Question about Health & Beauty
Amplifier a7 electic scooter
I want to know how to wire up this a7 electic scooter. Any sort of diagram will help on how to wire it up from the batteries to the motor, ignition, kill switch, and charger.
Does the owners manual have a wiring diagram in it for the rascal 230 electric scootetr
Hi marilyn, Sadly no mobility scooter manual will give you such information, i willing to help , what do you want to know ? faulty lights , thinking of fitting a new controller ?
Regards
Rob
Feb 15, 2016 | Electric Health & Beauty
Wiring diagram download
hi Bruce, I 'm very sorry but you never get a diagram unless someone reversed engineered the scooter wiring but to be honest , it's not required ...
Is there a problem ? want to rewire the scooter then i 'll only need to know the controller ..
Regards
Rob
Jan 10, 2016 | Zip'r Mobility 3-Wheel Compact Scooter
Wirng diagram for a sc50 sonic pride scooter power switch, horn,horn button,power meter,etc.
Bad boy (or girl of course)! Should have noted everything BEFORE taking it apart. But then you now know that and probably did before .... Oh well, we've all done it... Once. I have a Pride scooter, but not this one. MAYBE someone with a sc50 Sonic will be kind and post a photograph of the underside of their control panel while still wired?? This would help our friend a lot.
Sadly Pride Mobility aren't known for useful things like wiring diagrams or meaningful owner's manuals.
Jun 22, 2014 | Pride Sonic 3 Wheel Portable Scooter
I am looking for a wiring diagram for the charger on a celebrity scooter legend mod# e675
hi ,I don't have access to the wiring diagram however I worked on most scooters so can I ask what the problem is , has the wiring loom got damaged ? if so please tell me the name of the motor contoller under the seat a blue or black box. I have rewired over 200 scooters so it not a issue. Not one failure.
Please let me know how you get on.
Regards
GeWiz.
Dec 18, 2009 | Pride New Mobility Celebrity 3 wheel...
Tow bar electics
Hi, I don't know whether you have sorted this or not but you MUST NOT connect directly to the cars lighting system, it will assume that there is an overload and switch the circuits off. You must use a bypass relay system of some sort, or preferably a vehicle specific wiring kit which will either plug directly into the REC (fuse box) in the left rear cubby hole in the boot or if you don't have the REC then a different wiring kit plugs into the lamps and has a towing interface with it. If you are not sure what you are doing then best contact your local towbar specialist.
May 09, 2009 | Car Audio & Video
49cc scooter
i have found a website that has scooters from 50 to 750 and here it is http://www.hondarestoration.com/tech_tips.htm
Mar 13, 2009 | 2000 Sachs Roadster V1.6
Cadence A7 HC not working
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible problems, read through the following page:
Amp in Protection - Troubleshooting
Let me know if you have any other questions.
Aug 18, 2008 | Cadence A7 HC Car Audio Amplifier
Health & Beauty Logo
184 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
