Question about Lowrance 116-20 : GlobalMap 3600C iGPS - GPS receiver : GPSS364
NOT PICKING UP SATELLITE - Lowrance 116-20 : GlobalMap 3600C iGPS - GPS receiver : GPSS364
Why does it take a long time for a satellite
Yes, sometimes it takes a long time to find a satellite, works best when it is fully charged, then it finds the Sats quickly
Jun 01, 2014 | Tomtom ONE 3rd Edition GPS
My tomtom is not receiving any satellite signal
You should use your computer to update the QuickFix positions of the Satellites (they do wander in the sky). To get signals you should be outside buildings with an unobstructed view to the sky.
Jan 18, 2014 | Tomtom One GPS
305 Not Picking up satellite signal
Visit the link below to update the software,
Here
Serial to usb connector needed like this Here
Should be good after that.
Regards.
Apr 16, 2009 | Garmin Forerunner 305 GPS Receiver
My pc [toshiba satellite a55- s106] sound just went off but when i put headphone i can hear sound. pliz help to restore my pc sound back.
On my Satellite I would constantly readjust my sound simply but picking it up and moving it as the control disk was on the side. Just checking to be sure you did not inadvertently knock the switch to the mute position? Though I am sure you checked that already - posting just in case.
Dec 27, 2008 | Toshiba Satellite A55-S106 (PSA50U0NE02E)...
Cannot get satelite signal for magellan triton 1500.
Options:
1) Walk outside and give the unit 3 - 5 minutes to acquire satellites.
2) Push the PAGE/GOTO button on the left side of the unit until you see the satellite page and see if you are picking up satellite.
3) If 2 and 3 do not work .. then reload the firmware again.
JG
Aug 22, 2008 | GPS
Can not save television channels
Send it back and get your money
Apr 01, 2008 | RCA DRC8335
Picking up tv station
Yes, lock out the frequency, or wait until digital broadcast comes int effect. DTV will be effective in 2009 where all television broadcasts must be done by cable or satellite. This means no antenna broadcasts.
Mar 17, 2008 | Uniden BC60XLT-1 Handheld Scanner
Only picking up one satellite
Thank you for the info.
Here is what you can try:
Try to get the Echo 8.10(110W) first by connecting the LNB on your left if you are behind the dish. On the first transponder from 110W you need to get anything better than 90% quality.
After this is done you may have to play with the skew until you get 119W. On 119W the first transponder frequency is 12239Mhz.
The skew will depend on where you live.
Check here for more info on the parameters to get your dish align.
BTW, What kind of receiver do you have?
Feb 22, 2008 | RCA DISH Network(r) 311 Satellite System
No satellite reception
open it up carefully and chk for the wire make sure it did not popped off .if it did resolder it and if does not work after that get a new unit.
Dec 20, 2007 | Magellan RoadMate 700 GPS Receiver
Lowrance 116-20 : GlobalMap 3600C iGPS - GPS receiver : GPSS364 Logo
16 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
