Question about Uniden SC230 Handheld Racing, Nascar Scanner NEW
Reset programmed how do i master reset my scanner
    Top Expert:
  • Uniden Master
  • 42,882 Answers
If you refer this inquiry directly to Uniden support, you will get a solution
Posted on May 07, 2013
How do I do a MASTER reset? My son played with it and now I need to enter everything all over. Thaanks
I don't see a master reset for your scanner, but powering it on while holding in the 2, 9, and HOLD keys works for many Uniden scanners. Otherwise, programming 0 (zero) into any channel will clear it, and programming a new frequency into any channel will delete/overwrite the previously programmed freq.
Bill B.
Listening in since the 60's
Jan 01, 2011 | Uniden BC80XLT Handheld Scanner
I had the batteries out for a while and when i put them back in it won't do anything(can't program). when i push and hold the pri button in the lower right hand corner of keypad "pch loc out" appears...
To reset you BC60XLT:
1. Power the scanner OFF.
2. Press and hold the 2, 9, and MANUAL keys while you power the scanner ON.
Bill B.
Oct 12, 2010 | Uniden BC60XLT Handheld Scanner
Need to do a master reset on pro 84 sanner but don't have manual
To RESET the PRO-84, turn the scanner OFF, then hold in the 2, 9 and HOLD keys and power the scanner ON. The word CLEAr will appear on the display to confirm the RESET.
While the manual for the PRO-84 has not been posted by Radio Shack, it is essentially a red PRO-83. You can download/print the 83 manual here:
http://scancat.com/OnLineHelp/OEM_Radio_Owners_Manuals/RadioShack-OlderManuals/Pro-83/pro83.pdf
For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
Bill B
May 19, 2010 | Radio Shack Pro-84 Handheld Scanner
I have pro 135 from radio shack. How do I reset it and keep the channels that are programed in it?
The RESET function will clear everything that you have programmed into the scanner and restore original factory settings. You can, however, restore the 150 pre-programmed frequencies after a RESET.
To RESET:
- Power the scanner OFF.
- Hold down the 2, 9, and PSE keys and power the scanner ON.
- CLEAr appears on the display as the scanner resets.
- Do not power the scanner OFF until CLEAr disappears from the display.
To restore the original 150 pre-programmed frequencies:
- Turn the scanner power OFF.
- Hold down the 3 and ENT/PGM keys and power the scanner ON.
Bill B
Apr 28, 2010 | Radio Shack Pro-82 Scanner
How do I do a master reset on the pro 83 scanner
To reset the scanner (clear a problem or keyboard lockup):
- Tune the power OFF and then back ON.
- Insert a pointed object (paper clip, ballpoint pen tip, etc) into the RESET opening on the side of the scanner and gently press the button inside.
If the RESET does not clear the problem you can INITIALIZE the scanner, but this procedure will clear/erase all information that you have programmed into the scanner.
- Power the scanner OFF and then ON.
- Press and hold the TUNE/CLEAR button while pressing the reset button as above. The display will momentarily blank.
- When the display resumes, press TUNE/CLEAR again.
Need the manual for your scanner? You can download/print it here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
BillB
Feb 08, 2010 | Radio Shack Pro-83 Scanner
How do I reset the scanner frequencies all at once; what is the button combination to push
There is no master reset/clear function on this scanner, but with only 10 channels it's fairly simple to enter "0.0E" on each channel to clear the programmed frequency.
Sep 20, 2009 | Uniden BC60XLT-1 Handheld Scanner
I,lost all programming, even weather, is there a master reset for this ?
Hold down the #2 and #9 buttons together when you turn it on and it should do a reset.
Jul 30, 2009 | Uniden BC60XLT Handheld Scanner
I have a uniden ubc73xlt handheld scanner,can't program channels, keeps saying locked out, have tried to unlock as per instructions but not unlocking.
Try a master rest:
If the scanner's display locks up or stops operating
properly, you might need to reset the scanner.
Caution: This procedure clears all the information
you have stored in the scanner. Before you reset the
scanner, try turning it off and on to see if it begins
working properly. Reset the scanner only when you
are sure it is not working properly.
1. Turn off the scanner.
2. While holding down 2, 9, and Hold, turn on the
scanner. It takes about 3 seconds to initialize
and CLEAR appears.
Feb 22, 2009 | Uniden BC72XLT Handheld Scanner
Radio Shack PRO-91 scanner keypad doesn't work
Try a master reset. You will lose all of your current programming but it resets the unit back to its original state when you purchased it. here are the directions from page 53 in your manual.
Resetting the Scanner
and CLEAr appears.
elijam1
http://www.scannermaster.com/?Click=37131
Dec 25, 2008 | Uniden BC72XLT Handheld Scanner
Uniden SC230 Handheld Racing, Nascar Scanner NEW Logo
55 people viewed this question
Top Uniden Computers & Internet Experts
castletech
castletech
Brett Duxbury
Brett Duxbury
Are you an Uniden Computer and Internet Expert? Answer questions, earn points and help others
