Question about Eclipse AVN5500 Car DVD Player
Where can I find rear speaker wire for this unit.
Putting unit into a car that does not come with a built in amp and the 4 rong wire is missing to con trol the balane and rear speakers.
    President:
  • 676 Answers
Are you looking for wires on the radio or the vehicle?
Posted on May 09, 2013
How can I find a wiring diagram
Hi Bob
Not much info to go on??
Usually don't need one
12v DC to posative (red)
12v Ground to Chassis or body of Amp
Possibly an Ignition Key 12v to hold memory settings
2 Speaker Unit will have 4 wires - 2 to each speaker
one wire of each pair will have a stripe (say negative)
keep striped wire to same speaker terminals to keep the speakers in phase with each other (speaker cones travel in same direction or you get distortion)
4 Speaker Unit - same as above but either Front Pair or Rear Pair.
Get the Amp on a bench & test the unit with a couple of cheap temporary speakers.
Good Luck
How to connect your car amplifier very simple explination and test
Part 1 How To Set Up PSU Car Amp Subwoofer In Home Re Do Video
Mar 16, 2016 | Car Audio & Video
LED lights up but! ???
Sounds like there is a problem with the amp. Try switching the inputs around for that output on the amp. If that does not help, Yes I would have to say that there is a problem with the amp output circuit.
Nov 06, 2007 | Infinity BASSLINK Car Subwoofer
How hook amp up to a oem integration SNI-15 line output convertor
The amp needs an RCA input to communicate with the head unit. SOLDER the wires that come out of the head unit for the front speakers to the SNI-15, making sure that the polarity and right/left is correct. Do this for the front and rear speakers if you have a 4 channel amp. Cut the wires if you add new speakers and run the new wire from the speakers or sub box directly to the amp, or skin back the wire insulation and tap on if you use the factory speakers :( then plug your RCA cable from the SNI-15 to the input side of the amp. Don't forget that most new cars have their own amp so you might have to locate it and bypass the speakers wires around it. Don't make a mess in case you have to put everything back to factory for resale. You can avoid all this by installing a new/modern head unit with built in RCA outputs for front, rear, and sub woofer. I hope this helps. Ray
Apr 23, 2014 | Car Audio & Video
How do i install a wharfedale CD head unit into a daewoo lanos 01
Please see THIS TIP for generic head unit wiring, and also the following Wire chart for your Lanos....
2001 Daewoo Lanos Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Brown/White
Car Stereo Dimmer Wire: Dark Green
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Brown/White
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Brown/White
Right Front Speaker Negative Wire (-): Gray
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue/Black
Right Rear Speaker Negative Wire (-): Yellow/Dark Green
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 03, 2010 | Car Audio & Video
Need a wiring diagram for the stock stereo system in order to install after market unit
2007 Saturn Vue Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Dark Green
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Light N/A
Car Stereo Antenna Trigger Wire: White
Car Stereo Amp Trigger Wire: White
Left Front Speaker Positive Wire (+): Tan
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Right Rear Speaker Negative Wire (-): Light Blue
Good luck and Happy New years.
Jan 04, 2010 | 2007 Saturn VUE FWD 4
Wiring Speaker to amp
remove all speaker connections to your amp. MAke sure the inputs are driving all 4 channels, and that the built in crossovers on the amp are all set to full range. Conect your full range speaker to each output channel one at a time and verify there is oputput on all 4 channels. If all is ok, then connect your rear speakers to the front(a) outputs of your 4 channel amp, and then use the second 2 channels (rear or B) bridged to drive the sub. Re-configure the crossovers for highpass for front (to drive your rear speakers) and lowpass for sub. This is the proper way to connect a 4 channel amp with a sup whle driving 2 full range speakers.
Jun 10, 2009 | Car Audio & Video
1999 Audi A4 Rear Speakers
The large block is a factory amplifier - in your car (as was in mine) you had a partially-amplified system. The front speakers were driven at speaker level from the head unit, but the rears were fed a line-level signal from the head unit to the amp, which then boosted to speaker level. The harness then sent the speaker level signal to each rear speaker.
What you can do is fit your new head unit. The fronts will interface perfectly with no issues. For the rear, run new wires from the adapter harness at the back of your head unit, back to the new rear speakers, and connect them directly. Then everything will work as it should.
Dec 17, 2008 | Alpine DDW-F30A Car Speaker
Rear speakers in audi 1999 audi a4
You don't want to fit that - it's the factory amplifier for the rear speakers (the rears are amped, the fronts are not). You need to run new wires from the head unit back to the new rear speakers so that the speaker-level outputs from the new head unit are used to drive the new speakers.
Dec 16, 2008 | 1999 Audi A4
1998 Audi A4 Quattro rear speaker wiring
You can't use any of those - the large connector at the OEM speakers is because the rears are amplified. Your factory head unit puts out a line level signal to the rear speakers. There's an amplifier on the driver's side rear speaker (the box around the magnet that you can see from inside the trunk).
You need to either replace the head unit with an aftermarket one to drive your new speakers, or you need to tap into the amp connector and find the line level wires, break them out, put RCA plugs onto them, and plug them into an aftermarket amp, which you'd use to power your rear speakers. Doing it that way allows you to keep the factory head unit.
Oct 25, 2008 | 1999 Audi A4
Radio on but no sound
i have a 1994 eagle vision, with the premium sound system (infinity) and yes you do have a amp in your car if you have that sound system and its in the trunk of your car to the left while looking at your trunk from the back of the car :) also if you tryed putting in diffrent speakers other then stock thats your problem you have to rewire new speakers cant use old wiring because it goes threw the stock amp and for some reason the stock amp only works with the stock speakers :P
Oct 01, 2008 | 1995 Eagle Vision
Eclipse AVN5500 Car DVD Player Logo
20 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
