Question about Casablanca Fan Stealth 3211T Ceiling
Casablanca fan-how to replace flywheel? - Casablanca Fan Stealth 3211T Ceiling
    Genius:
  • Casablanca Fan Master
  • 1,617 Answers
You'll need a special tool to take it off. Check www.casablancafanco.com for the nearest service center.
Posted on May 17, 2013
Testimonial: "Hey Dave; not to be an ingrate, but you can't be a "shade tree mechanic" member. The motto by the way is "Never throw a straw to a drowning man". Take care and good luck,Haywire."
Is Casablanca Zephyr Table fan # 1928C available???
It is. $50 on eBay.
  • Casablanca Zephair Desk Fan Table Fan Model 1928D ' eBay www.ebay.com > Search > Casablanca Zephair Desk Fan Table Fan Model 1928D Find best value and selection for your Casablanca Zephair Desk Fan Table Fan Model 1928D search ... Vintage CASABLANCA Model 1928C Floor Fan 120vac 60HZ ...
  • Casablanca Fan Zephyr Oscillating Desk - sears.com www.sears.com/search=casablanca fan zephyr oscillating desk Home / Results For: "casablanca fan zephyr oscillating desk" ... SYBA 8-inch Tall Personal Table Mini Oscillating Fan, 2-Speed, Adjustable Head, Black.
  • Casablanca Zephair Desk Fan (Table/Desk Fan) 1928D in ... www.hansenwholesale.com/ceilingfans/casablanca/model.asp?ProdNo=1928D Casablanca Zephair Desk Fan (Table/Desk Fan) Model 1928D. Choose Custom Options & Accessories Here. ... The Casablanca Zephair Desk Fan is UL Listed for ...
  • Casablanca Fans Zephair Floor Fan Portable Fan 1928F www.casablancafansonline.com > ... > Portable/Freestanding Fans Casablanca Fans Zephair Floor Fan Portable Fan ... This 0.0 light Portable Fan from the Zephair Floor Fan collection by Casablanca Fans will enhance your home with a ...
  • Mar 24, 2016 | Casablanca Fan Zephair 19N8C Table
    I have a Casablanca ceiling fan that is making a thumping noise as it rotates.
    Call Casablanca @ 1-800-715-0393. It is not a simple repair. It does sound like a flywheel problem.
    May 31, 2015 | Dryers
    Ceiling fan off track
    Might have broken the flywheel if this fan has one. The flywheel is the is the round rubber wheel that the blades attach to. If I knew the model of the fan I would know if it has a flywheel.
    Aug 31, 2013 | Casablanca Fan Dryers
    Casablanca fan stopped working. Cannot turn by hand
    Check the rubber flywheel that you attach the fan blades to on the motor to see if you need a new one.
    Feb 18, 2013 | Dryers
    Replacing the flywheel on a Homestead 6 blade fan Are there any instruction sheets that are available?
    I had to do the same with my Casablanca fan. Biggest problem was getting the light kit holder off the bottom of the fan before I could remove the remnants of the flywheel. Had to purchase a special tool to pull the light kit holder off. If this sounds like what you are faced with let me know and I will be happy to give you additional details.
    Sep 03, 2010 | Hampton Bay 52 In. 5-Blade Fan, Aged...
    I have a Casablanca New orleans fan that I just had fixed by an approved Casablanca repair place. The fan is and always has been connected to a dimmer switch. After a repair of a simple flywheel, the fan...
    Hi, is this fan an older fan with the dimmer type control on the fan itself, (and you have a wall speed control in addition to) or is it the later fan with a three speed pull chain control? If the latter, the service rep may have accidentally placed the fan on Medium speed which due to additional capacitance from the speed control board in the switch housing, could cause the symptoms you describe.
    Thanks, Brian
    P.S. That's an $$$$ fan, glad to see you had it repaired instead of replaced.
    Aug 29, 2010 | Dryers
    Casablanca stealth fan light scrapes against blade surround
    There are two probable causes. One, the light housing has been pushed/bent up into the rotating assembly, which is possible if the fan were ever removed from the ceiling and sat on the glass.
    If it has never been removed however, the most likely cause is that the Allen Set screw on the flywheel has loosened allowing the flywheel to slip down the motor shaft. It's a purely mechanical problem and if memory serves, to get to the flywheel, you remove the light pan and it's right there. Find the set screw, loosen it enough so that the flywheel is easy to move up and down and raise it up a bit and then cinch it down tight. It's a fairly common problem and for the life of me I cannot understand why Casablanca would not use loctite on that set screw. I mean you pay $500+ for a fan, it should outlast you, right?
    Jun 03, 2010 | Casablanca Fan 3245T Ceiling
    Scraping sound inside casablanca stealth fan
    You need a new flywheel. Go here: http://www.bostonplus.com/parts.html#flywheel
    Jan 24, 2009 | Casablanca Fan Stealth 3211T Ceiling
    This is actually a Delta II model fan. The fan blades and the ring they are bolted to recently dropped out of the fan housing and are sitting on top of the base of the light kit. Is this the flywheel? If...
    it is the flywheel. I ordered one directly from the Casablanca web site, took the fan down and find the parts are pressed together. Looks like it needs some heavy tools or a jig of some kind. Any suggestions?
    Jul 05, 2008 | Casablanca Fan 3245T Ceiling
    Casablanca Fan Stealth 3211T Ceiling Logo
    286 people viewed this question
    Top Casablanca Fan Dryers Experts
    Henry  Thomas
    Henry Thomas
    Jerry Greenberg
    Jerry Greenberg
    Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
