Question about Home
Need door stop - Home
Need door stop. door is 5inches off dirt and no backing or stud in stucco wall
    New Friend:
  • 10 Answers
Fabricate metal bracket stopper
Posted on May 07, 2013
Floureon 3in1 stud finder instructions
Put it on the wall, turn the sensitivity know until it beeps, turn it back a fraction until the beep stops. Run the device across the wall. If it does'nt beep, you were on a stud the first time!
Floureon 3in1 stud finder instructions Google Search
Sep 24, 2017 | Measuring Tools & Sensors
If ProteShield is put on a beige colored stucco wall, will it dry clear, or will it darken the stucco when it dries?
Good question. Only way to know for sure with these products is to do a test on some out the way, unnoticeable spot, and test there for color change. Then be guided accordingly.
Aug 31, 2015 | ProteShield 1-Gal. Elastomeric Waterproof...
How to use a stud finder
The stud finder works by picking up density of the product it is pressed and slid on..Turn your stud finder on make sure the ok light is on...then slightly press it against the wall or surface you are working with,,then slowly moved it right or left still against the surface. As the finder starts to detect more density "thickness" it will. Glow or beep depending what type you have..It will get brighter,louder or what ever it signals are while crossing the stud beneath the surface..keep moving until it stops then move back
again until it stops.....mark or note the position where the signal starts then find the middle...2x4's are 1 1/2 inches across...so center should be 3/4 of an inch...good luck..
Aug 04, 2014 | Stanley 77-720 Stud Sensor 200
Unable to fix CUA-854L router
If you are able to connect, then lose the connection, there is usually some interference somewhere between you and the AP that is weakening your signal.
If you have a smartphone, download the Wi-Fi Analyzer App to it to see what the signal strength is in the location you are accessing it from.
Things that cause interference include:
  • Florescent lighting
  • Microwave Ovens
  • Refrigerator or other appliance with an electric motor.
  • Walls with metal studs or chickenwire in stucco walls
  • Walls with electrical wiring inside.
Nov 10, 2017 | Computers & Internet
I have plaster walls in an old house the stud finder just keeps beeping how does this thing work?
Your stud finder keeps beeping because old plaster walls have lath boards behind the plaster that are attached to the studs and running horizontally. Try adjusting the sensitivity of the stud finder by placing it on the wall and turning the sensitivity down until it just stops beeping. Then move it back and forth in a wide enough arc to be sure that you have crossed a stud, turning up the sensitivity ever so slightly until you get a tone when you cross a stud. Hope this works out for you.
May 08, 2011 | Stanley Garden
I have a 9-volt Strait-Line Stud Finder with 3 red LEDs and 1 green LED at the top end to mark the Stud Edge. I would appreciate it if I could receive step-by-step instructions on how to use the stud...
I suspect there are several models but I have one model. 1) Turn on the unit (if the green light is blinking replace the battery). 2) Calibrate the unit by holding it flat against the wall for 5 seconds until the red light goes off and the beep stops. Make sure you do not move the unit during the calibration or position the unit over a stud (try a spot 6-12" away from the corner of the wall - most studs are on 16" or 24" centers and the wood/metal stud is 1 1/2" thick). If the unit keeps beeping or the red light doesn't go off during the calibration, move the unit sideways 5-8" in case you are above a water pipe or other reason for "too deep a surface" for the unit.
3) Do not lift the unit off the wall or you will need to recalibrate it. Slide the unit across the wall. When the upper red light comes on and the beeping starts, that marks one edge of the object in the wall (stud). Continue until the red light goes off and the beeping stops. Mark the other edge of the stud by moving the stud finder in the opposite direction and marking when the red light comes on and the beeping starts. The center of the two marks is the center of the stud for securing anything to the wall.
If the beep persists over a 6" range, I'd check if you have any old cast-iron pipes or a door/window that was relocated in that wall. Repeating the test in a few places vertically along that spot of the wall will tell you there is a consistent large object in that location. Neither a filled in window or door will run the entire length of the wall but you could be finding the headers (the vertical framing of the opening would probably be ~4-6" wide (double or triple stud depening on the needs of the house design)).
I hope this helps.
(on another stud-finder that I borrow, you press the buttons on the right and left side to turn it on. Calibrate by holding it to the wall for a short while and then slide it across the wall. Note when the top red led lights and the beep starts. Repeat in reverse to find the other side of the stud.)
Sep 17, 2010 | Garden
Because of broken (from a freeze) water pipes, I have a 2 foot by 4 foot hole in our outside stucco wall (a hole made by a plumber). I have cleaned out the hole, cut and placed plywood to match the hole,...
stucco really is easy. just go to HD or Lowes and get stucco patch. it is better to get the kind you have to mix yourself. Make a small batch according to the instructions and practice on a scrap piece of plywood so you get the feel for the material. You can lighten up on the water if the finish is rough. If the finish is smooth, then apply the stucco mix with the less water first and build it up until you have it about 1/8 to1/4 inch shy of the finished surface, then make another batch that has more water then called for to finish it out. PRACTICE on a scrap piece of plywood. Good luck.
Jan 27, 2010 | Bon Tool Stucco & Plaster Tools Co. Angle...
How do you fix a leaking outdoor wall spigot? Even though the handle is turned tightly off there remains a drip. Spigot seems to be all one piece and attached into stucco wall. Is there a way to repair...
Sometimes, depending on the type of the spigot, you can unscrew the valve from inside the spigot. There would be a hex nut immediately under the part where the handle on the valve stem comes out. BE CAREFUL: Outside spigots rarely have independent shut-offs (ie, in order to work on it, you will have to shut off the main water supply). Once you start down this path, you need to be fairly certain there is a replacement available for your type of spigot. If you remove the valve, there is no assurance that you will be able to get the original back in without making the leak worse. Please have an emergency back-up plan in place.
Sep 16, 2009 | Plumbing
Waterproofing house stucco
First of all, this is a problem the guys from Home Depot wouldn't know how to fix.
Years ago, maybe when this post was originally written you may have needed to do a two coat system.
Your best and actually easiest option will be to power wash your stucco, to remove any dirt from the surface.
Then you will need to mask everything up tight because you're about to spray all the stucco. Cover any concrete and plants nearby, (anything that is closer than 10 feet from the stucco.)
Then go to Sherwin-Williams and purchase Loxon XP this is a one coat system however if you have larger cracks in the stucco you will either want to caulk them with an elastomeric caulk (if you don't have too many) or apply a second coat of Loxon XP. If you're a do it yourself kinda of person you can go to home depot and rent a spray machine. While your spraying your gonna want to back roll it. www.outbackpaintingusa.com
Oct 01, 2008 | Measuring Tools & Sensors
Home Logo
363 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
