Question about Dual Electronics XD1222 Car USB Player
Radio won't play
I'm installing a Dual XD1222 CD player into a 1999 Corolla. I bought a wiring harness and connected all wires as directed, but after plugging the unit in it doesn't turn on. Any ideas?
    Top Expert:
  • Dual Electro... Master
  • 34,763 Answers
There may be differences between the color coding of the adapter wires and the color coding of the vehicle. Check to determine whether the wires were functionally matched, not just matched by color. Check for missing or poor connections
Posted on May 07, 2013
2 Suggested Answers
  • 41 Answers
SOURCE: dual xd1222 radio fit a 97 stratus wire harness
Basically the radio will fit but since harness differs between some chrysler products, you need to find the pigtail that will fit the Dodge harness and give bare wires to connect the Dual's respective wires. An example of this can be seen at http://www.hifisoundconnection.com/Shop/Control/Product/fp/vpid/2669860/vpcsid/0/SFV/30046
I have found similar pigtails at Walmart, Best Buy, and some autoparts stores. Crutchfield includes all this based on your purchase - just a thought.
Posted on Feb 13, 2012
Cant get the power to work on a xd1222
If the radio is correctly installed and, there is no power on the vehicle's accessory wire when the key is turned on, check the vehicle's radio fuse. If you connect the red to constant 12 volt along with the yellow radio memory wire the stereo WILL NOT TURN OFF. There is nothing strange about that.
Oct 14, 2012 | Dual Electronics XD1222 Car USB Player
How to replace a starter on toyota corolla 1999
Make sure you have your radio code if needed otherwise the radio won't work after this. Disconect battry, Unbolt main wire from starter, disconect switch wire from starter, unbolt starter, remove starter, fit new starter, connect switch wire, connect main wire to starter, connect battrey, start a couple of times to make sure all ok, input radio code.
Jun 24, 2012 | 1999 Toyota Corolla
Dual xd1222 radio fit a 97 stratus wire harness
Feb 12, 2012 | Dual Electronics XD1222 Car USB Player
I had bought a dual xd1222 aftermarket stereo. i bought a gm2000 harness for it to hook up in my 2002 chevy cavalier. i have all the wires connected but when i hook it up in the carit will not work. what...
check the fuse behind the stereo and in your fuse box first off and make sure the power wire/ignition wires are on the correct pin. do this with a test light for verification. also check the ground wire. after you test and connect these 3 wires, the stereo should turn on. Your wiring harness may not be done correctly so visual verification with a test light would be the best thing before starting a car install. If this still does not work and the stereo you took out did, it is a malfunctioning unit.
Sep 11, 2010 | Dual Car Audio & Video
I just bought the xd1222 car radio, but the components in my 01' dodge neon and the radio do not match up. How do i install the radio?
www.dualav.com/support/manuals/xd1222.pdf - Similar
this site is very helpful i just bought a new used vehicle with the same stereo system and i have had no problems since going to this site.
Aug 01, 2010 | Dual Electronics XD1222 Car USB Player
Install dual xd1222 into a 1993 dodge intrepid
The best way is to get a stereo installation kit designed for your car. It will have the surround for the new stereo to fit where the stock stereo fit. Also, it comes with a wiring harness that you connect the new stereo to then it plugs in to the stock radio plug. Most local automotive stereo stores should carry them.
May 12, 2010 | Car Audio & Video
I just hook up an after market cd player up in my 2001 chrysler 300m and the radio play but the cd player want play, it turns on and everything just no sound. do anyone have any ideas of what i did wrong?
DOES THE RADIO PLAY? HERE ARE THE FACTORY WIRING COLORS FOR THE RADIO HARNESS, RECHECK YOUR WORK. IF U FIND NOTHING THEN IF THE RADIO PLAYS THE CD PLAYER IS DEFECTIVE, IT HAPPENS BELIEVE ME.
2001 Chrysler 300M Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis or Strap
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange
Car Stereo Antenna Trigger Wire: Orange/Red
Car Stereo Cell Phone Mute Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Located under the rear deck in the trunk.
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Nov 05, 2009 | 2000 Chrysler 300M
Need a new wiring harness for my Dual XDMR7710
Look in your local phone book yellow pages under stereos for a local (not big name) stereo installation store (there will be one) and go there.....you will thank me!
jack
Feb 22, 2009 | Dual XDMR7710 CD Player
Dual Electronics XD1222 Car USB Player Logo
119 people viewed this question
Top Dual Electronics Car Audio & Video Experts
xxxxxx xxx
Matthew Spark
Matthew Spark
Are you a Dual Electronics Car Audio and Video Expert? Answer questions, earn points and help others
