Aoc l32wb81 The green led indicates the unit is switched on however there is no picture or "no signal" warning. Neither the remote nor the tv side panel "on/off" button can turn the green led to red.
  • Jon Henry May 10, 2013
    Fixed it, I removed one of the hdmi cables and the tv came back to life. Returned cable and all is good.
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
The set is not responding to remote control. There should be a voltage loss, from its main power retulator board.
Posted on May 08, 2013
SOURCE: TV not turning on.
Mine was doing that and I ordered a replacement power supply board for it and now it work. It's fairly easy to replace.
http://www.partstore.com/GetModel.aspx?MfgName=Royal+Philips+Electronics&BrandName=Philips&ModelNumber=37PF7320A37&page=16
Posted on Mar 27, 2008
SOURCE: TV will not turn on/black screen/picture/green LED is red/blinkin
I had the same problem for my TV which was model number: 42PF9631D/37 and I went to get the software update at http://www.p4c.philips.com. Type in your model number, then click on the right model. Then click on software & drivers in the left column. Then download the correct software update to a flash drive. The flash drive must be completely empty except for this file. Then unplug your TV, and plug the flash drive into the USB port. Plug your tv back in, and the software update will upload. It fixed my TV instantly.
Posted on Jan 09, 2009
  • 2336 Answers
SOURCE: Red power indicator light is blinking
The flashing light indicates a short circuit inside the power supply circuitry. This type of repair is not a DIY without a multimeter, desoldering iron and hand soldering skills. I repair these power supplies, if you need further info write to jah2mil@hotmail.com
Posted on Jun 08, 2009
SOURCE: My LCT3201AD is plugged in and the standby light
Remove the power supply and replace the three (3) capacitors soldered to it. They will be rated at something in the neighbrohood of 16v. Replace them with larger capacitors, something in the neighborhood of 35v.
Posted on Jul 12, 2009
rulds2008
  • 3866 Answers
SOURCE: Polaroid 4011-tlxb. Power to tv and it was turning
if you replaced the supply board then there is issues with the decoder board as you would need to chec kthat and see if its not the issue.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Sep 22, 2009
Model no. 32A33 lcd sharp tv. no picture. power red led glows. with remote on green led comes. no picture. some times sound is coming.
Main board fault. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Apr 04, 2014 | Sharp LC-32A33M LCD TV
VIZIO 42 CLASS RAZOR LED SMART TV M420KD picture has lots of green ghosting and thin white vertical line through left side of screen also
Hi Charlene,
please try with video input from any device,and i think you are using local antenna and it has gain problem or your tuner section of the tv is not working correctly.
if distroted pictures comes with video input signal it is video amp and processing unit problem.
you have to go for repair shop for fix that.
regards,
nuwan
Jan 24, 2014 | Vizio Televison & Video
Toshiba regaza 37rv635db wont turn on
seems like capacitor problem, chack them and if thay have exploded replace them.
Aug 25, 2013 | Toshiba 37RV635DB Regza 37-inch Widescreen...
Lcd tv troubleshooting
Check for power supply trouble. The green LED on the front panel should light if power is getting to your TV. The "no signal" indication may mean no antenna or cable input is detected
Aug 21, 2013 | Televison & Video
AOC L32W961 No picture during initial setup problem I just bought this TV today. When I turn it on, the light turns blue, the screen says please wait for about two seconds, then the screen goes black, and...
If this is an LED set I'd look at a backlight error, some lamps in the panel are bad and the power supply is shutting down the LED supply voltage because of over current or under voltage.
Dec 24, 2017 | AOC L32W961 32 in. TV
My tv turns off and on and sometimes wont respond to the button or remote. I've taken the back off and all capacitors look good. Some people say motherboard some say power supply. Any ideas?
Tv turn on.Power LED indication light on solid green,have picture.Only problems it wouldn't respond to any controls wright?It the Tuner signal motherboard board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Oct 17, 2010 | Samsung LN32C450 32 in TV
AOC color monitor model 5En...during power on all led lights blinks then stops blinking without display action. all led lights on no more action observed.
actually if u repair an aoc monitor alone without getting connected to cpu once u switch on the monitor all led's will lit on ( green light ) it will remain on situation until u connect the vga connector to cpu that's the time led's will lit off and only the power led will remain in green condition.some aoc 5en once u power on power led is in green condition and if not connected to cpu it will be in orange condition.hope u get some idea but i am not sure if it will work with ur monitor. but as long as LEDs lit on i think no problem with ur monitor.
Nov 02, 2009 | AOC 5 En 15" CRT Monitor
My son bought an AOC LCD TV (model L24H898) last month and connected his laptop and XBOX to it. Yesterday we lost internet connection and the screen on the TV went blank. Now none of the button on the TV...
According to the manufacturer, to reset the entire unit do the following:
1. Press and hold "Menu" and "Channel +" on the TV. 2. Using other hand, press the power button. 3. A small screen should appear in the top left part of the screen. 4. Using the remote, select "Memory Recall" and select. 5. Power off and re-boot the computer 6. Run channel auto-scan to regain the picture.
Aug 28, 2009 | AOC L24H898 24 in. LCD TV
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Dlp tv will not "fire up"
if your tv is on warranty take it back to the supplier.the problem with your tv is in the power supply there is a open regulator in that circuit along with the H .O. Transistor there is a black that feeds from the HOT to the flyback which also needs to check probably it is also open.good luck my friend
May 06, 2007 | Samsung DLP HL-P5663W 56" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
