Question about Lanzar HTG244 Car Audio Amplifier
PROTECT LIGHT COMES ON WITH 2 SPEAKERS HOOKED UP
WHEN I HOOK UP ONE SPEAKER TO MY AMP IT WORKS FINE, AS SOON AS I PUT THE OTHER SPEAKER INTO MY AMP MY PROTECT LIGHT COMES ON. I HAVE A LANZAR HTG244 AND MY SUBS ARE LANZAR AMERICAN 1000W A PIECE. HELP!!!!!!!
  • taylor corley Feb 06, 2008
    my amp power protection light comes on no matter what speakers connected or not....and when i hook the kicker 12" comp to the 1000w amp it makes noises and hits without the volume even bein turned up.....what's the deal?
    Novelist:
    Champion:
  • 219 Answers
Go to this website page and see if any of this applies to your problem. http://www.caraudiobook.com/car_audio_amplifiers/car_audio_amplifiers.htm
Posted on Aug 12, 2007
I have a 1400 watt cruch amp & i hooked it up myself. when i turn the radio on the power wire on the amp comes on, bt if the audio cords are hooked up, the protection light comes on. if i dnt hook the...
Should the amplifier go into protect mode, simply disconnect all RCA and speaker leads, while keeping +12 volt, power ground and remote leads connected.
1. Now turn the amplifier back on, and if the diagnostic LED lights, the amplifier has an internal fault.
2. If not, plug the RCA cables back, and reset the amplifier. If it goes into diagnostic now, the fault lies in the input, either with bad cables or source unit.
3. If the amplifier seems fine with RCA cables plugged in, connect the speakers, one at a time, and if one of the speakers or its wiring is faulty, it will activate the diagnostic
system.
Dec 08, 2010 | Mobile Authority A-500 Car Audio Amplifier
I have a dual electronics 4 channel amp that goes into protect mode as soon as i throw power to it
unplug all the speaker from amp then power on. if you still have a protect light amp is bad and if you have no protect light continue to hook up each speaker one by one while amp is on till you get a protection light and that speaker would be the source of your problem
Jun 02, 2010 | Dual Car Audio & Video
Protection light keeps flashing on and off
try hooking up only the power ground and remote see what happens if protection light is on then u have a problem with amp if it goes off then hook up rca if still off then hook up speaker wire if it turns on then u have a prob with speakers
Feb 02, 2010 | Kicker ZX10001 Car Audio Amplifier
Amp burned out but fuses still good?
this is caused by inproper wiring from the speakers/subs to the amplifier.. an amp will still put out power to subs and speakers when it's wired improperly but it won't last for very long doing it... 6 months is longer than usual....
Dec 05, 2009 | MA Audio M1900XE Car Amp
Xm-2002gtr amp keeps kicking protect light on
check your amp and speakers and make sure their both hooked up 4 ohm instead of 2 ohm because if you have 1 set of voice coils on your speakers they can only be hooked up four ohm and not bridged to your amp because if you keep trying this you will lock up your speakers if the speakers are only 4 ohm than just hook them up regular to each channel on your amp if your trying to brigde four ohm speakers to your amp it will keep going into protect or worst case scenario you will fry your speakers and you can check your ohm with a ohmmeter trust me my brother owns a stereo shop
Oct 19, 2009 | Sony Car Audio & Video
Protection Light Comes on
Sounds like you have an ohm problem, Tryy hooking the positive from one speaker to the negative on the other speaker. Then hook the negative from the first speaker to the negative on your amp and the positive from the second to the positive on the amp this will drop your ohm load and the amp should stop going into protection.
Mar 08, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sony explode amp for my car
Try disconnecting everything but the power connections. If the protection light still comes on, then there's a problem in the amp. If it goes out, then there's a problem elsewhere. In that case, hook up one speaker cable at a time and power on. If the protection light comes on, then either that speaker is bad, or you've got too many speakers connected to that one amp output. Too many speakers connected together can cause an overload and trigger the protection circuitry, or worse, blow out something out.
Hope this helps, and please rate my advice.
Thank you, and good luck!!
Feb 04, 2008 | Car Audio & Video
VB101PK REV 13, AMP WITH SUBWOOFERS
was the amp hooked directly to the box? You probably rattled the power connections from the circuit board like I did on a PT 800 watt amp.but check amp fuses first.
Sep 15, 2007 | Visonik V117SX Car Audio Amplifier
Amp not working
1. Did you witness this amp ever working if not then you may have a blown amp. Hook up the speakers, get a portable player with a head phone jack get one of those cables with a headphone plug on one end and RCA's on the other plug the portable player into the amp and hit play. If sound comes out then your problems are elsewhere. If not I'm afraid your amp is probably toast. If the OHM rating of the speakers are too low for the amp then the amp will go into protect. This will be indicated by the protect LED lighting up or the power led changing color from say green to red.
Jun 28, 2007 | Kenwood KAC-729S Car Audio Amplifier
Lanzar HTG244 Car Audio Amplifier Logo
115 people viewed this question
Top Lanzar Car Audio & Video Experts
Mike Duncan
Mike Duncan
Morne Olivier
Joe Alexander
Joe Alexander
Are you a Lanzar Car Audio and Video Expert? Answer questions, earn points and help others
