Question about Sony Bravia KDL-40V4100 40 in. LCD HDTV
GREEN POWER LIGHT/BACKLIGHT ON. NO DISPLAY, NOTHING
When I plug it in, I hear the power relay click on. When I turn on the TV's power, the green power light illuminates. The buttons at the top of the TV don't work (except power) and all buttons on my remote don't work (except power). I guess that since the LCD's backlight is still functional, there's hope, but there is NO display whatsoever. If it helps, after opening that small little door on the back with the wiring harnesses, the CN3251 port is vacant. No resistors are popped either... HELP!
    Top Expert:
  • Sony Master
  • 74,136 Answers
If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.http://electronicshelponline.blogspot.com/
Posted on May 08, 2013
Visio VP504 fhdtv10a - When I plug it in, it has an amber logo light and makes a click noise (like a relay). When I press the power button nothing happens.
These are problems gradually developed in TV over the years. You may have to look for any dry solder, change the capacitors that look 'puffy' and try.
Jul 30, 2012 | Televison & Video
Mitsubishi Medallion does this
hi there,
Check for bad solder on convergence module. May have bad stk's. Do not neglect looking for bad solder on dsignal and defl boards. Mitsubishi is very prone to bad solder.
`jack
May 26, 2008 | Mitsubishi WS-55411 55" Rear Projection...
Tv will not turn on and green light blinks 3 times constantly
Your main power board located in the center where your power cord will plug into is going bad, actually it's just a relay. I have the same problem, tv works for hours til relay overheats, then tv shuts off and tries to restart, hence the clicking and the 3 green flashes, mine will actually restart after 15-30 minutes. search online for the board, ranges anywhere from 150-280. I haven't found anyone to sell just the relay. I am trying tv with rear panel removed and cover removed from relay to see if relay will not malfunction? Board is a simple plug and play, just remember to have the tv unplugged.... you can actually remove the rear panel while on it's stand, just don't remove the screws holding the base onto the tv.
Jul 14, 2011 | Toshiba Regza 52XV645U LCD TV
Lost picture. When using main power button, the
Tries unplug,replug the tv an hour later might work.But this a temp.fix,must replaced the backlight video board sooner or later.
Dec 22, 2009 | Planar PDP-42BK 42 in. Plasma HDTV
No picture on my philips 42PF7321D/37
Bad caps in the power supply must be replaced .
Jul 21, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Hey got a good one for ya....The TV had fallen and there is a corner on the plastic cabinet that is broken away.When plugged in and turned on the blue power on indicator will light up and you can hear a...
LCD sets sometimes will not power up until the backlight boards power up. the backlight boards have SMT fuses that open. and driver FETs (commonly also SMT) that short.
check the backlight circuits first.
Dec 05, 2008 | JVC LT-26WX84 26 in. LCD HDTV
No picture, no sound.
Hi i have a pilips 42" plasma tv (42PF5320/79) i can hear clicking the green light is on and the tv will go into stand by if i press the power button and the red light also comes on .I have turned it on and off and it works now nothing just the light on the front as if its working looking at the back through the slots two green lights come on then the tv clicks and they turn off,thanks
Aug 06, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sharp LC-45D40U Won't Power On! Need Help!
If doesn't give error code most probably is something wrong with 5 and 3.3 volts lines. Check first the power supply and try to start the tv with all connectors removed. Let only the one between main pcb and power supply. Look for shorted voltages lines.
Apr 10, 2008 | Televison & Video
Hyundai plasma model HP-4200
Hello ****, I have the same problem. However. I manage to get the TV on by pulling the cable out and then plug it back in again several times. A couple of times just after you have heard the first click and the a couple of times just when you hear the second click. Sudenly the TV decided to work again. I think it must be a problem with one of the two relays that sits next to each other near the centre of the TV. If you take the back of and then plug the power back in you will see the two lights next to those relays come on and then die out when the relays let go. This is what hapens if the TV doesnt work. If the TV works those lights/LED's will stay green and the relays will hold on and feeding the TV screen. I will probably try to see if I can buy replacement relays and replace these. If I can get hold of them, then probably I would take the existing relays appart to see if I could see any fault. If those relays ar ok and the replacement relays appear in the same manor like the old ones I would look for problems before those relays. Maby order a new circut board from Samsung.
Con
Jan 08, 2008 | Televison & Video
Open Questions:
See all Sony Bravia KDL-40V4100 40 in. LCD HDTV Questions
Sony Bravia KDL-40V4100 40 in. LCD HDTV Logo
65 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
