Question about Microsoft Xbox 360 Console
Xbox 360 live sign in error
I'm getting an error when trying to log into xbox live that says a system update is required to sign in to xbox live but the update is currently unavailable. if the problem persists, visit www.xbox.com/support.
  • 4 Answers
When you do this try plugging it in to an ethernet cable
Posted on May 08, 2013
  • 5 Answers
SOURCE: Xbox Live Sign Up Unavailable .. :S
Yeah... called xbox today and they say that due to the high volume of holiday signups.. it's thrown the server into all sorts of problems... they don't know when the problem is gonna be fixed.. but the guy said to keep tryin' every now and then and hope for the best... sucks!!
Posted on Jan 05, 2008
SOURCE: Unavailable Xbox live signup. >=[
I have been able to sign up today. This site was a big help: http://www.acddv.com/
Keep checking back so see when Xbox live is online and working. Then at that time quickly sign up. It worked for me and i'm on it right now! Good luck everyone!
Posted on Jan 06, 2008
  • 127 Answers
SOURCE: i have xbox 360 250
so better download this I want to just make it clear to you, that you can repair the following problems at home with a good repair guide. There is no technical knowledge needed you simply do what you see on the step by step vids or the paper guide.
Click Here
Posted on Dec 11, 2010
  • 71 Answers
SOURCE: I was doing the new Xbox live update 2011 and my
Unfortunately this means that your xbox 360 is "bricked" or unable to work due to corrupt software. You need to contact Microsoft (xbox section) and they should be able to replace it for you.
Posted on Jun 13, 2011
  • 8 Answers
SOURCE: Hello, I have a modded
1. Anote second hex data 22FB-3151-B200-0700-C000-0013 and go to http://easycalculation.com/hex-converter.php
2.
Convert it to decimal and get the update number:
Hex:
3151 - Decimal: 12625 Update
3. Go to http://dl.console.se/index.php?dir=Xbox360/uppdateringar/ and seek the correct update. Download it.
if not try to locate it on google)
4. Extract $Systemupdate and put it into root of a pendrive formatted in fat32 or a CD
5. Turn off the console and plug the pendrive or insert the CD
6. Turn on the console and wait
7. Enjoy!
Posted on Aug 23, 2011
I'm losing my connection...
It sounds like you've refused an Xbox Live Update at some point.
You can go into your system options and see if there's an update available.
To check for an update on the Xbox 360 you basically force a new Xbox Live connection:
  1. Press the Guide button (center logo button), bringing up the pop-up menu
  2. Go to Settings
  3. Select System Settings
  4. Select Network Settings
  5. Select Wired Network or the name of your wireless network if you're on wifi
  6. Select Test Xbox Live Connection
  7. Select Yes if prompted to update. If you're not prompted and the test completes successfully, you have the most recent update.
If that doesn't work try this link http://www.gamefaqs.com/boards/927749-xbox-360/67807343
Jan 08, 2017 | The Video Game Consoles & Games
Alright my girlfriend just got an xbox and she has everything set up, but she cant connect to live because a text pops up that says that it requires an update but she said that it has said that 5 times....
The easiest way to update your console software is to connect to Xbox LIVE. To update your console by using Xbox LIVE, all you need is an Internet connection.
  1. Connect your Xbox 360 console to the Internet. To learn how, please see How to connect to Xbox LIVE.
  2. On the console, go to My Xbox, and then select System Settings.
  3. Select Network Settings.
  4. Select Wired Network or the name of your wireless network, if you are prompted to do so.
  5. Select Test Xbox LIVE Connection.
  6. Select Yes if you are prompted to update the console software.
If you receive a connection error, try using the Xbox LIVE Connect Solution.
Console update did not install successfully?
If her system says that she needs an update then likely her connection should be getting to Live. You might need to clear her cache first and then try the steps above. Here is how you will clear your cache:
To clear the system cache
  1. Go to My Xbox, and then select System Settings.
  2. Select Memory.
  3. Highlight any storage device, and then press Y on your controller.
    (It doesn't matter which storage device you select; the cache will be cleared for all storage devices.)
  4. Select Clear System Cache.
  5. When prompted to confirm storage device maintenance, select Yes:
Aug 03, 2011 | Microsoft Xbox 360 Console
When I go to download update it says can't connect to xbox live and test connection. When I test the connection it says it's fine. tried the update again and got the same error. Status Code:...
Try going into your network connections and doing a test connection. It should log you out do the test succesfully and then attempt to redo the update. It should ask you to update again and just accept the update by pressing the A button.
Hopefully it should update your system without the error this time? Good luck.
Jul 19, 2011 | Microsoft Xbox 360 Console
Systems need up dating disc
You're Xbox 360 does not need a specific disc to update. When you log into Xbox Live, and your system needs an update, it will usually give you the choice to update, or not, but you don't need a disc to do so. To sign up for Xbox Live, access the Sign Up feature on your Xbox Dashboard. You can also sign up for Xbox Live at the following link http://www.xbox.com/en-US/live/joinlive
Xbox Live does cost money.
Jun 28, 2011 | Microsoft Xbox 360 Console
My xbox is not letting me sign on x-box live. it is saying a system update is required to sign into xbox live.
You will need to accept the update otherwise you will not be able to sign into Xbox Live.
There was a recent dashboard update, this could be the problem.
Nov 22, 2010 | Microsoft Xbox 360 Console
I keep getting the 80150010 error. We have tried all the recommendations. We have been at this since 5 ct. Please help. First time to sign up for xbox live.
error message 80150010 when trying to sign into Live, follow the following instructions:
1. From the dashboard logout of Xbox Live if logged-in
2. Remove any profiles on the Xbox 360 with the same name as the gamertag being recovered (This can be done on the “System” blade within the “Memory” option)
3. Using the “Xbox Live” blade, select “Recover Gamertag from Xbox Live”
4. When prompted, enter the gamertag being recovered and click “Next”
5. On the “Passport Network Account” page, press the “Y” button to “Recover with Original Xbox Info”
6. Proceed to recover the account by providing the information requested by the prompts
  1. To delete a profile
    1. On your console, go to My Xbox, and then select System Settings.
    2. Select Memory.
    3. Select the storage device where the profile is located.
    4. Select Gamer Profiles.
    5. Select the gamertag that you want to delete.
    6. Select Delete.
    7. Select Delete Profile Only.
  2. On your controller, press the Guide button.
  3. Select Recover Gamertag and follow the on-screen instructions.
Jul 22, 2010 | Microsoft Wireless Network Adapter Xbox...
My friend brought over his memory pack and disconnected mine but when it came time to attach mine my avatar wasn't there and when i tried to go customize it a warning sign popped up and said you need to...
It is a compulsary update for your Xbox 360 system so it can support the feature you are trying to do. So you really might want to join to Xbox Live by creating an Xbox Live account and by signing in to Xbox Live, it will automatically install the latest firmware to update your system.
May 09, 2010 | Microsoft Xbox 360 Console
It won't let me sign up to xbox live.
Xbox 360 to network is ok. network to internet is ok. internet to xbox live comes up 40% connected and pops up with update required. when i try to update the bar doesnt move and then it comes up with failed to update.
Nov 15, 2009 | Microsoft Xbox 360 Console
Can't Connect to Xbox Live / Can't Receive Update
try looking at your wireless connection and in this case try deleting your orginal connection and creating a new connection
Sep 12, 2009 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
208 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
