Question about Fishing
I just bought a Shakepeare baitcasting reel & rod. I set it up and the first cast knotted the line up, I fixed it and now it only casts like 5 feet. How do I fix it?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 99 Answers
Take all old line off then spool on new line
Posted on Aug 04, 2013
4 Suggested Answers
  • 42945 Answers
SOURCE: Snarled line on low profile reel.
readjust your drag and use your thumb more when casting . free spool reels still need casters help
Posted on Apr 26, 2010
  • 677 Answers
SOURCE: how do you cast the reel so the spool dosent
On the side of the reel there is a knob that you adjust for the spooling.As a rule of thumb you adjust it so when you have a lure on,click the release button and let it spool out,it will only drop about 4 feet.Now! tighten it a fraction.Start casting and it will not go very far.Just before the lure hits the water,you put your thumb on the spool.Hard at first and then less as you get used to it.You can then adjust the spooling knob to go a bit further every time.You use your thumb on the spool to adjust the last 10 feet of line.Use a lure with no hooks on it to practise.It's called a plug.Hope this helps and you reel in the big one's
Posted on Sep 23, 2010
SOURCE: my penn 950SSm reel doesn't
Try flipping it forward.. if that doesn't work... there must be a small spring inside broken. Just take it completely apart on a table. once apart look at the bail assembly, u should be able to find the broken piece. Take both broken pieces down to your local hardware store and ask someone for assistance. Someone should be able to help you find a piece very similar.
Posted on Oct 30, 2010
How can I get my reel to cast smoothly?
Hey Ken, Neil here from Dark Side Reelz. it boils down to over oiled bearings, or bearings that require cleaning, your spool shaft only rides on 2 or max of 3 points, (depending on reel make) each of those points contains a bearing the spool shaft seats in those bearings any build up will greatly reduce casting distance. I specialize in reel cleanings, rebuilds and restorations as well as custom work like upgrades and super tuning. If you would like to read some really good info on what you can do read this article I wrote http://ezangler.com/tackle-box/gear-tips/the-reel-truth/ here is the link to my webiste as well www.darksidereelz.com
Jul 05, 2014 | Generic Ardent C400 Fishouflage Bass...
Abu garcia silver max reel manual
those are your magnetic cast control. it is a magnetic braking system. i suggest setting it at "5" and dont adjust unless you are casting into the wind, if that is the case turn it up to towards maximum and keep your casts low to the water and use heavy baits. its a great tool to help eliminate backlash.
Apr 05, 2013 | Abu Garcia Pro Max Baitcast Reel
Howtoseyupaspincastingreel
use 10# test line or heavier. use 3\8 oz lure or heavier. set magnetic control to "5". tighten small silver knob under the reel handle down until the spool will not turn when you push the thumb bar. loosen the same silver knob while you have the thumb bar pushed and adjust the knob tension so that the spool stops turning when the bait hits the ground. this is basic tuning for any baitcasting reel.
Jul 08, 2012 | Abu Garcia Pro Max Baitcast Reel
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Bird nesting I think something is missing like a washer on the spool shaft under the cap and I don't know what should be there
common problem especially with new users who are used to fixed spool casting, when casting with a multiplier you should keep your thumb over the drum so you can slow down the drum as your cast slows to fall in the water, if you had a drag washer you wouldnt be able to cast, you will get the hang of it with practice, but even with 30 odd years of use i still ocaisionaly get a nest.
Jul 06, 2010 | Pinnacle Inertia Baitcast Reel
How do you cast it? I kept getting tangled...the ...
Put thumb on spool, flick into free spool. look at spot you want to cast too. Cast SMOOTHLY taking thumb off as you get to about 45* to front. *IMPORTANT8 THUMB ON SPOOL THE INSTANT THE TERMINAL END OF LINE HITS WATER!!!!!!!
May 19, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Wont cast
if u pushed the release button it will automatically lock if u real it wen u are finished casting make sure u put d catch bak on for the line to retrieve to ur reel
Mar 22, 2009 | Pinnacle Solene SLP10 Baitcast Reel
Fishing Logo
140 people viewed this question
Top Fishing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Steve P
Steve P
Are you a Fishing Expert? Answer questions, earn points and help others
