Question about Craftsman Garden
Craftsman ZTS 7500, center blade cuts but outside blades do not.
I can manually turn the blades on the outside but center blade doesn't, if I turn the center blade manually then all blades turn. under power only the center blade cuts. Is the center hub broken or stripped maybe?
SOURCE: Craftsman 18.5 riding mower when I engage the
craftsman decks have a positive stop adjustment for the decks. A spring atached to the blade ingadgement arm pulls the tension pully into position if the cable is rusted inside the sleeve it wont put enough pull on the ingadgment pully and thus the blades dont spin full force the belts on the mowers have no adjustments only the pully . second thing is you may want to drop the deck and clean around that pully by scraping any rust off the surface under the pullys slide good luck
Posted on Jun 20, 2009
  • 11 Answers
SOURCE: I have a craftsman zts 7500 zero turning radius 26
i going to assume that yr tractor does have the hydrolic p.t.o. that controls the drive and cutting mechanism's???... if so you might start with checking the hydrolic fluid in the resevior. or you might check into replacing the hydrolic p.t.o. pump , if you ran the tractor in heavy work without any hydrolic fluid in the p.t.o. pump the pump is probably burnt up. if so im sure you can beat the cost of a new pump by rebuilding it yrself with a kit.
Posted on Jun 24, 2009
  • 218 Answers
SOURCE: one blade on deck gives an uneven cut
Hi..my name is Keith..and most times..when your problem happens..either the deck is bent down from runing into something or stepping on it..or the deck hanger is bent, worn or out of adjustment..or the blade on that side is bent..and i hope this will help..if not..please write back
Posted on Jul 04, 2009
bbreton
  • 437 Answers
SOURCE: I have a 19hp craftsman 42 deck. It has two
You may be running too fast on ground speed for the mower deck to cut completely. It may be time for some new blades. The blades may be worn down to where they are shorter than when they were first put on.
Posted on Sep 26, 2009
SOURCE: duel blades on craftsman riding mower cut unevenly
Its not the tires it is the blades don't line up.One blade is three-quarters of an inch lower.Is there a shim for the star fitting.
Posted on Jun 11, 2010
I'm trying to find PDF repair manual 4 ZTS 7500 Craftsman Zero-Turn mower
Here's the owners manual which includes belt replacement.
http://www.hammerwall.com/Download_Manual/38636
Here's Sears parts direct, with 11 diagrams of the mower.
Model zts7500 CRAFTSMAN REAR ENGINE MOWER Parts
Aug 08, 2016 | Craftsman Garden
Blades won'e engage
Your belt may be on wrong or slipping.
May 23, 2013 | Craftsman Garden
I have an 07 craftsman 24 ohv, 42 " cut riding
Left blade is on backwards (liftng edge is contacting grass). Try reversing the blade on the left side.
Jun 15, 2012 | Garden
Craftsman ZTS 7500 dies when engage blades or when engage transmission
check the "kill switch" they are usually located in the seating area. it senses for pressure or seat angle and will kill the mower if nobody is sitting on the mower. Good Luck
Apr 17, 2012 | Craftsman Garden
It leaves the center uncut
i think i would raise the whole thing up on jack stands and take a look at the bottom of the deck. do not start it of course, but the problem should be evident. 42 inch generally means only 2 blades which are cutting on the outside leaving you a mohawk. so something is blocking the grass from being cut in the center. if it is by chance a 3 blade deck , then something is wrong with the center blade, if it is there i would guess a broken key.
Aug 23, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
My craftsman zts 7500 will not start. The battery is charged, but turning the key does nothing.
The problem may be one of the safety switches. Make sure the blades are not engaged. The clutch pedal needs to be pushed all the way down, and there is another one that needs weight on the seat. Look around those areas for disconnected wires. Some even need to be in neutral. Lots of safety features.
Mar 27, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
I have a 7500 zts 50" and I cant find new blades for it,please help
I would suggest taking an old blade to a home hardware store or a Sears store to match up.
Oct 22, 2009 | Craftsman Garden
Craftsman zero turn - blades won't engage
The PTO switch contacts to operate the clutch that starts the blades is defective. I have replaced mine and the new one just failed again. Sears must know this is a defect problem but so far they are quiet about the problem
Jul 20, 2009 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have a craftsman zts 7500 zero turning radius 26 hp with a pull knob over elec.To turn on the blades.It also has an elec.raised deck.When I pull the knob to turn on the blades the engine dies.And when I...
Jun 24, 2009 | Craftsman 20 hp 42 in. Deck Yard Tractor
Craftsman zts 7500 will not run with levers engaged
Cody,
Yes, I am sitting when I do engage the blades on my craftsman zts 7500. All you do is pull/push the engaged button to your left well you are seated.
Apr 05, 2009 | Craftsman Garden
Garden Logo
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
