this is in part due to you not replacing it with what should've been an LCD. The reason why it's dim is because those diodes are not getting the required voltage to emit as it should. LCD's work under a different concept where crystals use the light modulating properties of liquid crystals. Liquid crystals do not emit light directly as LED's, because it stand for light emitting diodes.
Mar 25, 2013 | Computers & Internet
My lenovo z500 has a screen brightness issue. It very dim and it won't turn up no matter what I do?
Hi, I had this problem also and I don't know why, but Lenovo Ideapad Z500 seems to have some compatibilities issues with a new Intel video card.
So, what you need to do is rolling back the HD intel video card driver to the previous version OR go to the following path: D:\drivers\VGA\Intel\x64\9.17.10 and press Setup to install the old driver again.
That solved my problem. It's a shame that I can't upload this driver in my laptop.
Mar 18, 2013 | Lenovo IdeaPad Z500 Laptop Computer -...
My g60 -235dx laptop on startup error message say communication problem with I/O deveice, HD, flash drave , CD-ROM
G60-235dx. (2011 model, is my guess)
ok tell the full story please.
PC boots sequentially.
progress in that matters. so it seem windows unstated runs?
XP?
so you power on and what happens ?,
errors before windows logs in or after.?
my guess #1 is the main laptop battery is bad, remove it.
this pC runs on AC power pack endlessly, (AC power good)
dim screens. can be bad CCFL lamps or low power in the PC.
so again take out the battery
what flash drive, remove that, test the pC with no usb devices at all plugged in.
just an A.C power pack and no main big battery.
this PC has old CCFL lamp tubes that all go dim, fast.
turn yellow then dim the flicker and then DIE for ever.
all do. some in 2 years time never turned off. they do.
it the screen goes black use a flashlight if data is good on the screen the back lamp is croaking. (***** of CCFL tubes)
there are many cause of black screens, I can list 30. (will not)
but dim screens are only
1; main battery bad and shorted.
2: AC power pack near dead. (weak happens)
3: shorts in the main board, modules.overloading power buses.
4: CCFL dim as every one this old does, all do.
see flash light test.
http://www.pcdied.com/monitors.html#flashlighttest
Oct 18, 2017 | HP G60-235DX Notebook
While driving @ nigh, lights dimmed, and eventually engine died. It was previously having startup problems. New starter installed before above problem occurred.
Dim lights while driving means your car is running off the battery and the alternator is shot, which is why it's hard to start and the lights go dim, you drain the battery while driving and the alternator is not charging it back up.
Apr 02, 2010 | Hyundai Motor 2002 Sonata
Screen will lightup and shortly after startup it will turn dark
You have a lcd light that is in need of replacement. if you are handy with disassembly of the lcd you can replace it yourself you may have to purchase and equivlent lamp module or have it replaced by a professional at a charge.
Aug 05, 2009 | IBM ThinkPad T43 Notebook
The screen on my Compaq Evo N610c is dim
You could have a faulty inverter or a CCFL lamp, To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jul 11, 2009 | Compaq Presario Notebook
Hp nx9010 notebook red screen on startup and red bleed on picture
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 10, 2009 | HP Compaq nx9010
Can't get the projector to project an image from my laptop.
Yes you need to press something on your laptop ...maybe FN +F3 or FN+F4..but after you have image but your projector still turn of...then follow my next comment.
Takecare..
Apr 19, 2008 | Computers & Internet
Acer aspire 3000 dropped on floor. Random startup events
theres a good chance that the hard drive platletes and parking head have been damaged, although this is not a huge problem to replace, as long as your screen is working ok, then it is worth replacing. you can access it on the underside of the casing, in the largest compartment, remove all screws and the hard drive will be held in with more screws.
Apr 14, 2007 | Acer Aspire 3000 Notebook
Acer eMachines 520-2890 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
